shaved engine bay - mk1
- Voora Molester
so do i use body filler? im thinking it will crack after a few hard launches....
need some help, would like to remove the brake booster, water bottle and the wire-tuck im sure i can hide... battery in the boot shouldn't be a problem as well....
this is not for a daily driver however i should be able to sit in peak winter traffic with the car...
edit: im not talking this =
Thupercharged S4
- PoLonY
- Car Model: A8
- Membership No: 1997
Re: shaved engine bay - mk1
why not do it like the pic?
key is to weld up as much as possible so only a tiny amount of bodyfiller is needed
- General
- Car Model: Golf GT
- Membership No: 1464
This is what I did in my GT, all the things you mentioned except the wiring I neatened up but didn't hide..
Current rides:
Hyundai - 1.4 Getz (daily)
- Voora Molester
yesterday i moved the catch can over to the right under the battery tray to hide it, i will upload pics of the engine bay as it stands after i had a work around with it the weekend.
@polony- that is too much work and i fear once i get stuck into it, its gonna take too long to complete...
also plating vs high polished... need pro's vs cons... i always had my stuff high polished and it turns out nice, but to maintain it was a beeech... never done plating..
Thupercharged S4
- PoLonY
- Car Model: A8
- Voora Molester
what you talking about?PoLonY wrote:Are you referring to me when you say Wouter?
Thupercharged S4
- PoLonY
- Car Model: A8
yakuza racer wrote:what you talking about?PoLonY wrote:Are you referring to me when you say Wouter?
- span die seile
- Membership No: 1746
Huh? What did I miss?PoLonY wrote:Are you referring to me when you say Wouter?
I spoke to a buddy and he is not shaving due to long term problems, but he is going to drive it daily. Dunno what it all entails though.
- Neuk
- Treasurer
- Membership No: 806
I have never done it but have heard it is a real ball ache to do properly, welding in plates, smoothing down weld lines, using as little filler as possible, relocating bits and pieces and hiding wiring...
- Voora Molester
hiding the wiring is not that hard, battery in the boot aint a ball ache, its the water bottle and extra bits (firewall) which im worried about....Neuk wrote:I have never done it but have heard it is a real ball ache to do properly, welding in plates, smoothing down weld lines, using as little filler as possible, relocating bits and pieces and hiding wiring...
i am going to have to spray the car over anyways, so i will start with the reloca battery in the boot first and remove the plate infront, tidy some wiring etc... i already done some work over the long weekend
Thupercharged S4
- Neuk
- Treasurer
Yeah, relocating and hiding isn't too hrd a job, time consuming though but all the welding, filling, smoothing, **** me that is a job...yakuza racer wrote:hiding the wiring is not that hard, battery in the boot aint a ball ache, its the water bottle and extra bits (firewall) which im worried about....Neuk wrote:I have never done it but have heard it is a real ball ache to do properly, welding in plates, smoothing down weld lines, using as little filler as possible, relocating bits and pieces and hiding wiring...
- Voora Molester
this is how the bay currently looks
now i need to get all that wires and crap out of sight... also its kinda dirty, but clean for a car that was standing for a year lol
Thupercharged S4
- PoLonY
- Car Model: A8
for the water bottle etc, you change the radiator for one with a built in overflow and coolant cap and tuck it under the slam panel
battery in boot as said, wires extended and running in frame rails etc
remove all the seam sealer, weld up grind flat, body filler
grind off all unnecessary brackets etc etc etc
- Car Make: Chevy
- Car Model: Sonic 1.6 LS B&W
Man thats a
Thats a shite loada work!!PoLonY wrote:for the water bottle etc, you change the radiator for one with a built in overflow and coolant cap and tuck it under the slam panel
- PoLonY
- Car Model: A8
well either do it right first time or you'll wish you had...
- Car Make: Chevy
true, as with anything i suppose.
- Voora Molester
the work shall begin tonight or tomorrow or the weekend lolPoLonY wrote:for the water bottle etc, you change the radiator for one with a built in overflow and coolant cap and tuck it under the slam panel
Thupercharged S4
- Car Make: Chevy
whichever is most applicable
- Car Model: caddy
- Membership No: 1147
i'm not sure if you can see much here.
we used 1mm cold roll steel to cover up as much as we could.
then a thin layer of filler..
not totally smooth as such, but covered up over chassis legs, holes etc.
battery in the bin.
and wiring went in through here
battery in the bin.
- PoLonY
- Car Model: A8
- Neuk
- Treasurer
+1PoLonY wrote:makes a massive difference, good job!
I have seen guys overseas hide or relocate a lot of things and then make fibreglass covers that they can fit and remove when necessary. Saves them from welding and grinding and filling...
- Voora Molester
that is EPIC!
thanks for the tips!
gonna start to get stuck in after payday
Thupercharged S4
- smoothscott
- Car Make: Honduh!
- Car Model: 'Lard
While not VW...but you can learn a few things from these shaved Honda bays as they have MUCH more to hide and relocate than the MK1 VW variants.
http://honda-tech.com/showthread.php?t=1693934&page=2
- Voora Molester
uhm....... 1000+ page thread.... 0_osmoothscott wrote:While not VW...but you can learn a few things from these shaved Honda bays as they have MUCH more to hide and relocate than the MK1 VW variants.
thanks man! looking for a DIY thread on a mk1 to follow through step by step
Thupercharged S4
- Ian F's special snugglebunny
- Car Model: Caddy
- Membership No: 1548
Curiosity has got the better of me, why do the fuel lines come in on the right hand side of the motor?
Normal Citi's/MK1's have the steel lines coming in from the left hand side of the motor.
This is standing with the bonnet open infront of the motor obviously.
