Alternator Bearing or water pump - Citi Golf
- Car Model: Polo 1.2 TSI
Hi all..
Over last few weeks, have a weird rubbing noise around the alt and water pump area. I took belet off and noise gone so definately one of the two..
I just need to establish which is exactly the culprit without buying one item and its the next.. The noise isn't there constantly and doesn't get louder or anything.. The belt is fine and tension is ok..
Anyone can help will highly be appreciated.
I even used the longer screwdriver and placed against alt to hear but sound is all different.
Current: 1.2 Polo TSI 66KW
EX Polo Vivo Blueline
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Pieta
- Car Model: 04 A4 1.8T 6spd S-Line
- Membership No: 1909
Re: Alternator Bearing or water pump - Citi Golf
Most probably the water pump. What's the mileage on your car? You can also feel for play on the water pump pulley.Little D wrote:Hi all..
Pieter "Pieta" Oberholzer
-04 Audi A4 B6 1.8T
BT In process
Biltein + Eibach Sportline
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
210000.. I did change as precaution some time back..
I span the pulley and its doesn't have much play..
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Start the car and get a longish screwdriver, put the sharp end on waterpump/alternator and your ear on the other end... you will hear were the noise is coming from... unconventional but works
Sharp . Tried with alty only. Will do on waterpump also. Thanks
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Pieta
+1 This works like a charmNaku786 wrote:Start the car and get a longish screwdriver, put the sharp end on waterpump/alternator and your ear on the other end... you will hear were the noise is coming from... unconventional but works
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
alternativelly, get some of that penetrating/lubricating fluid, the one that comes with a long thin red tube that gets pressed into the nozzle, so that you can have very accurate control over where you spray it.Pieta wrote:+1 This works like a charmNaku786 wrote:Start the car and get a longish screwdriver, put the sharp end on waterpump/alternator and your ear on the other end... you will hear were the noise is coming from... unconventional but works
aim the spray at any of the suspected components, don't forget the idler pulley over which the fan belt runs, those idler pulleys bearings are known to run dry and start to make noise.
the one where the noise goes silent is likely to be the culprit
I have known people to change steering pumps, air-con pumps, alternators etc, very expensive exercise, and the noise still doesn't go away....then they do the trick above, and when the oil gets into the idler pulley, the noise went away, and the replacement cost is minimal compared to the other big components.
Thanks Guys
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
One way to test the alternator is to take the belt off and spin up the pulley with your fingers, it should be quiet - no rumbling noises.
Current rides:
Hyundai - 1.4 Getz (daily)
I will certainly.
The alt does sound a bit rough but not the noise that its making.
sounds like a wobble sound or so.
the waterpump does have a screetch.
Waterpumps , Meyle i heard is good but how does it compare to OEM?
Well Vw wants over R1300 for it
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Just buy the pump, you can use the same housing. Change your themostat while you at it. I used a GMB brand product, brilliant quality IMO.Little D wrote:I will certainly.
- Pieta
GW Sells Meyle and in all honesty, I have used 3 of these and never had issues. Even have a Meyle part on my ABF.Little D wrote:I will certainly.
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
I have been to one spare shop and offered me GMB. I wasn't really knowledgable about it though. They also said its good. Well the meyle one is R100 more so I thought I'd stick to what I know.. Vw quoted me for thermo R141 which isn't too bad.
I checked now and the waterpump is definetely making noise. I used the screwdriver method
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Car Make: Reebok
- Car Model: Classic
How much the waterpump cost?
Do it once, do it right!
'13 Polo Vivo 1.6 - stock- RIP
'08 rox 1.4i - 76kw - sold
Around 400-500
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Car Make: Reebok
Awe. Thanks buddy
I paid R 230.00 for a GMB pump from midasLittle D wrote:Around 400-500
- General
Yes it's cheaper if you buy just the pump without the housing...Naku786 wrote:I paid R 230.00 for a GMB pump from midasLittle D wrote:Around 400-500
Current rides:
I got quote on GMB complete - R320
So roughly same.
Who stocks Echlin Though?
So roughly same.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
Autozone and most decent spares shopLittle D wrote:I got quote on GMB complete - R320
So roughly same.
- Car Make: Reebok
Goldwagen quote - R384. Complete
make is WAG.
Any good/reviews?
make is WAG.
Any good/reviews?
WAG is the GW house brand, never used it so cant comment. I always settle for topran/febi/meyle if I buy from GW...thepot wrote:Goldwagen quote - R384. Complete
make is WAG.
Any good/reviews?
Echlin or GMB from spares shops...
- Car Make: Reebok
Eish.
Thanks naku, will ask for meyle if I'm there.
where's torker now to comment. Sure he has used it all before lol
- General
I've bought a GMB pump from Midas before and it served me well. Thermostat I will always go OEM for extra peace of mind. This is what I'll be fitting in both my 16V's - spot the difference...
Current rides:
- Taz0
- Car Model: Polo 9N3 2.slow
- Membership No: 1925
1 outlet
Mk1 Citi golf
Mk5 R32
Mk4 golf 3.6 4motion
Mk5 R32
