Clear coat coming off
JVA
Car Model: A4 B8 3.0Tdi
Post by JVA »
My golfs clear coat is coming off on parts of the bonnet and left side door. Are there any cheap fixes I can do to make it look better? Maybe water sand it smooth so it stops peeling?
katotter
span die seile
Membership No: 1746
Re: Clear coat coming off
Post by katotter »
Year model?
JVA
Post by JVA »
katotter wrote:Year model?
94
katotter
span die seile
Membership No: 1746
Post by katotter »
Damn, if it was younger than 10 years, VW should fix it, as paint has a 10 year guarantee.
So sorry I cannot help with your predicament, take it to a pb shop, they should be able to advise accordingly?
rodga
Nazi Spelling Master
Car Model: MKVI GTI
Membership No: 1323
Post by rodga »
katotter wrote:Damn, if it was younger than 10 years, VW should fix it, as paint has a 10 year guarantee.
id like to see someone try this successfully
rodga's ride
'09 Generic XOR 125 - matte black - Daily Driver :)
katotter
span die seile
Membership No: 1746
Post by katotter »
rodga wrote:id like to see someone try this successfully
Funny you should say... A buddy of mine with a 2006 G5 Jetta TDi went for his 100 000km service at a agent, don't know where. He asked what he can do about his clear peeling and chipping, he said "lets have a look on our system quickly", came to the conclusion that there was a recall on that specific UG batch and his car never got the treatment, he will be receiving his full body respray soon...
Stompie
Boostleak Guru
Registered for: 14 years
Car Model: 2006 120D
Membership No: 1843
Post by Stompie »
why not sand it off with 2000-3000 grit water based sand paper, and then just get some restoluim clear cote and respray it 2 or 3 coats, sanding between each coat. after the last coat if you have orange peel, get a good buffing compound and just sand it again and buff till it shines...?
BMW 120D E87
katotter
span die seile
Membership No: 1746
Post by katotter »
PoloGTIman wrote:why not sand it off with 2000-3000 grit water based sand paper, and then just get some restoluim clear cote and respray it 2 or 3 coats, sanding between each coat. after the last coat if you have orange peel, get a good buffing compound and just sand it again and buff till it shines...?
Sounds like a good plan, great tip there bud!
rodga
Car Model: MKVI GTI
Membership No: 1323
Post by rodga »
but a recall is different to a warranty claim, no?
cool for your bud tho
rodga's ride
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
glad i could help!!
only problem with this solution is, the parts done are going to look brand new if done proparly, then the rest of the car is going to look old...lol....
BMW 120D E87
Mc3103
Car Make: Tuk Tuk
Post by Mc3103 »
PoloGTIman wrote:glad i could help!!
Im going to try your method as well and see what happens. the sides of my car look brand new, i machine polish them often, its just the bonnet and roof that have clear coat damage.
Just i pick up the sand paper and clear coat spray at a normal hardware?
'96 Citi Sport 1800
Vodka wrote:Ahh If it's got tits or wheels It's going to cost you money!!
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
get it at builders, or any hardware shop.
but get the restoleum clear coat!! best quality!!
Please make sure that when sanding you keep the area wet and do not press to hard!!! also be carefull of not going through base paint. all you want to do is sand the clear coat to a cloudy shade and untill service is smooth. then you clean, and start spraying the clear coat. the paint might look dull after sanding but after applying clear coat, and buffing it will have the nice shine again.
take your time in doing this. give the paint at least 10-15min drying time between coats. make sure the sand paper is water based.let the sand paper lay in the bucket of water a minute or so to soak up water and get soft. then lastly, be careful of corners and edges as the paint is very thin in those areas, pressing to hard or sanding to long will sand through the paint!!!
do some read up on google regarding sanding and painting before attempting this on your car!! practice on a piece of metal or so to get the hang of this.
BMW 120D E87
Mc3103
Car Make: Tuk Tuk
Post by Mc3103 »
PoloGTIman wrote:get it at builders, or any hardware shop.
Thanks for the info.
I'm guessing i use the 2000 grit to get the clear coat off and then the 3000 grit inbetween spraying the clear coat on? My bonnet couldn't get any worse than it currently is, so im not too stressed about it.
'96 Citi Sport 1800
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
jip, use 2000 to get it off, then 3000 to smooth it, then wash, spray, wait till dry, spray second coat, wait to dray, spray 3rd coat, wait to dry for 24-48 hours, then sand with 3000 till the whole bonnet is clowdy then, buf it with buffing compound...should look great.
BMW 120D E87
Mc3103
Car Make: Tuk Tuk
Post by Mc3103 »
And buffing compound, must i use a specific one, or also just something from a hardware?
Oh and JohanGP sorry for the thread hijack.
'96 Citi Sport 1800
Stompie
Boostleak Guru
Membership No: 1843
Post by Stompie »
any good buffing compound...almost think mcguires has one...and do it with a polisher as with your hand it going to take looooooooong!!
BMW 120D E87
PoloGTIman wrote:any good buffing compound...almost think mcguires has one...and do it with a polisher as with your hand it going to take looooooooong!!
Yip they do, it is called ultimate compound - available at Makro/Builders Warehouse / Autostyle etc etc. Or you can check out Crazy Detailer website for other products.
Mc3103
Car Make: Tuk Tuk
Post by Mc3103 »
Thanks, i will get the mcguires then.
'96 Citi Sport 1800
