MK3 GS fuel tank leak
- Dirty Harry
- Car Make: People Carrier
- Car Model: footswagen
- Membership No: 1640
Howzit guys
Its the GS again, giving problems. The SO went this morning to fill up(first time since we have had the car since middle Jan this year) and about 3/4 way of it being filled(47l),petrol starts pissing out the petrol tank.I had a quick squiz and it seems as though its coming from above the joining seem. What are my options here?
Is it possible that because there has not been any fluid it dries out therefore causing this leak sort of like those wooden wine barrels or am thinking up **** here to try divert myself from replacing a petrol tank.
Help will be appreciated.
Cheers
Harry
Cheers
Harry
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Re: MK3 GS fuel tank leak
The tank is plastic, so it might have a crack or it got damaged somehow. But before you do anything, take out the boot carpet and remove the round black plate (3 screws) and check there for a leak.
But if it is leaking from the seam or it has a crack, you can have it plastic welded or get a new tank form a scrapyard. God luck.
- Dirty Harry
Will check that out later.
Thanks Ryan
Thanks Ryan
- SUM DP 4 GP
- Car Model: MK5 KO4
- Membership No: 1394
Harry, if you can't fix it, go to ABC Auto Parts in Kempton, off allandale Road, there's about a 100 G3's there, might be cheaper/worth while to just get a new tank??
- Dirty Harry
Thanks Reolan.Will keep that in mind.Will see how bad the damage is then take it from there.
- SUM DP 4 GP
Most likely just the seal at the fuel cap where the sender unit and pickup sit. It is an absolutel bastard to put in correctly and with the swop to take the pump out and put old gauge and pickup in it probably got pinched or mis-installed. It's not a physical tank leak.
- Forest
- Car Make: BMW
- Car Model: 135i Coupe & S1000RR
- Membership No: 1648
Hey Harry,
What Panic said....
What Panic said....
Stock Standard '89 Golf Mk2 VR6 (Sold)
Project "Merge" Mk2VR6 - The Build
'86 Golf Mk2 AGU 2 Door (Sold)
Project "Tudor" Mk2AGU -The Build
- Colonel
- Membership No: 1041
does the golf 3 tank fit in a golf 2, they look very similar
- Jetta2
Straight swop. No mods needed.UDC wrote:does the golf 3 tank fit in a golf 2, they look very similar
- Colonel
are the fuel float housing the same size, golf 3 looks bigger
- Jetta2
Mk3 pump + fuel level jobbie is way bigger in diameter than the Mk2 item.UDC wrote:are the fuel float housing the same size, golf 3 looks bigger
- Colonel
cool thanks bruJetta2 wrote:Mk3 pump + fuel level jobbie is way bigger in diameter than the Mk2 item.UDC wrote:are the fuel float housing the same size, golf 3 looks bigger
- Dirty Harry
Thanks Stephan and JW, will have a look and see if I can put it on correctly. That is better news. Will update as soon as I find out what the issue is.
- Dirty Harry
I think and hope I have sorted the problem out. I think I am still floating a bit from all the fumes as the tank was full. The damn cap was not tightened properly . I see what you mean its quite a ball ache to put the cap on properly but I managed to tighten it better. I shook the car from side to side to see if anything leaked out and looks like its fine.
Thanks for the help guys.
