Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK !!!
Replacement parts suitable for: VW ~ Audi ~ Seat ~ Opel ~ BMW ~ Mini ~ Mercedes Benz
Viper
Goldwagen Delarey
Registered for: 14 years 4 months
Membership No: 1800
Post by Viper »
There have been some questions in the wanted section for ABF flywheels and i think i have come up with a solution!
We have a clutch kit on the shelf here (made by Valeo) that replace the duel mass of the VW golf 4,A3 and polo 9N 1.8t with a solid mass flywheel (ABF) and use a vr6 2.8 clutch on that.
Size:
Od of ring gear 281mm
thickness of flywheel 43mm
Clutch plate size 228mm
We sell the compete kit for R4960.00 (flywheel, pressure plate, clutch plate + thrust bearing)
boost'd
Criminal Troll.
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 vr6 ? AVAILAB
Post by boost'd »
As far as I know it's the AbF flywheel and VR6 clutch
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
boost'd wrote:As far as I know it's the AbF flywheel and VR6 clutch
What is the difference between ABF and AAA flywheel's?
Digit Riaan
Registered for: 19 years 11 months
Post by Digit Riaan »
The crank bolt pattern.
Car Make: VW, duh...
Car Model: Stuff
Post by Jetta2 »
ABF flywheel will have 6 bolt holes like the one in your pic, the VR flywheel will have 9 holes.
2012 Suzuki Hayabusa
2021 Aprilia RS660
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
So this will work on 4cyl crank shaft and cable shift/ hydraulic gearbox setup?
Viper
Goldwagen Delarey
Membership No: 1800
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF OUT OF S
Post by Viper »
Pynoxim wrote:When these are eventually in stock, would they fit a Mk4 with a 6 Speed Gearbox as I've heard that there are differences between the 5 Speed and 6 Speed Gearboxes.
NO sorry mr it will not fit. I do not know if there is a solid mass conversion foe the 6 sp. I know we can order aluminium flywheel and racing clutch kit from the uk, but it is not cheap (about 15k)
Viper
Goldwagen Delarey
Membership No: 1800
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK
Post by Viper »
Hi every one !!
The Valeo kits with the solid mas flywheel for the 1.8t 5sp boxes is back in stock again!
Post by Dougi »
how will this kit work on the TDIs?
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
Dougi wrote:how will this kit work on the TDIs?
Nee mr it will not work. TDI sport line is 6sp Sorry :oops:
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked »
Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
1992 Golf Mk2 GTi R32
2011 Golf Mk6 R
2010 Touareg V6 TDi
Stompie
Boostleak Guru
Car Model: 2006 120D
Membership No: 1843
Post by Stompie »
That is a awesome price for the whole kit wikus! now i know who to come see when mine decides to fail!
BMW 120D E87
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
VWicked wrote:Clutch kit only, how much? Mk2 GTi 16v Cable Shift.
The one that fits this flywheel is the vr6 type R1157.00
The 2.0 16v once is in the process of being discontinued and they are R1112.00
VWicked
Membership No: 1492
Post by VWicked »
Hmm what is difference in design between vr6 and mk2 16v? My car would have the same flywheel like an ABF
2011 Golf Mk6 R
2010 Touareg V6 TDi
Viper
Goldwagen Delarey
Membership No: 1800
Post by Viper »
I will check and come back to you!
Sheldon123
Re: Solidmas flywheel for Mk4+A3+9N 1.8t + mk3 ABF IN STOCK !!!
Post by Sheldon123 »
Hi any ABF / G60 spec flywheels for sale? Which other flywheels would fit? Any help would be greatly appreciated. Thanks Sheldon 0612916242 based in Gauteng
Breadroll
Registered for: 14 years 5 months
Car Model: A3 1.8T
Membership No: 1989
Post by Breadroll »
Sheldon123 wrote:Hi any ABF / G60 spec flywheels for sale? Which other flywheels would fit? Any help would be greatly appreciated. Thanks Sheldon 0612916242 based in Gauteng
Hey bud please have a look at this thread. My whatsapp number is 0787325682 if you want to chat on there.
http://www.vwclub.co.za/forum/viewtopic ... 5&t=203017
ChadGeeTeeEye
Post by ChadGeeTeeEye »
Hi. Do you still sell this kit? Thanks
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner »
ChadGeeTeeEye wrote:Hi. Do you still sell this kit? Thanks
Call the boys at DRD in Roodepoort and ask, this thread is old.
