2E or ADY
zain_c
Car Model: Accord + MK2 Jetta CSi
2E or ADY
Post by zain_c »
so just been trying to decide which motor is better? Some guys are convinced the ADY is better than the 2E and vice versa.
What are the differences between the 2 motors? :geek: As I've heard the ADY is a newer motor.
Is there anyone that can break it down to me with regards to which one would be the best option.
Zain
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
88 MK2 CLi 1.9 16v 15.0 Killarney
96 MK3 GTS
Car Make: VW, VW, Aprilia
Re: 2E or ADY
Post by Jetta2 »
Specwise they are identical.
Power and torque wise, both are also identical.
Yes, the ADY is a newer model motor than the 2E, so if getting an ADY chances are good that it will have less km on it than a 2E.
Also the 2E has only a dizzy, while the ADY has a 60-2 crank angle sensor already fitted as stock (60-2 wheel fitted to crank and sensor fitted to the block under the dizzy).
warrenk
Car Model: '84 Jetta GX
Re: 2E or ADY
Post by warrenk »
Personally I prefer the 3A or short-block 2L as they are often referred to
mk1-8valve.
Car Make: VW Polo
Car Model: 9N3 Polo 1.6
Re: 2E or ADY
Post by mk1-8valve. »
Is the AGG the same as 2E & ADY in terms of spec's.
WRT timing setup, are the timing marking on the AGG the same as any other 8v motor or does the set up differ in any way (i.e. cam pulley to tappet cover, dissy points to no. 1 cylinder, crank pulley marking line up to lower engine cover marking, no.1 piston on TDC). TIA
VW Polo 9N3 1.6
Renault Scenic 1.9 dCi
Ex rides:
Toyota Corrola 1.6
Toyota Yaris T3
VW Citi Sport 1.8i
VW Caddy 2.0
Re: 2E or ADY
Post by Jetta2 »
All the 2 litre 8V VW motors share the following specs (engine codes are 2E, ADY, AGG, AKR & ABA):
Capacity - 1984cc
Bore - 82,5mm
Stroke - 92,8mm
Compression ratio - 10,4:1
Power - 85kW @ 5400rpm
Torque - 166Nm @ 3200rpm (2E, ADY and ABA), @2600rpm for the AGG and AKR
Power and torque figures are at the crank and at the Coast.
Check here for more info (scroll down to the 3rd block):
http://www.doppel-wobber.de/wbb2/golf_info.php?id=124
Car Make: VW, Mini, Slowyota
Membership No: 3337
Re: 2E or ADY
Post by kingr »
zainyboymk1 wrote:so just been trying to decide which motor is better? Some guys are convinced the ADY is better than the 2E and vice versa.
Zain
I thought you where going to go 16v :evil:
Kurt #3337
- 10" Mx5 NC2 (main daily)
mk1-8valve.
Car Make: VW Polo
Re: 2E or ADY
@guys running 2.0 8v motors with a 288deg cam on aftermarket management.
How does your motors idle when you start up in the morning or evening when its cold? Does it idle un-assisted?
I have to keep my foot on the accelerator, use the fuel pot thing to enrich the mixture and wait for the motor to warm up half way on the gauge before it idles on its own.
I plan on putting the std A cam back in & retune it to make the car idle better (un-assisted) and for reliability & drivability sake.
VW Polo 9N3 1.6
Ex rides:
Toyota Corrola 1.6
Toyota Yaris T3
VW Citi Sport 1.8i
VW Caddy 2.0
joggiep
Registered for: 20 years 4 months
Car Model: Amarok V6
Membership No: 664
Re: 2E or ADY
Post by joggiep »
mk1-8valve wrote: I have to keep my foot on the accelerator, use the fuel pot thing to enrich the mixture and wait for the motor to warm up ....
Gotech --- spit
There is your issue !
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
aran.com
Re: 2E or ADY
Post by aran.com »
mk1-8valve. wrote:@guys running 2.0 8v motors with a 288deg cam on aftermarket management.
not the same but i had a 1.8 with 288 and standard mp9 had no problems with idle or drivability
maybe the tuner didnt setup the cold start correctly?
Current:1997 Civic Vtec
Ex:2003 Caddy club
Ex:1997 Ballade vtec
Ex:1999 Ballade vtec
Ex:1995 Golf VR6
Ex: 1.8i citi.com
mk1-8valve.
Car Make: VW Polo
Re: 2E or ADY
Gotech --- spit
Lol, close, its mr. turbo v1.7.
What would you advise in this situation joggiep?
VW Polo 9N3 1.6
Ex rides:
Toyota Corrola 1.6
Toyota Yaris T3
VW Citi Sport 1.8i
VW Caddy 2.0
Re: 2E or ADY
Post by Jetta2 »
If you have a laptop, tune the cold start yourself through the Mr Turbo software.
I tuned the Perfect Power XMS4 in the Jetta that way through the LetRipp software and cold starts are no issue. Also did the same with the Gotech fitted previously and also no issues there with cold starts.
MarnoG
Car Model: 2009 Citi Sport 1.4i
Re: 2E or ADY
Post by MarnoG »
Jetta2 wrote:All the 2 litre 8V VW motors share the following specs (engine codes are 2E, ADY, AGG, AKR & ABA):
Capacity - 1984cc
Bore - 82,5mm
Stroke - 92,8mm
So, same internal specs. How about external? Mounts? Mating it with gearboxes?
Marno
Stuff for sale:
- 2009 VW CitiSPORT 1.4i: http://www.vwclub.co.za/forum/viewtopic ... 9&t=198201
current: '09 VW CitiSPORT 1.4I
ex: '93 VW Citi Shuttle 1.3 (Golf VS. Truck)
Re: 2E or ADY
Post by Jetta2 »
Same as well.
zain_c
Re: 2E or ADY
Post by zain_c »
thanks for the help guys...it looks like i'll go with the ADY just coz because its a newer motor. what's the issue with the dizzy though? I've heard some guys talking about this before.
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
mojo786
Car Make: Vw+SEAT
Car Model: VeLo+Cupra
Re: 2E or ADY
Post by mojo786 »
zainyboymk1 wrote:thanks for the help guys...it looks like i'll go with the ADY just coz because its a newer motor. what's the issue with the dizzy though? I've heard some guys talking about this before.
You will need to change the trigger plate to 4window,you can use the one from your 1.4.
For mp9 usage.
Velo-ABF-ride-thread
2.0 16v ABF - MP9/ Per4mance Custom Tuned-(0837860345)
57mm F/F
Custom ratio Bolted diff Gearbox
CrossDrilled VR6 stoppers!
JOM coilovers
A.R.B
Webasto tilt n slide sunroof
.:R -Line boot spoiler
07 SEAT IBiza CUPRA TDi
Allard EGR delete
BMC flatbed filter
dp/FullZorst
Sw
Mopower.abf@gmail.com
clinton-mk2
Re: 2E or ADY
Post by clinton-mk2 »
@ jetta2 do you perhaps know why the torque of the AGG is made at lower rpm?
Re: 2E or ADY
Post by Jetta2 »
clinton-mk2 wrote:@ jetta2 do you perhaps know why the torque of the AGG is made at lower rpm?
Different cam and ECU settings I suppose.
poloplayaWP
Registered for: 14 years 5 months
Car Model: 9n 1.9 TDI Sportline
Re: 2E or ADY
Post by poloplayaWP »
Forgot about my motor lol AFW 2.0 MP9.
2014 VW Golf VII GTI DSG
2009 Ford Bantam 1.3 Rocam
2008 CRG Road Rebel Shifter with TM Racing 125cc 2 Stroke 6 Speed Sequential
ex 2011 VW 6R Polo GTI
ex 2005 Polo 1.9 TDI Sportline
ex 1978 Beetle 1.6 Twinport
ex 1998 Original VW Motorsport Polo Classic 2.0 8v
ex 1984 Golf 1.3
ex 1998 Polo Playa 1.6>2.0
ex 1989 Ford Bantam 1.6
ex 2007 Nissan 1400
Holmesshaidan
Registered for: 6 years 2 months
Re: ady
Post by Holmesshaidan »
Hi guys im new at the racing game , I bought a golf 3 gti with a 2l 8v ady motor, need some help with regards to making it faster, I would like to put bigger injectors or even throttles but I dont know which way to go, would like to put a cam in as the motor is standard but has a 57mm exhaust right through, so the question is could I put bigger injectors and cam and then wat else could I do to improve power and helpibg it get off the line quicker
missioner
Car Model: '87 MK1 Golf Citi
Re: ady
Post by missioner »
Holmesshaidan wrote:Hi guys im new at the racing game , I bought a golf 3 gti with a 2l 8v ady motor, need some help with regards to making it faster, I would like to put bigger injectors or even throttles but I dont know which way to go, would like to put a cam in as the motor is standard but has a 57mm exhaust right through, so the question is could I put bigger injectors and cam and then wat else could I do to improve power and helpibg it get off the line quicker
I hope you have lots of money. MK3's are expensive to make fast.
1st expect to spend R1000/kW on an N/A engine.
2nd you have a very heavy body for the purposes of racing. I suggest a Citi with the same engine as the power to weight ratio is loads better.
3rd suspension and weight reduction can make a larger improvement in real world track performance than engine upgrades. Rather look into a set of proper racing coilies and better brakes before you even put a spanner on the engine. Polyurethane suspension bushes and sway bar upgrades can make noticeable improvements in lap times on a track. A roll cage also makes a difference by reducing chassis torsion during cornering, the flex can affect the wheel alignment enough to take one off of the racing line, which costs time.
Check through the threads and you can find numerous threads posted by racers detailing the modifications made to their cars to make them faster, very little of which is engine work.
Finally find a decent tuner (*cough* 8V Performance*cough*) close to you and chat to them about your goals. They can advise you how best to achieve the most from your existing engine whilst meeting the rule requirements for your chosen class. Download the rule book from the MSA website, study it closely.
TL;DR
Good luck
Re: 2E or ADY
Are you talking actual racing racing as in track or street racing.
Either way, you picked the wrong tool.
Bigger injectors on it's own does not make more power. They are needed only if you make other big mods. In anybcase they will support more hp younare likely ever to make in naturally aspirated form anyway.
Killerwatt
Car Model: S3
Re: 2E or ADY
Post by Killerwatt »
In all honesty a NA 8v in a mk3 will never be fast. Yes you can make it a little bit better but it may not be worth the money spent on it. Add a cam, tune accordingly and be happy.
I've always wanted to bolt up an Eaton supercharger to an 8v motor. Maybe look into that, but thats a fair bit of fabrication.
Mk1Crazee
Car Model: 1980 Mk1 4 Door 2L8V
Re: 2E or ADY
Post by Mk1Crazee »
Mk3s are HEEEEAVY! i owned one for 2 weeks and then realised it just wasn't worth my money. If you plan on using it for racing i would advise to look for a lighter platform.
What are your intentions though?
1989 VW Fox 1800 (Sold)
1985 Ford XR3 1600Sport (Restoration Sold)
2004 Mk1 Golf 1.4i Velo Motor (Sold)
1980 Mk1 Old School Golf 2L8V
Shallow Pockets. Backyard Builder :moon:
LeeR#1
Registered for: 3 years 9 months
Re: 2E or ADY
Post by LeeR#1 »
Hi guys, I'm new here. Sorry for going off topic and adding to the initial question. I just want to know if anyone has did a 2E with a carb conversion and what the perks are if any and what the proper setup would be to ge the most out of it. I just bought a citi golf with a 2E Carb in.
TIA
Hope I didn't make a flop
