Howzit guys just wondering how big of a job is it to change the inner c.v joint boot on a 2003 mk1 1.4i? anything too look out for?
Scared to do it myself after hearing stories of it popping out while driving as I do a lot of long distance.
Currently in PMB. Who would be better to replace it if I had to send it in? C.V joint specialist or Natal C.V joints?
Both R200 including the boot.
Inner C.V Joint boot replacement
- naidup
- Car Model: Citi 1.4i
- Membership No: 731
Re: Inner C.V Joint boot replacement
It's not too bad. For me its easier than the outer becasu the outer you kinda just moer the shaft into the CV and hope the locating ring has done it's job. The inner you can see that the circlip is holding everything nicely.
If you get hold of a Haynes manual for a mk1 the procedure is explained in pretty good detail.
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
1966 Splitty.
No Mk1 ;(
- Colonel
- Membership No: 1041
for that price you rather give it to them to sort out, is a very messy and annoying job, you bascially only going to save about R100 if you DIY itqwerty wrote:Howzit guys just wondering how big of a job is it to change the inner c.v joint boot on a 2003 mk1 1.4i? anything too look out for?
- naidup
Just scared of bad workmanship or bad quality grease. 1 place said they use c.v ms grease. other said they use caltex c.v grease.
CV Grease is generally Molybdenum Disulphide grease. If it's CV grease, its CV grease whether it comes from Caltex or anyone else, it's not fancy at all really.qwerty wrote:Just scared of bad workmanship or bad quality grease. 1 place said they use c.v ms grease. other said they use caltex c.v grease.
Stuart
1966 Splitty.
No Mk1 ;(
1966 Splitty.
No Mk1 ;(
- amstel18
- Car Model: Tiguan Allspace
I'd be more worried about the quality of the boot that they'll be fitting.
Some CV boots are hard and perish very soon.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Car Model: MK5 GTI DSG BWA
- Membership No: 1156
For the price, I wouldnt think twice about DIY.
As stated cv grease is cv grease.
Just make sure the boot is soft and flexible.
if its hard it will wear our sooner.
2012 Dec Mk6 GTI CW DSG - REVO Stage 1
Ex 2008 White Golf 5 Gti DSG REVO3 K04 - Weekend Toy
Regards
Hoosen
072 135 7861
Regards
Hoosen
072 135 7861
- naidup
Okay so finally around to changing the boot. The guys i took it to said there is wear on the below part, now from what i know they don't wear as easy as the outer so i told him to leave it, wasn't sure if he was just trying to make an extra R400 of me. How would i know if it worn? is it a danger? it just looked a little rubbed on those channels.
