272 vs 276
- Car Model: Polo classic
272 vs 276
hi im going for a cam in my 2l 8valve which one would be best preferred as i use my car daily?
I know this is always a debated topic and if i go for 272 can i keep my own vernier or should i get a other venier?
- Lazy Poes
- Car Model: Polo Gti
- Membership No: 1720
Re: 272 vs 276
Hi Bud do you have a Piggyback or Unichip of some sort?Classic8 wrote:hi im going for a cam in my 2l 8valve which one would be best preferred as i use my car daily?
- phillip
- Registered for: 14 years
- Car Make: Ford
- Car Model: 225 ST
Re: 272 vs 276
You can use a 298 cam in your daily, been asked plenty on the forum.
Its all how much you want and can handle, for some guys 276 is too much but others a 288 is still not enough.
I ran a 288 in my 2l 8v and i loved it, if i could go back i would put a 298.
Like fanie asked, do you have a piggy back system, management? if not fueling might be a problem.
But if it was my choice 276 minimum.. 272 is for a 1400
EX
City.Com ABF
Focus ST 225
City.Com ABF
Focus ST 225
- Car Make: Ford
- Car Model: Focus ST250
Re: 272 vs 276
hey bud...
just had my 276 removed from my 2.0l 8v....
it was very nice and smooth, with a slight of beat idol..
but change back to a G-cam...its perfect for everyday use. got loads of torque from right at the bottom and is very very smooth.
only other mods is a gotech Mini-X, and a 57mm exhaust not even a branch. made 83wkw yesterday...
198.9wkw and 526nm @ KAR
- Lord of the Sponge
- Membership No: 1676
Re: 272 vs 276
and I went the other way..... bwahahahaahaaaa.... from a 276 to a 288 and am already considering a 298Dono82 wrote:hey bud...
TBH I would not run anything less than a 276
- Car Model: 2004 Chico under construction
- Membership No: 1820
Re: 272 vs 276
OP does not state capacity
Re: 272 vs 276
ACiD_Omega wrote:OP does not state capacity
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Re: 272 vs 276
Acid, it says 2.0 8v
For daily i would go 276 as its a mix between power and fuel consumption. I had a 288 in my car but it drank loads more fuel. Bottom end is also severly affected but that didn't bother me as I do not short shift my car.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
Re: 272 vs 276
ooops, sorry, I missed that completely
- General
- Car Model: Golf GT
- Membership No: 1464
Re: 272 vs 276
Depends what you can live with - I've seen guys pull 276's out of 2.0 engines because they could not handle the lumpiness, I consider a 276 just about stock and grew bored with it in a couple of months...
Current rides:
Hyundai - 1.4 Getz (daily)
- VWicked
Re: 272 vs 276
agree, 276 should be the stock cam on 2.0. on my cti, it was smooth with the 276, no lumpynessTorker wrote:Depends what you can live with - I've seen guys pull 276's out of 2.0 engines because they could not handle the lumpiness, I consider a 276 just about stock and grew bored with it in a couple of months...
Re: 272 vs 276
Ok so i guess its then going to be the 276 cam. It sounds great and i can see the excitement with the 276. is it nessesary for head work with the 276 or can i run it as is and will i need a other vernier pulley or must i use standard vernier pulley?
Re: 272 vs 276
I'm unsure that you know exactly what a vernier pulley is but yes you can use the standard timing pulley that the car comes with.
- Psycho8v
- Car Make: Toyota
- Car Model: Corolla Quest 1.6
- Membership No: 1881
Re: 272 vs 276
Sorry for the hijack. But I think this can be relevant information to the OP as well.
Alot of people say that the 276 is a nice smooth cam for a 2.0 8v, what about the 282 cam? How does that compare to the 276 as an everyday cam. Is there a big difference in fuel consumption? (i know it's got alot to do with controlling your right foot) How is the power delivery? Any info will be great.
- General
Re: 272 vs 276
I don't think the choice of cam plays that big a factor in consumption, all the variants I had - 276 in 2.0, 288 in 2.0, 298 in 2.0, 298 in 2.1(hydro) and now 300 in 2.1(solid) had basically the same consumption, around 10l/100km, my driving style is pretty consistant but if you are hooning it all the time the consumption will cetainly suffer.
Current rides:
- Crawler
- Car Model: 9N3 Polo TDi
- Membership No: 1358
Re: 272 vs 276
Wow torker you been through the range
CW Polo TDi Sportline
- General
Re: 272 vs 276
LOL, I think I finally hit the sweet spot in terms of performance with the last one, but that said, I've still got a 316 solid lifter cam in my cupboard...crawler wrote:Wow torker you been through the range
Current rides:
- Major-General
- Car Model: MK1
Re: 272 vs 276
I've had all sorts of combos on 8V's and 16V's. 276 is the bare minimum on a 2.0, in fact its nice on an 1800 and 288 on a 2.0 is better as its got more low end torque. I've driven 8v and 16v with 288's in traffic, no issues, also didn't notice any consumption differences from 276. If you can't handle a 288 in traffic, you a learner driver.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
- Psycho8v
- Car Make: Toyota
Re: 272 vs 276
Thanks alot Christo. This is actually good to know, as my arse is itching for the 282 cam.Torker wrote:I don't think the choice of cam plays that big a factor in consumption, all the variants I had - 276 in 2.0, 288 in 2.0, 298 in 2.0, 298 in 2.1(hydro) and now 300 in 2.1(solid) had basically the same consumption, around 10l/100km, my driving style is pretty consistant but if you are hooning it all the time the consumption will cetainly suffer.
Oh my word, I friggin' hosed myself!Zubair wrote:If you can't handle a 288 in traffic, you a learner driver.
- VWicked
Re: 272 vs 276
perhaps my consumption is related to my management of lack of management. With the 288 on the 276 tune the AFR's were lean around 15 or so, so Stephan had to add more fuel to protect the car from itself.
That in mind though, cruising at 120km/h the car chows the same amount of fuel on all the cams i have (Stock, 268, 276 and 288) the onbly difference is when the car idles in traffic that the 288 used to drink.
Re: 272 vs 276
Hi car koppe i just recentlt got me a mrk4 1.6 sr uhm what type of cam is suitable for it and everyday use...
Need help im new at this
- ADZ
- Car Model: Mk2 GTI 16v
Re: 272 vs 276
Hey Psycho8v I've got a 282 cam in my citi with an ADY motor runs absolutely smooth no jerking no hesitation you can pull off and cruise at 1000rpm with no issues, in terms of power it comes in from around 3800rpm and drops of around 6400rpm I'm still running mp9. Fuel consumption is excellent I get around 13 to 13.5km per lt if I drive nicely lol but if I floor it then it drops to around 11km/lt.Psycho8v wrote:Sorry for the hijack. But I think this can be relevant information to the OP as well.
Its a good cam for a 2lt, I recently bought a mk2 with a 2e motor running dictator on that one I will go for either the 288 or 298.
02' citi 2L 8v
04' Mk4 Jetta 2L
89' Mk2 1.8 16v GTi
72' Beetle 1600TP
Re: 272 vs 276
There are very few places that makes a cam for that engine. There are actually very few performance upgrades for that engine.
- Shadows101Fall
Re: 272 vs 276
Mother of thread Resurrection. Why not go dig up your great grandma while your at it.Chadsta wrote:Hi car koppe i just recentlt got me a mrk4 1.6 sr uhm what type of cam is suitable for it and everyday use...
- Car Model: CitiRox 1.4i
Re: 272 vs 276
Shadows101Fall wrote:Mother of thread Resurrection. Why not go dig up your great grandma while your at it.Chadsta wrote:Hi car koppe i just recentlt got me a mrk4 1.6 sr uhm what type of cam is suitable for it and everyday use...
Lol im so glad someone opened up this can of worms I too have a cam question as I would like to add one to my 1.4i, I read many of the older posts and from what I can gather for a 1.4i standard motor with just exhaust (branch and 50mm freeflow) and K+N flatbed the options are:
268 - best for daily, bottom end torq focus and least lumpiness.
272 - middle ground with balance of either and some lumpiness.
276 - biggest (reasonably) for 1.4i stock motor with most lumpiness and least bottom end torq.
Then the decent brands (well I think) is estas and ***, estas being the sort after (their website seems down I sent a PM to nellis and waiting on pricing). *** came back with this package which seems decent price wise... http://***.co.za/camshaft-shop-online/3 ... -38-detail
Any advise and thoughts that I should look out for or in going this road? Lifter Set & Vernier Pulley? etc etc
