ABF Alternator Bracket (Pic up new part)
- Pieta
- Car Model: 04 A4 1.8T 6spd S-Line
- Membership No: 1909
Hi all,
So after seeing Wikus's setup on the ADY he bought for the caddy I decided to get me the bracket from VW. So it arrived and it fits perfectly on the motor, but the 90 amp alternator the import engine came with does not look like it will work as it is intended to do. It misses the tensioner spring completely. Ideally I would like a 70 amp alternator does anybody know which alternator fits on this bracket and works with the spring as intended? Where to get a alternator that fits preferably in Pretoria somewhere? If someone can help me with a pic of how it should look like I will greatly appreciate it.
See on the following pic, the spring on the bottom of the bracket misses the alternator completely.
We tried everything to get it aligned, but no show.
Pieter "Pieta" Oberholzer
-04 Audi A4 B6 1.8T
BT In process
Biltein + Eibach Sportline
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- Car Model: S3, Polo Playa,
Re: ABF Alternator Bracket
you can make something to bolt onto the alternator between the two lobes that catch the spring, take a tube (pipe) with triangle plate welded to it and bolt it in between the 2 lobes, just weld a support onto it that prevent it tilting backwards when spring tension pressed against the triangle plate, did a couple of them and they works grate
- Pieta
We used the 1.4's tensioner bracket and it looks like it can work, I need a new alternator anyway, would just like to know what type of alternator works with this spring setup, the bracket was listed on the ETKA system as a direct replacement to the ABF instead of the bracket that holds the ac pump and power steering pump. I saw this bracket on Wikus's ADY and thought looks neat and simple. I haven't upgraded the 1.4's charging wire so that's why I would prefer to get a 70 amp alternator or so.vwpro wrote:you can make something to bolt onto the alternator between the two lobes that catch the spring, take a tube (pipe) with triangle plate welded to it and bolt it in between the 2 lobes, just weld a support onto it that prevent it tilting backwards when spring tension pressed against the triangle plate, did a couple of them and they works grate
Thanks for your reply, will definitely look into this if I don't get a suitable alternator.
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
I've got the exact same setup, made up a bracket to tension the belt. I used a 6PK975 belt and made the bracket to suit the belt. I'm not using the bracket in the pic anymore, it had just enough play on the ball-ends to cause vibration on the alternator, I now use an aluminium bracket.
Current rides:
Hyundai - 1.4 Getz (daily)
- Pieta
If all else fails l will have to make a plan like yours Torker. I browsed on the internet and it looks like a 1.9tdi T4 alternator. It comes with 70A charging rate, perfect. But finding one will probably now be a mission.
This looks like the exact alternator for that bracket?
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
I had that bracket and alternator at one point in time. Wouldn't it just be a Mk3 non-AC with power-steering alternator?
http://forums.vwvortex.com/showthread.p ... ator-Setup
That thread has all the part numbers you could possibly need.
Bosch 70A: AL0185X or 0-123-315-001
Bosch 90A: AL0187X or 0-123-320-002
Could try your luck with Bo$ch dealers (Diesel-Electric http://www.diesel-electric.com). They were the only ones who had a rebuild kit for the starter motor I had on the 02C box.
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
- Car Model: 18 Polo Vivo
- Membership No: 1691
Ask wikus how i made his setup work..
I used a golf 1 adjuster bracket to make it adjust and oyu need to space the alternator out abit, Let me see what alternators i got lying around, Alternativly, i can give tyou the abf bracket.
The Events Toy
Project Louise Drag Car
The Daily
Project CTi
The Daily
Project CTi
- General
Did you do the pulley mod, I've got to go through and pick one up for the GT.nd_s wrote:Ask wikus how i made his setup work..
Current rides:
- Car Model: caddy
- Membership No: 1147
i used the bracket from a polo non a/c.
If i am not mistaken that is the same bracket.dbndude wrote:i used the bracket from a polo non a/c.
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- Pieta
Hi guys,
Looks like I have found a new Bosch alternator, it will be with me tomorrow, I went everywhere today searching for the right one even Diesel Electric does not have, but went to Stargen Auto Elec here in Pretoria North, and they ordered me one.
Lets hold thumbs and hope its the right part.
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- Pieta
What is the purpose of the pulley Wikus do other than the normal one?Torker wrote:Did you do the pulley mod, I've got to go through and pick one up for the GT.nd_s wrote:Ask wikus how i made his setup work..
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- General
Check here: http://vwclub.co.za/forum/viewtopic.php ... 0#p1968840Pieta wrote:What is the purpose of the pulley Wikus do other than the normal one?Torker wrote:Did you do the pulley mod, I've got to go through and pick one up for the GT.nd_s wrote:Ask wikus how i made his setup work..
Pulley is a bit bigger so alternator turns slower, useful at high rpm to help the alternator stay in one piece, it's also got a one-way mechanism inside, when you are revving the engine the alternator turns, when you let go of the accelerator the alternator freewheels. This takes the strain off the belt and eliminates the 'belt-hop' on deceleration.
Current rides:
- Pieta
Aaah, now I see. Nic definitely needs one, after Kyalami. LOL, think it would be worthit on a stock motor as a fail safe?Torker wrote:
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- General
I think so, the brackets like we have are prone to cracking and breaking through the mounting points, I believe it's because of the belt hopping on deceleration, it can be quite violent. If you can eliminate that the bracket will last longer. The fact that it's bigger than standard is just an added benefit.Pieta wrote:Aaah, now I see. Nic definitely needs one, after Kyalami. LOL, think it would be worthit on a stock motor as a fail safe?Torker wrote:
Current rides:
- Pieta
Cool, then I need to get myself one of those as well. The plan is to do trackdays etc, so don't want alti's failing.Torker wrote:I think so, the brackets like we have are prone to cracking and breaking through the mounting points, I believe it's because of the belt hopping on deceleration, it can be quite violent. If you can eliminate that the bracket will last longer. The fact that it's bigger than standard is just an added benefit.Pieta wrote:Aaah, now I see. Nic definitely needs one, after Kyalami. LOL, think it would be worthit on a stock motor as a fail safe?Torker wrote:
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
Been afraid to drive the car cause of this.Aaah, now I see. Nic definitely needs one, after Kyalami. LOL, think it would be worthit on a stock motor as a fail safe?
Well i got one, Will let you know how it runs, Also picked up the last one for christo..Cool, then I need to get myself one of those as well. The plan is to do trackdays etc, so don't want alti's failing.
What was the part number for the alternator? and how much did it set you back?
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- Pieta
Paid R1955 incl. for a new part, fits the bracket perfectly. EA1308 is what is on the alternator and the box there are a part number 305.501.090 or CA740IR. Pic is up.nd_s wrote:Been afraid to drive the car cause of this.Aaah, now I see. Nic definitely needs one, after Kyalami. LOL, think it would be worthit on a stock motor as a fail safe?
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
Re: ABF Alternator Bracket (Pic up new part)
Is that the 70 amp version?
The Events Toy
The Daily
Project CTi
The Daily
Project CTi
- Pieta
It said 90A on the invoice. No info on the alternator itself except the numbers I posted up here.nd_s wrote:Is that the 70 amp version?
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- General
What belt do you run with this setup?
Current rides:
- Pieta
Not sure yet, need to get a belt, will let you know when I have one. LOLTorker wrote:What belt do you run with this setup?
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
- markfish888
- Car Model: B7A4 -JETTA Mk2
- Membership No: 1787
Nice set up, looks propper, exelent reference for the future!
PS:
Laat jou vrou toe dat jy olie kanne op haar eetkamer stel se stoelle sit????
PS:
- Pieta
Hahahaha, daaroor praat ons glad nie, sideshafts le in die sitkamer en daars 2 bucket seats in die huis ook nog. Dis net parte waar jy kyk. Niemand vok met my parte nie. LOLmarkfish888 wrote:Nice set up, looks propper, exelent reference for the future!
PS:
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
-04 Audi A4 B6 1.8T
BT In process
Too much to mention
- 98 Polo 6N 2.0 8v
Quick Google indicates that part number is for a brand called "Cargo". Looks like a decent unit and price.Pieta wrote: Paid R1955 incl. for a new part, fits the bracket perfectly. EA1308 is what is on the alternator and the box there are a part number 305.501.090 or CA740IR. Pic is up.
