VW505.01 VS VW507.00 (Lets put a end to confusion)
- Goldwagen Delarey
- Membership No: 1800
Re: VW505.01 VS VW507.00 (Lets put a end to confusion)
You will only get it in 1l bottles.
Sent from my GT-N7105 using Tapatalk 2
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Shell Helix Ultra Extra from VW Hatfield Bryanston. It is 507.00 and about R70/l from the dealers.Rezizter wrote:where can I get 507.00 5 liters in Pretoria or near Bryanston?
What brand is it as the helix hx7 diesel is 505.01
Is it ok for a ibizi cupra tdi?
- 4ePikanini
- Car Model: Touareg R5
castrol and shell make 507.00
Midas also sell havoline in 507.00
Goldwagen should have.
There are many HX7 shell oils. The 505.01 is the HX-7 AV one.
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
That's the one I use in my LC. You should see the petrol attendants kak themselves as they put 95 in the tank while I put prominently marked DIESEL oil in the engine.4ePikanini wrote:castrol and shell make 507.00
- Car Make: BMW
- Car Model: 135
- Membership No: 1531
Got hold of some 507 this morning at VW Hatfield (Pretoria)
5 x 1l bottles 540.20 , was surprised at how good the price was.
Castrol Edge Professional, Long Life III 5w 30
Was using hx 7 diesel (now only realising it's 505.01) that was at the last service around 8 000 km's ago. Should be interesting to see how it goes with 507 .... looking forward to fetching car from my guy after work.
Current: 2011 BMW E82 135i Alpina White - Stock
ex: 2008 Seat Cupra 1.9tdi Zenith Grey - stock
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=150579
ex:2005 Velociti 1.6i - Dark Metallic Blue (sold)
ex: 2005 Velociti1.4i - White (stolen)
ex: 95' WHITE CITI (i'll always miss you)(blew up)
I'd rather push my VW than drive an Opel
DIE HARD MK1 FAN
DIE HARD MK1 FAN
the new API SN Spec Castrol Edge 5w30 which is widely available is also a 504/507 spec oil which meets Dexos 2 as well so should be very robust.
Current - Audi TT RS
Current - VW Chico 1.4 - Track Toy
Ex - 2013 Toyota GT86 High Spec
EX - Honda Civic Type R Championship Edition
- Lazy Poes
- Car Model: Polo Gti
- Membership No: 1720
After seeing what Castrol does to the inside of an engine I will stick to shell thanks you.
- 4ePikanini
+ 1 Billion!Vinnige Fanie wrote:After seeing what Castrol does to the inside of an engine I will stick to shell thanks you.
Nothing wrong with Castrol. As i said before, the fact that these oils perform to the exact same standard and specification makes them virtually identical in performance. Thats the whole point of these certifications. 505/507 has a cleanliness limit of maximum deposit formation (as with all other certifications) which gets tested to the max in the relevant applications. So its impossible that Castrol was the cause of the sludge. Mobil or Shell would have had exactly the same issue in that engine that you are referring to.4ePikanini wrote:+ 1 Billion!Vinnige Fanie wrote:After seeing what Castrol does to the inside of an engine I will stick to shell thanks you.
The problem you saw was caused by an issue with the engine, surrounding components or neglected oil changes, NOT the oil.
I have seen countless UOA's where Castrol keeps the internals as clean as Mobil and Shell.
BMW only uses Castrol and i have never heard of a modern BMW engine sludge up.
The Veyron uses off the shelf Castrol Edge, and thats a 16 cyl quad turbo. I am pretty sure its good enough to run in our cars
Even VW recommends Castrol now as their preferred / associated oil which they partnered with. Often with these partnerships come joint development so it might be best running Castrol in your VW
- 4ePikanini
It's all about money. Castrol probably tendered the best deal.
castrol may conform to the required spec but I believe others exceed the stated spec. (just my opinion)
I used castrol in my jetta and it created sludge after 8000km. I switched to delo400 and the oil stayed golden for 6000km and the oil usage stopped.
I for one, will never, ever buy castrol engine oil again.
On the other hand, their gear oils seem to be brilliant!
which Castrol did you use before the Delo ? An oil that does NOT discolour quickly is a bad sign, that is the fact that it was still golden means the oil wasnt removing and trapping the carbon deposits the way it should (which would not be the case with an HDEO) OR there was no carbon deposits left as the Castrol cleaned it up4ePikanini wrote:It's all about money. Castrol probably tendered the best deal.
Delo is a group 2+ diesel oil aka a HDEO (Heavy Duty Engine Oil) mainly used in trucks which produce higher soot levels and rev much lower. With HDEO's, the oil discolours almost instantly due to its stronger cleaning properties. So the reason for the Delo 400 staying clean was the fact that the Castrol cleaned up all the sludge before using the Delo proving that the Castrol did a fantastic job in preventing sludge formation.
If you had to use the exact same Castrol again, the result in your oil colour would have been EXACTLY the same as with the Caltex oil.
Also, define sludge. By the sounds of things, you are confusing the fact that the oil turning black is sludge which its not. Its an indication that the engine oil is actually trapping the deposits the way its should.
Fact is, in the end, Castrol makes brilliant oils. Especially their Edge range. Any slating of the product is purely based on not understanding how engine oils work, perform and are specified.
The fact that people comment things like "Castrol sludges" could not be further from the truth and spreading such misinformation is preventing others from using a fantastic product which is actually well priced and commonly availible
- Lazy Poes
Miela,
As always thanks for the more in detail information I am sure the newer Castol is a great oil, But Ill still stick to Shell for engine oil. Gearbox oil though Castrol works really well.
No worries.Vinnige Fanie wrote:Miela,
Like i say, buy whats ever one special
- Lazy Poes
My Tdi pissed oil all over me the first time I did the change I hope this doesn't happen again
- Car Make: BMW
- Car Model: 135
Dead right. I walked into Hatfield VW gave them my vin number and they gave me Castrol.Even VW recommends Castrol now as their preferred / associated oil which they partnered with. Often with these partnerships come joint development so it might be best running Castrol in your VW
DIE HARD MK1 FAN
DIE HARD MK1 FAN
- Car Make: BMW
- Car Model: 135
Small note to add.
when running 505.01 when flooring it, there was plenty of black smoke behind me ... now with 507, only get small bursts of smoke, seems to leave a little cloud in the background.
Performance and economy seems identical though
DIE HARD MK1 FAN
DIE HARD MK1 FAN
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
Rezizter wrote:Small note to add.
So Miela was correct. As mentioned previously, I am not worried about deposits from burn off as we have seen that TDI engine ports do not get that dirty (see Carbon doctor...). I am more worried about acid and sludge as this diminishes the protective properties of the oil....Miela wrote:
So, is 507 better than 505.01, not really. In 507 you will have less deposits from burn off, but in 505.01 you should have more acid / sludge fighting additives.
Hope this helps
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- Registered for: 21 years 4 months
VW MK7 GTI DSG. White.
MB C200 Avantgarde A. Palladium Silver.
Ex's
2006Mk5 Jetta 2.0 TFSI DSG. Silver
2002Mk4 Gti. Silver
2008 MB C180k Avantgarde A. Silver
2011 6R Polo Gti. Silver.
2005 9N TDI Sportline. White
2001 MK4 GTI. Black. Sunroof.
1996 MK3 GTI. White. S3 wheels.
2000 MK4 2.0 Highline.GTI Wheels.
1991 MK2 GTI. White. (Best car owned ever)
1991 MK1 CTI. White. Momo EVO1's
Ex's
2002Mk4 Gti. Silver
- Car Make: Nike
Sorry
Sorry
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
- 4ePikanini
I understand the way oil works.Miela wrote:which Castrol did you use before the Delo ? An oil that does NOT discolour quickly is a bad sign, that is the fact that it was still golden means the oil wasnt removing and trapping the carbon deposits the way it should (which would not be the case with an HDEO) OR there was no carbon deposits left as the Castrol cleaned it up4ePikanini wrote:It's all about money. Castrol probably tendered the best deal.
I did three changes on castrol. All three times there was tar like substances under the tappet cover.
Switched to delo 400 and 3 changes later the oil remained golden and underneath the tappet cover it was clean. I did about 6 changes on delo 400 and when I removed the sump to fix a nagging oil leak since purchase the engine was spotless.
This was after about 6 changes of delo 400 (316'000km on the odo)
This was my pajero under the tappet cover after 60'000km on delo400. This picture was taken 1000km after oil change
507.00 is the required spec for all VW/Audi diesels except pre-DPF touareg R5/V10.
Castrol can't be that bad to get VW's approval but I'm not a fan due to personal experience. My personal experience is in no way a large test data criteria.
Only thing I would really push for is that whatever oil you use, change it every 10'000km.
- JVA
- Car Model: A4 B8 3.0Tdi
How does Liqui Moly TopTec 4200 Longlife compare to Castrol or Shell? I can't find either of the latter in Bloem but can get Liqui Moly 5L for under R500
- 4ePikanini
Liqui is probably on par or better than shell.
Im not a castrol fan.
Sent from my iPad 2
Sent from my iPad 2
- Goldwagen Delarey
+14ePikanini wrote:Liqui is probably on par or better than shell.
Sent from my iPad 2
Helix ultra extra 507 meets and surpasses 505.01 specs so it basically supercedes it. We'll probably see the oil companies supercede it in the future. It does smoke less as it a low ash oil.
- Car Model: Jetta 5 1.9tdi, Touran 1.9tdi
Can anyone suggest a place in Cape Town with a good variety of oils to look at and choose from?
Need some oil for my Jetta. It has got the BXE 1.9 tdi engine.
I've used Castrol edge in the wifes jetta 4 tdi and at 248 000km the car used absolutely no oil at all (and without any sludge at any time
)... even after hitting a kudu it still didn't use oil...
Will it be better to pay the extra money and get the 507 spec edge professional?
I'm curious though about the shell helix who some people seem to swear by. Maybe I should try it and see if it makes any difference to the car. Can anyone give some details about the specific Helix to use in the 1.9 PD?
Any feedback will be appreciated, I realize I'm a bit of a hijacker but since it's on more or less the same topic I hope I'll be forgiven...
