Missfire when starting? 2l 16v Turbo
16v Turbo
Car Make: Suzuki
Car Model: 2010 GSX-R 600 Limited Edition
Membership No: 1896
Post by 16v Turbo »
Can someone please help with the following, when I start my car in the mornings it sound like it's got a missfire between 1000 - 3000 rpm, can it be the cold start setting on my dicktator 60-2?
When it's hot it idles perfect and no problems
CURRENT RIDE:
2010 Suzuki GSX-R 600 Limited Edition - 600cc
EX RIDES:
1981 VW Golf MK1 2 Door - 2l 16v ABF Turbo
2007 Honda Civic Type R - 2l 16v I-VTEC
2004 Renault Megane Sport - 2l 16v Turbo
2003 Renault Clio Sport - 2l 16v
1997 Uno Turbo - 1.4l Turbo
Image Image Image Image Image
Wit Ark
Car Model: Citi Chico baby dragster
Re: Missfire when starting? 2l 16v Turbo
Post by Wit Ark »
I am taking a shot in the dark here but sounds more like a fueling issue during cold start, maybe check your water temp sender unit first? I had a similar problem a while back, turned out to be the electronic sensor thingi in the dizzy, but you running 60-2 so thats irrelevant. hope you get it sorted. cheerz
16v Turbo
Car Make: Suzuki
Membership No: 1896
Post by 16v Turbo »
Wit Ark wrote:I am taking a shot in the dark here but sounds more like a fueling issue during cold start, maybe check your water temp sender unit first? I had a similar problem a while back, turned out to be the electronic sensor thingi in the dizzy, but you running 60-2 so thats irrelevant. hope you get it sorted. cheerz
It can also be a sensor, will you be able to pick it up on your laptop when you connect the dictator?
CURRENT RIDE:
EX RIDES:
Registered for: 22 years 10 months
Yes if you know what to look at.
16v Turbo
Car Make: Suzuki
Membership No: 1896
Post by 16v Turbo »
panic-mechanic wrote:Yes if you know what to look at.
Wish you were closer to me but Benoni is a bit far from Krugersdorp?
Do you know anyone this side that knows alot about golfs?
CURRENT RIDE:
EX RIDES:
M3THANOL
Blue Bomber
Registered for: 13 years
Car Model: Golf Mk2...now....2.0L 8V AGG
Membership No: 1822
Post by M3THANOL »
Shaun Du Preez that used to own SRD (Shauns Racing Developments), he specialised in Dictator. I know he sold his business but if you can get hold of him maybe he can point you in the right direction
I'm literally can't evening!
http://www.iamsecond.com/
Current: The Blue Bomber
1km: 165km/h (ODI-2013/10/27)
16v Turbo
Car Make: Suzuki
Membership No: 1896
Post by 16v Turbo »
I spoke to him but he don't have the dyno or laptop for dicktator anymore
CURRENT RIDE:
EX RIDES:
About golfs yes not sure about management. Also no sure if they still operating. Anthony Taylor
graham savage
Membership No: 803
Post by graham savage »
Sounds too rich on cold start, probably fouling up a plug
