Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK !!!
Replacement parts suitable for: VW ~ Audi ~ Seat ~ Opel ~ BMW ~ Mini ~ Mercedes Benz
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper » Sat Dec 01, 2012 9:17 am
There have been some questions in the wanted section for ABF flywheels and i think i have come up with a solution!
We have a clutch kit on the shelf here (made by Valeo) that replace the duel mass of the VW golf 4,A3 and polo 9N 1.8t with a solid mass flywheel (ABF) and use a vr6 2.8 clutch on that.
Size:
Od of ring gear 281mm
thickness of flywheel 43mm
Clutch plate size 228mm
We sell the compete kit for R4960.00 (flywheel, pressure plate, clutch plate + thrust bearing)
boost'd
Criminal Troll.
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 vr6 ? AVAILAB
Post by boost'd » Sun Dec 02, 2012 9:09 pm
As far as I know it's the AbF flywheel and VR6 clutch
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper » Mon Dec 03, 2012 9:26 am
boost'd wrote:As far as I know it's the AbF flywheel and VR6 clutch
What is the difference between ABF and AAA flywheel's?
Digit Riaan
Post by Digit Riaan » Mon Dec 03, 2012 10:01 am
The crank bolt pattern.
His: '05 WRX STi, '98 356 Speedster Rep, '76 Dodge D100 383, '79 Golf LS
Hers: '10 Mitsubishi Outlander
Car Make: VW, VW, Aprilia
Car Model: VR6, Caddy, RSV4
Post by Jetta2 » Mon Dec 03, 2012 10:33 am
ABF flywheel will have 6 bolt holes like the one in your pic, the VR flywheel will have 9 holes.
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper » Mon Dec 03, 2012 10:52 am
So this will work on 4cyl crank shaft and cable shift/ hydraulic gearbox setup?
Viper
Goldwagen Delarey
Membership No: 1800
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF OUT OF S
Post by Viper » Thu Jan 17, 2013 11:33 am
Pynoxim wrote:When these are eventually in stock, would they fit a Mk4 with a 6 Speed Gearbox as I've heard that there are differences between the 5 Speed and 6 Speed Gearboxes.
NO sorry mr it will not fit. I do not know if there is a solid mass conversion foe the 6 sp. I know we can order aluminium flywheel and racing clutch kit from the uk, but it is not cheap (about 15k)
Viper
Goldwagen Delarey
Membership No: 1800
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK
Post by Viper » Tue Apr 16, 2013 8:55 am
Hi every one !!
The Valeo kits with the solid mas flywheel for the 1.8t 5sp boxes is back in stock again!
Post by Dougi » Tue Apr 16, 2013 8:57 am
how will this kit work on the TDIs?
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper » Tue Apr 16, 2013 9:18 am
Dougi wrote:how will this kit work on the TDIs?
Nee mr it will not work. TDI sport line is 6sp Sorry :oops:
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked » Tue Apr 16, 2013 9:32 am
Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
1992 Golf Mk2 VR6
2018 Golf Mk7.5 R
Stompie
Boostleak Guru
Car Model: 2006 120D
Membership No: 1843
Post by Stompie » Tue Apr 16, 2013 9:34 am
That is a awesome price for the whole kit wikus! now i know who to come see when mine decides to fail!
BMW 120D E87
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper » Tue Apr 16, 2013 10:02 am
VWicked wrote:Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
The one that fits this flywheel is the vr6 type R1157.00
The 2.0 16v once is in the process of being discontinued and they are R1112.00
VWicked
Membership No: 1492
Post by VWicked » Tue Apr 16, 2013 10:03 am
Hmm what is difference in design between vr6 and mk2 16v? My car would have the same flywheel like an ABF
1992 Golf Mk2 VR6
2018 Golf Mk7.5 R
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper » Tue Apr 16, 2013 10:09 am
I will check and come back to you!
Sheldon123
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK !!!
Post by Sheldon123 » Fri Feb 24, 2017 11:06 pm
Hi any ABF / G60 spec flywheels for sale? Which other flywheels would fit? Any help would be greatly appreciated. Thanks Sheldon 0612916242 based in Gauteng
Breadroll
Car Model: A3 1.8T
Membership No: 1989
Post by Breadroll » Mon Feb 27, 2017 9:33 am
Sheldon123 wrote:Hi any ABF / G60 spec flywheels for sale? Which other flywheels would fit? Any help would be greatly appreciated. Thanks Sheldon 0612916242 based in Gauteng
Hey bud please have a look at this thread. My whatsapp number is 0787325682 if you want to chat on there.
http://www.vwclub.co.za/forum/viewtopic ... 5&t=203017
