Advice on Cleaning wheels
warrenk
Car Model: '84 Jetta GX
Post by warrenk »
Hi Guys,
I bought a set of Montreal II's yesterday,
brake dust build up is very bad on one of the rims.
any ideas on cleaning it up?
I tried all the detergents i could get in the house, even pool acid..
thought the acid would chow the paint but it's still alright..
i dont really want to repaint the wheels yet..
anybody had a similar experience before?
Re: Advice on Cleaning wheels
warrenk wrote:Hi Guys,
:eek:
Adamantium
Post by Adamantium »
those wheels need a paint did you see all the scratches....
just prep it for spraying it will all come off, otherwise clean green or some other cleaner
http://www.adamantiumcg.co.za
ADAMANTIUM GUARD-commercial/residential services PSIRA 1966419
07 Mini Cooper S
06 Corsa utility
11 CW Bigboy Sportflite F35
EX
06 CW Golf V GTICW G5 GTI
05 1.6 Ford Fiesta
97 1.3 Opel Corsa
Yakuza Racer
Voora Molester
Post by Yakuza Racer »
Autoglym Rim CLeaner....... worked for my phatt5's i had, and those had almost embedded in the rims...... came out brand new again
Thupercharged S4
Kashi
Car Model: 8P A3 2.0 FSI
Post by Kashi »
have you tried those 60 second mag wheel cleaners
The best car safety device is a rearview mirror with a cop in it!!!
infiltrator
Registered for: 18 years 2 months
Post by infiltrator »
oven cleaner....
current rides:
81 Mk1 GLS
05 Mk5 GTI
6teen_valve
Registered for: 16 years 1 month
Car Model: Sooter, Money pit
Membership No: 1406
Post by 6teen_valve »
Cyclo CM30 FTMFW!!
Crazy Detailer Sell it. check there website.
89' MkII Golf
Ex:2003 1.4i CiTi
Ex:2004 1.6 16v Opel
Ex:2002 2.0i 8v Caddy
Ex:08' Sooty - Stolen
''anybody can go out and buy a new hot hatch
it takes a special kind of crazy to restore a mk2 to its former glory''
Membership No: 1406
Yakuza Racer
Voora Molester
infiltrator wrote:oven cleaner....
x2!!!
use this to clean my zorst tip, works WELL
Thupercharged S4
Crawler
Car Model: 9N3 Polo TDi
Membership No: 1358
Post by Crawler »
post after pics
CW Polo TDi Sportline
onyx
Registered for: 21 years 4 months
Car Model: Golf V 2.0FSi
Post by onyx »
From the larger image you can see some particularly bad scratches and chips... I reckon you'd be better off having then stripped and re-painted!
In the interim however get:
• Dedicated wheel cleaner (if its the acidic type make sure to follow the instructions carefully and make sure its safe for your wheel)
• Eucalyptus oil or Tar Remover
• Pressure Washer
Spray on the wheel cleaner (following the instructions) and then blast them with the PW.
Assess if there's any difference - if not, repeat but this time use a brush to agitate the dirt/brake dust/tar.
Much difference?
Brush some Eucalyptus oil onto a test spot, leave to dwell (agitate if needed) and then blast with the PW
Any Change? No? Yes? :hi:
warrenk
Post by warrenk »
haha, i 1st wanted to clean them and see what they would look like on the van...
i am going to repaint them, and ovencleaner aint friendly to the paint :lol: i sprayed the oven cleaner on and immediately cleaned the excess off... it left "dry" marks.. all the more reason to paint them.. and seeing as i now beggered the paint up on the one rim i had a go at that **** with the steelwool... it takes vark long but it comes off, but so does the paint :lol:
what is the correct colour for these wheels? otherwise i'll just go hyper silver
Djin
Crazydetailer
Registered for: 21 years 11 months
Post by Djin »
From the looks of it, I would say you could have got those wheels to at least 80-90% back to new. Before going for the harshest chemicals dig deep for a bit of patience :wink: . I know its the road less traveled but it pays in the long run. That brake dust build up has taken YEARS to accumulate, NO magic product will sort it out with a quick wipe.
My process would have been:
Step 1 - Wash thoroughly with a decent mag cleaner and brush. If its acid based, don't leave on the wheel for more that a minute. Like Onyx mentioned, read the instructions.
Step 2 - If you see that step is removing the brake dust then repeat until completely satisfied. IF not, move onto step three.
Step 3 - Try loosening up the dirt with a bit of tar remover. Let it sit on the contamination for a bit and then agitate with brush. Repeat if it works for you until clean, else move onto step 4
Step 4 - Use detail clay plus lube on the contamination and see if that picks up any dirt. Again, if that works for you, keep repeating until completely clean.
Generally these 4 steps covers 90% of wheel contamination but theres always the EXTREME cases.
In extreme cases wet-sanding is the LAST resort. This is the point where you have decided already that you will refurbish the wheels, so if you really mess up, you already prepared to pay to get it restored !
Store Tel : 011 476 5409
Spooln_4
Post by Spooln_4 »
:hi: waar het jy nou weer die wiele gesmous? Gan mooi lyk op die caddy!!
warrenk
Post by warrenk »
PocketRocket wrote: :hi: waar het jy nou weer die wiele gesmous? Gan mooi lyk op die caddy!!
Ek het die goed by Autostyling gekry, Amish het gediscount met Hooka...
Thanks for all the input from you guys, but a friend and myself ended up repainting them. The brakedust was somehow embedded in the clearcoat/paint.. got rid of all the nicks and scratches as well so these babies are looking brand new. Want to give it another coat of clear though. Must still sort my front brakes out before they can go onto the van :twisted:
Spooln_4
Post by Spooln_4 »
I see they came out nice!!
warrenk
Post by warrenk »
im going to give them another coat,
all in due time, still busy with the front brake setup
