Mk1 rev counter sender unit
- klippie
- Car Model: MK1 Caddy, Mk3 VR6 Jetta
- Membership No: 1658
Ok guys a quick Q,
Where does the rev counter in the cluster get its data from? I have a new cluster but the rev counter is dead, i suspect the sender unit to be fault if there is such a thing...
Everything else on the cluster works
**** you thunder, you can suck my ****!
the BlueWafle http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=119334 - SOLD
the Storm Trooper http://www.vwclub.co.za/phpbb3/viewtopi ... 9#p1612279 - Crashed
- jetta786
- Registered for: 12 years 4 months
- Car Model: MK5 JETTA COMFORTLINE 2LTR
- Membership No: 1715
Re: Mk1 rev counter sender unit
Did your old cluster not have a rev counter? if not and u fitted one to accomodate rev counter, then the signal comes from the negative of your 2 pin coil.
- klippie
thank you velly much. will check tomorrow moring. the old cluster did have a rev counter, but the board connector was f'ed. so got a new one. the rev counter has never worked. so thus i believe that to be the problem. ill look for a wiring diagram for the cluster online. to make sure that the wire is running to the coil.
- marnus
- Membership No: 1975
What management are you running dicktator?
- marnus
Are you running any aftermarket management?
- klippie
Hi Marnus,
Yes I'm running Dicktator......
- klippie
bump, what does Dicktator have to do with the issue? Please explain?
- Car Model: 2004 Chico under construction
- Membership No: 1820
Your dicktator can also supply tach signal, but the diagrams on the website doesn't work on my PC, good luck
- klippie
what is the website
- klippie
no worries, i found the diagram. i see the pin that supplies the output. now to find one for the cluster.
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Bru its pin 4 on dicktator that supplies rev counter signal. you using square dash cluster so it will work fine without resistors etc.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- VWicked
i think the wire is green for rev counter on the cluster but check. its been over two years that i had a look at a citi type cluster
- klippie
ill have a look, I'm just scared I'm gonna cut the wrong wires and break something.
- klippie
There are to many wiring diagrams on the web, making my head spin........
http://www.veedubz.co.za/tech/VW%20Hayn ... AGRAMS.pdf
- klippie
found this, does it look right?
- klippie
and this,
seems like its the red and black wire
- jetta786
on what car is this? i see your profile reflects caddy??
check this link. make sure the ecu is connected correctly.
http://www.dicktator.co.za/diagrams.html
hope this will help.
- klippie
ok, so i cut the blue no 4 wire running to the ecu, connected that (ecu side) to the cluster. Nothing.
My harnes plug looks like this,
Gray
Brown
Purple
Yellow with a red stripe
Red with a black stripe
Red
Blue with a white stripe
Thick Black
Thick Black
Blue
Blue with a red stripe
Black
I connected it with the Yellow/white and the red/black.
any idea's?
Gray
Brown
Purple
Red
Thick Black
Thick Black
Blue
Black
any idea's?
- klippie
Used it thanx bud. Jip Caddy 82 and 2006 clusterjetta786 wrote:on what car is this? i see your profile reflects caddy??
- marnus
Is this for the old shape dashboard?
- klippie
that is correct sir!
- klippie
Ok, so i will be running a new wire through from the coil, to which wire do i connect this new one? See above for colors.
- marnus
I had the same problem but I have the new dash. I have a old wiring loom laying around. Will have a look and maybe trace the wires for you.
Check this. Here the guys say on the old dash its the thick green wire but dont see a thick green wire on your wires.
http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=128344
- klippie
thanx, no green wire on the loom, will rip it all out this weekend and do some testing.......
- Membership No: 1469
Sup Marnus,marnus wrote:I had the same problem but I have the new dash. I have a old wiring loom laying around. Will have a look and maybe trace the wires for you.
How did you solve the new dash rev counter problem? im running dicktator with new dash?
