Best Gearbox for an ABF mk1
Citisport007
Car Model: MK1
Post by Citisport007 »
Good Day
I have an ABF setup in my mk1 with the FFZ gearbox. Car is driving fine it just feel that the gears is to short.
Is this normal for the FFZ or would you guys recommend another box.
Thank you in advance!!!
16V
09 Citisport ABF
SykomantiS
Car Make: SsangYong
Car Model: Rexton II 270XDi
Re: Best Gearbox for an ABF mk1
Post by SykomantiS »
Why not use the 6 speed Touran TDI box?
It has the same 1st four gears, longer 5th, and a 6th. Not sure what the box model number is though.
edit: not sure if the box I'm comparing it to is the FFZ, but I know it's the one used in the 1.4 citi (somewhere 2000 onwards I think)
2008 Honda Civic 2.2 iCTDi VXi
2010 SsangYong Rexton 270XDi
Boost
Car Model: Caddy pickup
Membership No: 1921
Post by Boost »
Wouldnt the 02j or 02A box work?
Sent from my Nokia 3310 using Tapatalk
Current: 2008 VW Caddy R-Line 20V BIG T :driving:
2009 CW 9n3 Polo Gti
2012 Holden Captiva 2.2d LX
2011 Holden Cruze Equipe
2010 Great Wall V240 Ute
2017 Chev Captiva 2.2d LT daily
2000 Vw Citi 1.6i
2013 GW Audi A3 Sportback 1.8TFSI SE S-Tronic (POS)
2006 Volvo S40 T5
2004 Nissan 350Z Coupe
2000 VW Golf 4 GTI (247wKw @ 1.3bar)
2007 Fiat Grande Punto
1994 Fiat Uno Turbo
1994 Fiat Uno Pacer
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
What are you looking for - longer ratios through the gears or more relaxed cruising in 5th?
Current rides:
Hyundai - 1.4 Getz (daily)
MOST WANTED
Car Make: VW GOLF
Car Model: MK1 16V ABFt
Post by MOST WANTED »
The ffz is fine. Just change the 5th to a longer ratio
2L 16V ABFt- 180kw @ 0.8 bar @ KAR
Citisport007
Car Model: MK1
Longer ratios through the gears especially 3rd!!!
16V
09 Citisport ABF
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
Citisport007 wrote:Longer ratios through the gears especially 3rd!!!
You can keep the FFZ ratios and change the final drive to 3.67 (eg AEN), that will give long ratios. Unfortunately the majority of 020 rod shift boxes have short ratios, similar to the FFZ so the solution is to customise the box for longer ratios. What wheels and tyres are you running?
Current rides:
King8v
Car Make: Chevy
Car Model: Sonic 1.6 LS B&W
Post by King8v »
So swithching the final drive to the AEN one, makes for longer ratios throughout? And if you want just a longer 5th, then you swop out just that one? Which one to?
Citisport007
Car Model: MK1
@ Torker
195/50/15
16V
09 Citisport ABF
duncan
Car Make: SEAT
Car Model: Golf MK1
Post by duncan »
Citisport, I was about to make the exact same thread.. I've got a stock ABF-ffz in a mk1 also and I find 1st-3rd gear/s are way to quick.... Where u from?
16v
'05 velocity ABF
'95 cti
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
This will be the speeds through the gears with your setup - looking at 3rd gear, 7000rpm = 140km/h. I actually made my 2nd/3rd and 4th gear shorter in my ABF GT.
Current rides:
blacfly
Car Model: Type 1 1973
Post by blacfly »
What would be the best setup to do about 130km/h at or under 3500rpm?
And is this a good idea?
Sent from my GT-N7100 using Tapatalk
Citisport007
Car Model: MK1
Yes Torker
Can you post one of an AUG
16V
09 Citisport ABF
duncan
Car Make: SEAT
Car Model: Golf MK1
Post by duncan »
Torker wrote:This will be the speeds through the gears with your setup - looking at 3rd gear, 7000rpm = 140km/h. I actually made my 2nd/3rd and 4th gear shorter in my ABF GT.
Damn this looks complicated, I dont have a brain for those figures... Torker is that diagram of a FFZ box?
What boxes do you have in your cars Torker? specify motor and box please.
16v
'05 velocity ABF
'95 cti
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
There are alternatives to the ever popular FFZ, first is the original box that was in the MK II Jumbo 16v, IMO probably the best choice, except they are very rare. The other one is the G3 GTi box. Both of these are 020 gearboxes and will be plug and play, so to speak. An 02A box can be fitted but will need cable gearshift mechanical to go with and a modded gearbox mounting, which is money I would rather spend putting in a LSD to keep all those lovely ABF ponies on the road.
mojo786
Car Make: Vw+SEAT
Car Model: VeLo+Cupra
Post by mojo786 »
I also did that when I broke my ffz,shorter gears mean losing less rpm on high rpm changes kEeping power band healthy..next is longer 5th gear 4.2 diff and LS :evil:
Velo-ABF-ride-thread
2.0 16v ABF - MP9/ Per4mance Custom Tuned-(0837860345)
57mm F/F
Custom ratio Bolted diff Gearbox
CrossDrilled VR6 stoppers!
JOM coilovers
A.R.B
Webasto tilt n slide sunroof
.:R -Line boot spoiler
07 SEAT IBiza CUPRA TDi
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
Mopower.abf@gmail.com
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
Citisport007 wrote:Yes Torker
Sorry don't have the AUG gearbox, if you give me the ratios I make one.
Edit - I'm lying, found this for AUG:
Current rides:
King8v
Car Make: Chevy
Post by King8v »
Did you see this one Torker? Sorry i wanna get my box sorted at some point, and want to know what im talking about. :grin:
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
I've got FFZ/AEN short ratio gearboxes in both my GT's, the ABF got standard 3.94 final drive but the 16V got 4.25 short final drive, better suited for drag racing.
Current rides:
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
Let me have a look at the ratios and draw up a couple of graphs.
If you swap in a longer final drive, all the ratios will be longer. When I had my first FFZ/AEN gearbox built I used the remaining stuff to built an AEN/FFZ hybrid - basically the opposite as my short ratio gearbox. I sold it to one of the guys on the forum that put it in his 2.0 Jetta 2. It had AEN 1st and 5th, FFZ 2nd, 3rd and 4th and AEN diff.
Straight AEN gearbox will work as well, the 5th is pretty long...
Current rides:
King8v
Car Make: Chevy
Post by King8v »
Thanks a lot bud. Just to get an indication, what does it cost to get such work done? I know thats like asking how long a piece of string is, but just so i can get an idea.
duncan
Car Make: SEAT
Car Model: Golf MK1
Post by duncan »
Back to the initial question.... Best gearbox for ABF MK1? I don't think at this time I would actually have a box built/switching of gears/diff.
Refering to a complete gearbox as is, which would be best suited?
Citisport007 wrote:Good Day
Since I tunned my car I took on a buddy of mine lastnight, identical motors/cars (mk1), same KW bracket, same rims even to the exact same tyres except that hes running AUG and me FFZ.
Results: 1st & 2nd gear neck on neck, 3rd gear he leaves me behind about a 2 car gap then thats how it'll stay right through till 5 gear and don't tell me its driving. NB hes box has NOT been modified!
AUG/FFZ/DDG, what else is there?
16v
'05 velocity ABF
'95 cti
Citisport007
Car Model: MK1
So Torker witch box would you recommend?
16V
09 Citisport ABF
Torker
Car Model: Golf GT
Membership No: 1464
Post by Torker »
Citisport007 wrote:So Torker witch box would you recommend?
For a daily a FFZ/AEN hybrid with 3.94 diff, for a track toy FFZ/AEN hybrid with 4.25 diff.
Current rides:
