AEN vs FFZ
- Benitovw
- Car Model: CITI ADY
- General
- Car Model: Golf GT
- Membership No: 1464
Re: AEN vs FFZ
I've got a hybrid gearbox in my GT, AEN gear ratios and FFZ final drive - makes for a nice short ratio gearbox:
FFZ Ratios - 3.46/1.94/1.37/1.03/0.85 and final drive 3.94
AEN Ratios - 3.46/2.12/1.44/1.13/0.85 and final drive 3.67
1st and 5th is the same, 2nd, 3rd and 4th is better spaced.
Current rides:
Hyundai - 1.4 Getz (daily)
- Benitovw
Re: AEN vs FFZ
@Torker but which 1 would be better cause I have a AEN box would a FFZ box be faster?
CITI 2L 8V
- General
Re: AEN vs FFZ
FFZ Speeds:
AEN Speeds:
From the above you can see that the FFZ got the shorter 1st gear and 3rd gear but the longer 2nd gear - I would say that apart from the less than ideal 2nd gear the FFZ would be the better option for short sprints. The long 5th gear in the AEN is more geared towards saving fuel than performance.
AEN Speeds:
Current rides:
- Benitovw
Re: AEN vs FFZ
Thanx Torker
I'll stick with the AEN because from 1st to 4th it looks close but I need the longer 5th for my everyday driving.
CITI 2L 8V
- Fiefster
- Car Model: 2005 1.4 CitiGolf
Re: AEN vs FFZ
Can anyone please explain to me what the final drive is?
Nuclear powered spaceship
Disguised as a 1400 citiGolf
- CRASH_IT
- Car Model: 8P S3
- Membership No: 1540
Re: AEN vs FFZ
What went wrong in my AEN then i dont know cause that thing was kak!
Short sprints were awesome but 5 gear at 120km/h @ nearly 4000rpm!
I now have a FFZ and is alot better 120km/h @ 3500rpm!
Lil more legs in the mid range gears tho.
CURRENT RIDE
2013 VW transporter 2.0TDI
2007 Audi S3
EX
- 2014 Ford Fiesta ST
- 1993 1.8i CITI MP9 98HP 147NM @ KAR
NOW:2.0 ABF 117HP 158NM @Panics on XMS (SOLD)SNIFF
http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=108203
2007 Audi S3
EX
- Fiefster
Re: AEN vs FFZ
My ffz box is like this. 120km/h (on the clock) and I'm at 3500 rpm, 120 true speed and I'm at 4k rpm. Top out at +-175km/h on a straight.CRASH_IT wrote:
Re: AEN vs FFZ
from those 2 graphs i see teh AEN is
faster in all gears.
teh lower teh number of teh gear & diff
teh longer teh gearing & diff ratio.
teh higher then teh opposite.
FFZ is a nice ratio for std & mild tuned cars.
For hi output engines go with longer ratios
a FFZ with a 3.67 final ratio......hmmmm i wonder.
Sud go well with some beeg torque.Anyone?
- Benitovw
- General
Re: AEN vs FFZ
After Poy built me a close ratio box (AEN gears and FFZ final drive) he used the stuff left over to built me a box with FFZ gears and AEN (3.67) final drive. I sold it to aarchaic on the forum and he put it in his Jetta - he was looking for a more relaxed drive and he is very happy with it.pepa wrote:
Current rides:
- Registered for: 15 years
- Car Model: Citi Chico baby dragster
Re: AEN vs FFZ
This is what Poy built for me
3.45 1st 2.12 2nd 1.44 3rd 1.13th and 0.85 5th
Final drive ratio is 4.25
Diff bolt kit
Vereway limmited slip diff
Overshift stoppers on 3rd and 4th, not so sure what these are for.
Pre load and backlash is done perfectly to 5kg, whatever that means or do
Rose joint adjustable short shifter kit
Diff bolt kit
- aarchaic
- Car Model: 1991 Jetta Clx Mk2
- Membership No: 1628
Re: AEN vs FFZ
FFZ will be better as it has more torque to get you off the line. but you will run out of legs on longer runs.
Membership Number: 1628
1991 Vw Jetta MK2 CLX ( ADY 2.0, 8v 282 cam , 96.7hp atw 144 Nm )
91 Vw Jetta Mk2 Build - ADY - Dyno Graph Pg 16
In Car Entertainment Build & Install Completed - Thread
Jeremy Clarkson : “I'll tell you what. We'll try it my way first... and then we'll finish!”
- aarchaic
Re: AEN vs FFZ
with 195 / 50 - 15 wheels at 4000 rpm these are the speeds you should getpepa wrote: a FFZ with a 3.67 final ratio......hmmmm i wonder.
Std FFZ - 129.65km/h
Std AEN - 132.94km/h
FFZ gears AEN Final Drive - 139.19km.h
