DIFF BETWEEN MK2 1.6 HEAD AND 1.8 HEAD
- Car Model: MK2 Golf CSX
- Membership No: 1486
So wats the difs I ask this because I was studying my heyns manule the outher night and saw that the valve sizes were the same on both now if i am thinking correctly the heads should be the same as the bore on 1.6 and 1.8 is the same
- 6teen_valve
- Car Model: Sooter, Money pit
- Membership No: 1406
Re: DIFF BETWEEN MK2 1.6 HEAD AND 1.8 HEAD
I have just done an head overhaul on what I thought to be a 1.8 mk2 head
To my surprize it was a 1.6 head, because aparently the 1.8 valves are longer thaan
The 1.6 valves. This is what I was shown by alert spares!
89' MkII Golf
Ex:2003 1.4i CiTi
Ex:2004 1.6 16v Opel
Ex:2002 2.0i 8v Caddy
Ex:08' Sooty - Stolen
''anybody can go out and buy a new hot hatch
it takes a special kind of crazy to restore a mk2 to its former glory''
Membership No: 1406
Ex:2003 1.4i CiTi
Membership No: 1406
will the to heads interchange
- 6teen_valve
i dont see a problem, but maybe there is,
who else can advise on this subject.?
89' MkII Golf
Ex:2003 1.4i CiTi
Membership No: 1406
Ex:2003 1.4i CiTi
Membership No: 1406
They should be identical.
- FM1
- Car Make: Ford
- Car Model: Fiesta
on the topic but slight off. are there then a difference between the 1.6 and 2.0 head, and will a 2.0 head fit on a 1.6 block
FROM ROOTS TO TREETOP
Current: Ford Fiesta
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Car Model: MK2 GTi
MadMax101 wrote:So wats the difs I ask this because I was studying my heyns manule the outher night and saw that the valve sizes were the same on both now if i am thinking correctly the heads should be the same as the bore on 1.6 and 1.8 is the same
Just a little light reading before bed time or what....
1991 MkII GTI 16V http://www.vwclub.co.za/phpbb3/viewtopi ... 11&t=95318
2015 Land Rover Discovery 4
2014 PW Golf Highline DSG TDi Xenon&LED pack, Pano Roof, Nav, RearView Assist, Park Assist, Climate Control
2016 Audi RS3
2020 Tiguan Highline TSI
2013 Land Rover Defender 90
2016 Audi RS3
2l head also interchangeable. The only head that is really differnt is the 1.3 and 1.4
- Killerwatt
- Car Make: AUDI
- Car Model: S3
just remember that you got solid lifter and hydro lifters in the mk2's, that's why the valve lenght differs. the kjet head had the big valves and the carb head had the smaller ones.
like panic said heads are interchangeable but if one is solid lifer and the other is hydro, the camshafts are not interchangeable.
- heineken
- Car Model: MKII Jetta CSL
- Membership No: 2009
Sorry for the Noob question....
With regards to camshafts for 1.6 & 1.8 carb heads, which one comes with an "A grind" and "G grind" cam
Smooth Carpuretor: http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=129428
G-grind was ONLY found on 1.8 GTi's
A grind only found on the longblock 2l engines. They were all injection as well.
I have a 1.6 head at home and a 1.4 head and i meshered the valve sizes and they the same. what is the valve sizes for the K jet head why would there be a differens
- Car Model: Mk1 2-Door, Polo Sportline
anyone here selling a G cam...? Mine got f**ked when my head seized.
It can never be Fast Enuf
Madmax191 take a picture of the 2 heads next to each other from the combustion chamber side and post it here.
Left is 1.6 right is 1.4
1.4 comustion chamber
1.6 comustion chamber
1.4 front
1.6 front
1.4 front
1.6 front
- MhVW
- Car Model: '06 Polo Classic 1.9 TDi
- Membership No: 1466
1.4 head:
Intake valve: 38mm
Exhaust valve: 33mm
Combustion chamber: 27cc
Intake valve: 38mm
Exhaust valve: 33mm
OK the main diffs between the 1.6,1.8,2l heads and the 1.4 head is the size of the combustion chamber and that is quite cleary visible on your picture. Usually the 1.4 that I have seen also has a smaller intake valve but I get a feeling that somebody modified the one you have to have the same size valves as the other heads. You can see where the chamber was cut away on the edge to accomodate that.
panic can the chamber be reshaped to fit for the use on a 1.8 motor or could i just leave it as is to push the compretion a bit
it's not going to push it a 'bit' it will send it to around 13.5:1. But you HAVE to measure volumes and calculate the CR as every engine differs and what I calculated for one engine 8 years ago might not be true for what you are working on.
- Membership No: 731
For what it's worth....I have a 1.4 head on a 1.8 carb block. It's apparenlty been worked with a longer crank etc to be 2.1L
Seems to work...But I haven't tried any of the bigger heads so I don't know if I'm losing any power because of it.
Panic: Would you be able to tell if you had to use less timing when tuning it because of the comp ratio?
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
1966 Splitty.
No Mk1 ;(
road hawg what pistons you using there
No can't really tell. you also have to calculate the CR to know for sure. I'm always amazed that guys will just slap a motor together without actually bothering to work out CR for real. There are many factors affecting ignition timing and CR is not the only thing. Some engines are more prone to detoantion than others.
panic-mechanic wrote:No can't really tell. you also have to calculate the CR to know for sure. I'm always amazed that guys will just slap a motor together without actually bothering to work out CR for real. There are many factors affecting ignition timing and CR is not the only thing. Some engines are more prone to detoantion than others.
Ok just wondering.
Yeah, It did have a 2L head on it when Jerry had the motor, but he broke the cam bet and killed the head. Sarel rebuilt it with the 1.4 head and he reckoned the compression was actually lower now with the 1.4 head as the 2L head had been skimmed a lot. His words.
I just said "ok"
Apparently they are kombi pistons with the squish pads machined down/flatened or whatever. I have no idea what's Really in that motor. Sarel reckoned the crank was worth more than the rest of the motor combined.
Stuart
1966 Splitty.
No Mk1 ;(
1966 Splitty.
No Mk1 ;(
Well if he calculated the CR then surely he should have told you what it was?. Yes honestly there is no way I can gues what it is without having actually meausred the values. The tuning cannot tell you but the fact that it ran quite nicely with realtively short timing does mean it was relatively high.
