Software MAP differences DSG vs Manual ?
Hi All
I have heard that there are differences between a map for a manual and a map for a dsg. I have read that there are additional parameters that need to be accounted for when flashing a dsg that don't come into effect on a manual map
Is this true ?
Sent from my BlackBerry using Tapatalk
Is this true ?
G5 DSG
Re: Software MAP differences DSG vs Manual ?
Anyone?Wazza wrote:Hi All
Is this true ?
G5 DSG
- Burner1144
I'm also interested in this... Does the dsg ecu also need tweaking and can it handle a software upgrade without failing due to the
added torque?
added torque?
2005 Subaru STi
2005 Golf 5 GTi
2004 Golf 4 GTi R
2002 Golf 4 GTi
2005 Subaru STi
2005 Golf 5 GTi
2004 Golf 4 GTi R
2002 Golf 4 GTi
Howzit budBurner1144 wrote:I'm also interested in this... Does the dsg ecu also need tweaking and can it handle a software upgrade without failing due to the
added torque?
I'm not talking about DSG ecu flashing I am refering to performance maps for the engine ECU that incorporate additional parameters in the MAP for DSG integration that do not exist on MAPS that are used on manual gearbox cars
G5 DSG
- Major-General
- Registered for: 22 years 3 months
- Car Model: MK1
As far as I know maps are identicle on either gearbox.
Ex '02 Citi.Com 20VT K04
'80 MK1 L 2Dr 8V Throttles
Zubair Aka Boost Junkie
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
- Demon Tweaked
- Car Make: VW & VW
- Car Model: MK7R & MK6 GTI
- Membership No: 1845
+1
LB MK7R 359WHP 511NM
MK6 GTI DSG UNITRONIC Stage2
AUDI RS3
BMW E92 M3 350WHP @ Rally Cross Motors
UNITRONIC SEAT Ibiza Cupra 1.8 20vT Stage3 434WHP 509NM @ KAR
VW Citi Chico 1.4
AUDI RS3
VW Citi Chico 1.4
Thanks ZubsZubair wrote:As far as I know maps are identicle on either gearbox.
That's what I wanted to hear
So the DSG box operates totally independently from the motor ECU using its own ECU programing
So what would cause the DSG box to start hesitating after each shift at WOT immediatly after loading a software MAP ?
G5 DSG
- Abnormal
- Registered for: 21 years 1 month
- Membership No: 848
Is the dsg ecu completely seperate or does it get some info from the engime ecu? I thought that the dsg ecu got torque output from the engine ecu.
\Oo) \ _w_ / (oO/
- Major-General
- Car Model: MK1
What software did you load?Wazza wrote:Thanks ZubsZubair wrote:As far as I know maps are identicle on either gearbox.
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
LOL I'd rather not mention names yet as we are still in the process of logging and diag but wanted to do a bit of investigation on my own for nowZubair wrote:What software did you load?Wazza wrote:Thanks ZubsZubair wrote:As far as I know maps are identicle on either gearbox.
G5 DSG
Ok So the problem is history now
I had the car flashed back to stock and there's no DSG shifting issues at all I'm M D or sport mode with TC on or off
But I'm not saying its the map
There may be some other explanation for this strangeness
G5 DSG
- Burner1144
I too flashed a stg 1 software map and immediately noticed afterwards that my reverse is jerky especially climbing a slight incline. Pulling away in D or S from standstill is pretty violent no matter how nicely you try modulate the pedal. Wasn't like this with OEM map.
Shifts though while driving are still smooth with no hesitations.
I thought of maybe resetting dsg box and letting it recalibrate, seems like quite a process.
At the same time ...dont want it to be a case of fiddle, fiddle, f...k..ed
2005 Subaru STi
2005 Golf 5 GTi
2004 Golf 4 GTi R
2002 Golf 4 GTi
2005 Subaru STi
2005 Golf 5 GTi
2004 Golf 4 GTi R
2002 Golf 4 GTi
Howzit man the DSG reset is pretty easy if you have a VAGCOM cable , But the reset only lets the DSG recalibrate the clutch take up it has nothing to do with the input power from the motor so it may make your changes a bit smoother , also check when last your DSG was servicedBurner1144 wrote:I too flashed a stg 1 software map and immediately noticed afterwards that my reverse is jerky especially climbing a slight incline. Pulling away in D or S from standstill is pretty violent no matter how nicely you try modulate the pedal. Wasn't like this with OEM map.
Cheers
G5 DSG
- Porra46
- Car Model: Golf 6 R DSG
- Membership No: 1858
Just for the record guys...
Who is all experiencing this? And what type if software are you guys using??
This seems to be an issue that doesnt happen only if your car has APR software... Lots of reads on overseas forums...
2012 Candy White Golf 6 R DSG - APR Stage 3
460BHP/344Kw and 608Nm
11.9s 1/4 mile @ Tarlton - Dragwars 2015
- Major-General
- Car Model: MK1
Apr?
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
- Porra46
APR as in www.goapr.com
There maps dont have as much glitches as others... Quite a few people have complained on the mk5, mk6 and vortex forums...
It can be remedied though. Your tuner must give it some attention. It is fixable.
- Major-General
- Car Model: MK1
I know APR, I meant was this an APR issue or a local is lekker brand
ZUB-AIR-RESEARCH
Boost Developments
ZUB-AIR-RESEARCH
Boost Developments
- Porra46
Sorry bud. Misunderstood you.Zubair wrote:I know APR, I meant was this an APR issue or a local is lekker brand
APR are the only ones that dont have issues in their software.
- Car Model: ROC 2.0 TSI, FRC & stuff
I've seen many Apr hesitation threads...many...Porra46 wrote:Sorry bud. Misunderstood you.Zubair wrote:I know APR, I meant was this an APR issue or a local is lekker brand
- Porra46
Not denying it bud.tfsi wrote:I've seen many Apr hesitation threads...many...Porra46 wrote:Sorry bud. Misunderstood you.Zubair wrote:I know APR, I meant was this an APR issue or a local is lekker brand
Most cases its a bad tune and if you don't inform your tuner that you are unhappy, how can he help you...
I'm with ETuners... Not APR.
Lol. With Shaheen? Do you stay about 350km from him? Did you think you had dv issues? Did you dyno stock at 194kw? Does your car now make 240kw? At the fly? Stalker alert...Porra46 wrote:I'm with ETuners... Not APR.
- Porra46
tfsi wrote:Lol. With Shaheen? Do you stay about 350km from him? Did you think you had dv issues? Did you dyno stock at 194kw? Does your car now make 240kw? At the fly? Stalker alert...Porra46 wrote:I'm with ETuners... Not APR.
Hahaha!
Hi Guys
My issues have been resolved , Unfortunately im not willing to post up specific info in this thread ,PM me if you want specifics
I think Burners issue is completely different to mine , I will be investigating other software vendors and hopefully I do not have this issue again
G5 DSG
