citi golf gear linkage adjustment
goose763
Car Model: Citi 1.6
Post by goose763 »
I replaced all the gear linkage bushes and in busy to put everything back together again.
Following this how to > http://vwgolfmk1.org.uk/index.php?page= ... 2%2F2%2F15
Problem is, now all my gears are fukd. I can get reverse, and then it feels like first gear is in 3rd gear's position and second in 4th gear's position. Cant get into the normal 4th and 5th positions.
What to do?
2000 Citi Golf 1.6
ex rides:
'97 mk3 golf 1.6i GS
'99 Citi Golf 1.6
'97 Citi Chico 2l 8v
'99 Citi Sonic 2l 8v (73kw/164nm-atw)
Honda CBR400RR
Honda VFR400R
Suzuki RG125F
PapaJo
Car Make: VW's
Re: citi golf gear linkage adjustment
Post by PapaJo »
IIRC the gap should be 10mm and not 19mm as shown in the link you posted on step 47. 10mm gap between the plastic clip part and the steel piece on the body. That plastic part need to clip onto the steel part on the small lip for reverse.
THANAS
Car Model: AW Polo GTi
Membership No: 2035
Post by THANAS »
1. Put car into neutral
2. Loosen the pinch bolt that grips onto the splines
3. Set the gap to say 15 - 20mm
4. Tighten the pinch bolt
5. Check that you can get into first and second.
6. Repeat if you're not getting all gears by adjusting the gap with the pinch bolt loosened.
Sent via Hedwig
goose763
Car Model: Citi 1.6
Post by goose763 »
CitiCitiBangBang wrote:1. Put car into neutral
Sent via Hedwig
Thanks!! Set the gap to 15mm, and now all is right. The smoofest shifting ive ever had in a citi
ciao :grin:
2000 Citi Golf 1.6
ex rides:
'99 Citi Golf 1.6
Honda CBR400RR
Honda VFR400R
Suzuki RG125F
Fuchs
Post by Fuchs »
If you dont come right, try the following:
1) Disconnect pinch bolt and pull off selector arm which is part of the bolt assembly.
2) Manually engage second gear on the gearbox by using the selector arm on the gearbox. Start by looking for reverse, then come out of reverse into first and then second. Remember that first and second is against a spring in the gearbox so you have to push against the spring. You may have to try this a few times until you get a feel for the gearbox and where the the gears are positioned.
3) Once in second gear reconnect the selector arm and push the selector rod in as deep as possible. Tighten the selector bolt.
If done correctly your gear lever will be in the second gear position when you get back in the car.
Good Luck!!
2226cc
Registered for: 21 years 2 months
Car Model: 2017 Cross Polo 1.2 TSI
Post by 2226cc »
Meh... I just let mine wear out all the bushings in the plate connected to the steering rack. Now it clicks through the gears like it's a Ferrari 328GTB! :-D click click grrrrr click click grrrr
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
King8v
Car Make: Chevy
Car Model: Sonic 1.6 LS B&W
Post by King8v »
2226cc wrote:Meh... I just let mine wear out all the bushings in the plate connected to the steering rack. Now it clicks through the gears like it's a Ferrari 328GTB! :-D click click grrrrr click click grrrr
:lol: :lol: Mechanical feel FTW!
King8v
Car Make: Chevy
Post by King8v »
goose763 wrote:Hi guys
What to do?
What a brilliant DIY guide! Shot bud :thumbup:
