Polo 9n3 Engine Conversion 150kw
B_rad
Registered for: 12 years
Car Model: Fiesta ST180
Membership No: 1835
Re: Polo 9n3 Engine Conversion 150kw
Post by B_rad »
Demon Tweaked wrote:turbo charging an NA car has been done many times. Its not uncommon either however he asked how does he get 150wkw from a polo 1.6i with 30k. that is a different story altogether.
Youre one hundred percent correct. If i look through your thread you clearly know your stuff. 30k is too little for all that has to be done properly perhaps.
But i bet people said why not buy an m3 and work from there if you wanna slap amgs and m3's etc.
Driving one of the fastest ibizas around must be farking epic. Thats probably the same reason he wants to go turbo... for the thrill of the build and for making something yourself...
All im saying is there is tons of knowlege to be had, why not just share it with him :)
Blade
Car Make: Polo
Post by Blade »
Ok here's a idea if u really in it for the thrill. Dunno if it will work though.
See if you can squeeze a G5 motor in there do some mods to make it fit then throw in a polo gti gearbox, pgti breaks, petrol pump and exhaust and u might be on your way.
Shaheem
Polo 6, 1.4 Comfortline
mika1803
Car Model: 07 PGTI
Membership No: 3089
Post by mika1803 »
Find a written off G4/pgti, then transplant everything, or stay n/a and strip all extras. It won't get the power, but u will feel the speed
Some people are wise, then some are just other-wise
08 Audi A4 2.0 tfsi S-line
Ex:07 Merc E63 AMG
Ex:11 6R PGTI
Ex:10 Silver Leaf Jetta 2.0 TSI-K04
Ex:12 Brilliant silver Jetta TSI comfortline, 9j 18 inch BBS wheels,custom intake, eibach
Ex: 07 Flash Red Polo Gti, stage 1 revo software, 63 mm downpipe, custom intake,G4 GTi.:R wheels,boost gauge
Ex: Alfa Romeo 156 2.5 v6 24v, intake, de-cat exhaust, GTA wheels
Ex: Tazz 130, Rsi wheels, some sound,
Florida, Woes Rand
B_rad
Membership No: 1835
Post by B_rad »
Blade wrote:Ok here's a idea if u really in it for the thrill. Dunno if it will work though.
Imagine if you could do that :crazy: It would fly!
Blade
Car Make: Polo
Post by Blade »
And maybe stil VAG it afterwards
Shaheem
FuDu
Car Model: polo 9n3 Sportline
Post by FuDu »
I think this guys aim is achievable.
HOWEVER, not a turbo conversion.
An abf motor with throttles and tuning should cost about 20k.
It would definitely be better to buy a gti but for some reason if the guy really wants to build something it's should be an interesting build. The chap will still have change for brakes and a clutch.
polo 1.9tdi
Gt2056
OREO
Registered for: 13 years 9 months
Membership No: 1604
Post by OREO »
Just sit back and enjoy the show :)
Matty2.0
Registered for: 11 years 7 months
Car Model: Polo 2.0
Post by Matty2.0 »
Respect for trying to be different man!
As seen in the second video that SemiColon posted, they were able to get 195Horses out of that 1.6 with the Nascarchips turbo conversion.. I don't know whats going on though because its all in Portuguese :grin: But at least we all know its possible to get 195HP (Which should be 140 odd KW) out of a 1.6! The only problem is, I have no idea how much it would cost you, what turbo you need and where you can get it done :twisted: I have tried researching Polo2.0 Turbo conversions for interest sake and all I found was one video! Perhaps you will have to try things the old fashion way and use email :grin: I like the idea of the sleeper tho!
Matty2.0
Car Model: Polo 2.0
Post by Matty2.0 »
Although! As some have said, the reliability won't be great or at least not as great as a car that comes stock with a turbo :smile: Good luck with this though! :smile:
the HP aim is not impossible. I have had a couple of close to 190 hp unos over my dyno and that is only a little 1.4 8v. So yes totally possible. BUT this is the kicker. You do not find any aftermarket tuning bits for THAT engine ie. not readily available CR drop pistons, not a readily cast manifold etc.etc. so you WILL have to custom make EVRYTHING. you will have to trial and error with pistons to get the CR down etc etc. So yes no problem on the Can it be done part. The problem is the R30k bit. That little affair will run you much much closer to R60k. N/A there is absolutelty no way you'll take that engine there.
graham savage
Membership No: 803
Post by graham savage »
I would keep it as a daily and buy a ready built mk1 turbo like Chris is selling that you can play with
vintagius
Car Model: POLO 9n4 2020 Model
Post by vintagius »
Where can i get the 1.8T engine for the polo9n3 and how much
Srapyard like 4springs in terrace raod edenvale or import shops like japan auto trading or boston or the likes. Or look on the board here. They sometimes come up.
SemiColon
I sparkle in the sunlight
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Post by SemiColon »
And prepare to pay R15k+ for the engine.
八拾六
bennit
Car Make: Audi, VW
Car Model: B8 3.2 fsi quattro, 9n3 1.6
Post by bennit »
Guys so if he does get hold of the motor, fitting it i dont think it will be a problem, but running the motor is it easy? or an after market management system is required? *just interested*
[img][IMG]http://i1033.photobucket.com/albums/a41 ... d945c6.jpg[/img][/img]
ACCIDENTS HAPPENS AT 100KM/H
Aftermarket.. Getting all the oe bits together will cost you as much as the engine.
viceroy
Registered for: 20 years 6 months
Car Model: 2013 S4 quattro
Post by viceroy »
If I may offer some advice.
Trade in the 1.6 on a PGTI.
Remove GTI badging and replace with 1.6 badging.
Will be the best mod you ever did.
ps. Listen to the guys telling to not try modding the 1.6 to turbo, they know what they are talking about.
2013 Audi S4 quattro
2021 VW T-Cross 1.5 (wifes)
2015 BMW M235i
2015 BMW 228i
2013 Audi S6 quattro
2014 Audi A4 2.0TDI allroad (wifes)
2013 Audi A3 1.4T (wifes)
2013 Audi A5 3.0T
2010 Audi S4 quattro 6MT
2007 Audi A3 2.0T 6MT (wifes)
2009 Audi A4 3.0 TDI quattro
2010 Audi TT Coupe 2.0T
2008 Audi A4 2.0T S-line
2005 Audi A3 3.2 quattro 6MT
2005 VW Polo 2.0 Highline
2001 Renaultsport Clio 2.0 16V
2001 Renault Clio 1.4 16V
1999 Opel Corsa 1.6s
1993 VW Citi Golf SPORT 1.8
Balls
Membership No: 1708
Post by Balls »
Think a 911T motor in the boot is a better idea, then you can convert it to RWD, the drivetrain from a Beetle should bolt right into the Polo with no modifications :driving:
AlexTDi
Car Model: '15 Polo GTI
Membership No: 1724
Post by AlexTDi »
240mm disks and drums at the back? :lol: :lol: :lol: :lol:
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Stompie
Boostleak Guru
Car Model: 2006 120D
Membership No: 1843
Post by Stompie »
1.9TurboVw wrote:240mm disks and drums at the back? :lol: :lol: :lol: :lol:
Stopping power......This is going to have it!! :grin:
BMW 120D E87
