Polo Gti Problem (Help Please)Update!
Stephan
Car Model: MK4 GiT 20VT
Post by Stephan »
Hi Guys,
My Mate at home drives a Polo Gti 9n3 (2006), there are some issues now and no one knows what's the problem.
What happens is that once the car is warm it tends to smoke under load a bit and once you rev it. It's white smoke. E.g when he stops at home and rev the car a couple of times white smoke comes from the exhaust.
Everyone told us it's rather valve stem seals, turbo seals or rings? Turbo was replaced with a secondhand turbo about 3 months ago :cry: not sure if its the seals?
We checked the car now on cold start up and no smoke came out. But once revved some white smoke comes out again and the car backfires with every blip of the throttle?
If anyone know what this issue might be please help.
.:R 20VT
Sinbad
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Re: Polo Gti Problem (Help Please)
Post by Sinbad »
Under load is unlikely to be valve stem seals - they tend to smoke under vacuum (at idle)
Turbo seals is more likely. Does the car use oil?
Stephan
Post by Stephan »
Sinbad wrote:Under load is unlikely to be valve stem seals - they tend to smoke under vacuum (at idle)
Yea Sinbad, it uses a crap load of oil. Topped up a liter yesterday
.:R 20VT
Sparkz0629
Car Model: 2012 Polo GTI
Membership No: 1768
Post by Sparkz0629 »
I beleive the Polo GTI's have problems with the turbo seals... im sure some of the PGTI owners will advise...
edit to add: thats on the 9n3 GTI... which one does your friend have?
Stephan
Post by Stephan »
Sparkz0629 wrote:I beleive the Polo GTI's have problems with the turbo seals... im sure some of the PGTI owners will advise...
Fixxed! Thanks bro
.:R 20VT
Stephan
Post by Stephan »
Just not sure about the oil use? Car is going in for a compression test today. Maybe they can pick up something.
.:R 20VT
Sinbad
Car Make: Mercedes
Membership No: 1152
Post by Sinbad »
Stephan wrote:Just not sure about the oil use? Car is going in for a compression test today. Maybe they can pick up something.
Doubt it.
Compression test won't pick up turbo seal issues.
Stephan
Post by Stephan »
Ok so there's white smoke coming out of the turbo's compressor side and by the silicone pipes.. So the tebo is fkcd?
.:R 20VT
Registered for: 22 years 9 months
Re: Polo Gti Problem (Help Please)Update!
Sounds most likely like a buggered turbo yes.
Amith11
Car Make: DUH !!!
Car Model: MK7 GTI
Membership No: 1545
Post by Amith11 »
i got one for you :-)
MK 7 GTi
(Daily)
amith.singh@icloud.com
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk4 GTI .:R (True Love)
MK3 Cabriolette 2.0l Exec
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
Stephan
Post by Stephan »
Hey Amith, wich one you got bru the t3?
.:R 20VT
Amith11
Car Make: DUH !!!
Car Model: MK7 GTI
Membership No: 1545
Post by Amith11 »
Nah i kept the Ko3s...
MK 7 GTi
(Daily)
Lost Loves:
Mk4 Tdi Wagon
MK4 TDi
Mk2 GTI 1.8 8V
Mk1 Caddy
Mk1 GTS (4door)
Stephan
Post by Stephan »
pm the price, then we can discuss from there. :)
.:R 20VT
