The all new Revo SPS....
For all your REVO software requirements
Revo Technik are proud to release their New SPS switch. The Patented OBD2 interface is the ultimate compliment to Revo performance software. The Revo SPS gives the user the ability to switch between a Revo performance modes and a stock performance setting via the vehicles OBD2 port.
The new SPS has a preset stock mode, the ability to store three performance settings and the additional benefit of a security lockout program.
Simply select a program, plug in, wait a few seconds, remove the select device and start the car. It's simple and there's no fixed switch to alert to any modification.
Revo - Innovators of Serial Port Switching to the aftermarket.
select functionality:* Position
Communications mode for PC’s 0
Stock Mode 1
Performance A* 2
Performance B* 3
Performance C* 4
Anti-Theft On* 5
Anti-Theft Off* 6
Firmware Update (Revo factory use) 9
*Check SPS Vehicle Application Guide for specific functionality of SPS with your car.
Some normally aspirated programs are single program only and not switchable.
The SPS delivers different levels of functionality depending on the vehicle it is used with, and whether variable switching is available in the Revo performance software.
The SPS features variable boost, throttle, timing and fuel adjustment for certain vehicles (check functionality of your vehicle via the SPS functionality link) allowing the user to set the car up to run efficiently with any fuel quality and in varying conditions. SPS software gives the user the ability to store up to three preset configurations in the switch or alter settings via the OBDII port.
The SPS features variable boost, throttle, timing and fuel adjustment for certain vehicles (check functionality of your vehicle via the SPS functionality link) allowing the user to set the car up to run efficiently with any fuel quality and in varying conditions. SPS software has the added benefit of a Data Acquisition function allowing the user to monitor certain engine sensors to efficiently set the adjustable settings. SPS software also gives the user the ability to store up to three preset configurations in the switch or alter settings via the OBDII port.
When purchasing select or select plus device, you will enjoy the additional benefits of a built in anti-theft program.
The anti-theft modes on the select switches allow you to totally disable your vehicle's ECU. It will leave the car totally inoperable even if the thief has the keys. Unlike other security devices there are no mechanical installation requirements such as wiring looms.
Once Revo performance software has been installed, you can purchase an optional select device and follow the simple and clear instructions supplied
To arm the anti theft program you select “anti-theft ON”, from your SPS, plug it into the OBD2 port found in the cockpit of the car, wait 5 seconds for an audible beep, remove your SPS device and the car becomes totally inoperable.
The car will start and idle, but when the accelerator pedal is depressed, the car will not advance pass idle!
To disarm the program you simply select “anti-theft OFF”, from your SPS device and follow the same procedure. The car will now return to standard (or your Revo performance program) and can now safely drive the car.
Please note: To benefit from the functions in our SPS devices, Revo performance software must be present in your vehicle.
MeanTdi
The Imposer Mod-whore-rator
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Re: The all new Revo SPS....
Post by MeanTdi »
Rabbit222 wrote:...The anti-theft modes on the select switches allow you to totally disable your vehicle's ECU. It will leave the car totally inoperable even if the thief has the keys. Unlike other security devices there are no mechanical installation requirements such as wiring looms...
Hey Rabbit,
How big is the unit? Can you put it in your jeans pocket and walk away?
Cheers Marco
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Hey Rabbit,
Cheers Marco
Hi Marco,
You can indeed :cool:
I just unpacked one and measured it up for you...
Length 9cm
Width 4cm
Thickness 2.5cm
MeanTdi
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Post by MeanTdi »
Rabbit222 wrote:Hi Marco,
Length 9cm
Width 4cm
Thickness 2.5cm
Thanks for doing that for me! That is incredibly small and user friendly!
Revo FTW :evil:
Marco
Current: Subaru WRX
Ex: VW Golf VR6
hubbly_bubbly
Car Model: Touran GTD
Membership No: 1793
Post by hubbly_bubbly »
Aaaah so I cant use it on my Kawasaki? :razz:
Will Mr Govender have one with him by the weekend? I would like to have a squizz?
Candy White 2007 Touran 1.9TDI Trendline
mebs
Car Model: GTI Ed35
Post by mebs »
This device will be the reason I eventually put REVO software..
//M Power
Looks the same as yours :hi:
MeanTdi
Car Make: Subaru
Car Model: WRX
Membership No: 1153
Post by MeanTdi »
mebs wrote:This device will be the reason I eventually put REVO software..
I agree with you. I am tired of fitting gearlocks, relocating ECU's etc...
@ Mr. Rabbit does this qualify as a VESA approved immobiliser?
Marco
Current: Subaru WRX
Ex: VW Golf VR6
That I'm not too sure about mate.
hubbly_bubbly
Membership No: 1793
Aaaah woops :) I cant see the pictures so I was assuming its ALL NEW :crazy:
sixteen10
Car Model: 2008 .:R32 DSG
Membership No: 1135
Post by sixteen10 »
As far as I am aware the car's ECU takes time to adapt to the software loaded ( around 500km if im not mistaken? ) , now if you activate anti theft mode and then come back to the vehicle and load up your REVO file again will the car need to adapt all over again or will it just get up and REVO? :type:
100ks
It will up and go :hi:
sixteen10
Membership No: 1135
Post by sixteen10 »
Rabbit222 wrote:100ks
We will be in touch :hi:
Awesum
Car Model: Tiguan
Membership No: 999
Post by Awesum »
So...Whats the diff between this and the cheap 1 you sold me?
2019 Tiguan 2.0TDI, R-Line
2019 Polo GTI
Ex 2013 Tiguan 2.0TDI
Ex 2016 Golf VII R, DSG
Ex 2015 Polo 6C GTI, DSG, Pure White
Ex 2014 Golf VII GTI, DSG, Tornado red
Ex 2010 Scirocco 2.0TSi, DSG; Candy White; Revo, 20" RS6 wheels; Coiled looow.
Ex 2010 Golf VI GTI Dsg, Tornado Red, 19's, Revo 2
Ex 2008 Golf V GTI DSG, Riding on 19"s
Ex 2007 Golf V GTI DSG
Ex 2002 Golf IV GTI
Ex 1991 Golf II GTi 2.0 16V
Ex 1991 Jetta II CLi 1.8 8V Exec
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
less than 100.... Mine adapted fully within 20 - 30km's of switching to the "C" setting the other night when i took on the big turbo scooby...
You gotta love SPS.. ;) REVO FTW!!
Current: 2005 E55 AMG
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 1998 BMW M3
hubbly_bubbly
Membership No: 1793
Awesum wrote:So...Whats the diff between this and the cheap 1 you sold me?
The package it comes in :geek:
RoadHaWg
Membership No: 731
Post by RoadHaWg »
AFAIK the Anti theft mode just kills the fuel pumps. So the car will not start. Use the SPS to Deactivate it and off you go. Not really fiddling with Maps.
Stuart
2006 Jeep Wrangler "Sarge"
1966 Splitty.
2014 KTM 1190 Adventure
No Mk1 ;(
Rascal69
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
RoadHaWg wrote:AFAIK the Anti theft mode just kills the fuel pumps. So the car will not start. Use the SPS to Deactivate it and off you go. Not really fiddling with Maps.
I put the Anti Theft on the other day... Car started but the accelerator did not work... then the car died :grin:
Ex: 1998 BMW M3
aslam
Car Model: MK6 GTi
Post by aslam »
Whats the pricing on these units ?
R2280
Kums
Car Model: Polo 9n3
Membership No: 1361
Post by Kums »
Rabbit222 wrote:R2280
is that with or without software?
9n3 polo
im only the pilot,vw did everything else
SPS unit doesn't have installation software. That will need to be downloaded from Revos website.
VWicked
Car Model: Golf 2 GTi
Membership No: 1492
Post by VWicked »
If you activate the anti-theft on one SPS, can another sps be used to deactivate it?
1992 Golf Mk2 VR6
2018 Golf Mk7.5 R
dazza
Car Make: VW and VW
Membership No: 1327
Post by dazza »
VWicked wrote:If you activate the anti-theft on one SPS, can another sps be used to deactivate it?
Probably as the SPS is not "Married" per say to ECU. Same way you can change setting on other peoples cars with your SPS
Darryn Van Rooyen
Current: 14 Amarok BITDI D/C 4Motion H/L Auto
Current: 1987 Citi Sport 1.6
Current: 05 Kawasaki 200KDX
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
SemiColon
I sparkle in the sunlight
Car Make: Volvo
Car Model: S40 T5
Membership No: 1641
Post by SemiColon »
:cry:
八拾六
