Polo tdi high idle issue... going to Hatfield Thursday :)
Neuk
Treasurer
Treasurer
Membership No: 806
Re: Polo tdi high idle issue... going to Hatfield Thursday :)
Post by Neuk »
OettingerTDi wrote:Just a thought...
My Jetta had a fast idle problem too, but at around 1200 r/min. It would happen at rondom, but particularly at start, but got worse to include hot starts too. It would burst into life with a cloud of soot and idle at 1200. With the Oettinger computer, pulling off and going round traffic circles was particularly interesting. :grin:
Turned out to be a faulty water temperature switch. The guage did not read 90 degrees as normal, slightly below. If you started the car at anything below a reading of 90 degrees, it idled at 1200.
Interesting Anton, because my TDi according to VAGCom and my RD gauge my Polo water temperature normally sits at aroun 80 - 81 degree's :wink: But a fualty water temperature sensor could affect idle as the ECU "believes" the car is cold and adjusts to warm up...
Cheers
Nic
kripstoe
Membership No: 1379
Post by kripstoe »
Neuk wrote:Interesting Anton, because my TDi according to VAGCom and my RD gauge my Polo water temperature normally sits at aroun 80 - 81 degree's :wink: But a fualty water temperature sensor could affect idle as the ECU "believes" the car is cold and adjusts to warm up...
Correct my if I'm wrong, but would a TDi warm up by idling faster? I know they only get warm by driving after cold start. The only difference I notice with a cold start is that the diesel consumption (1l/h down to 0.7l/h when cold) is higher for a while until it gets warm (0.4 - 0.5l/h).
Current: '21 Audi 8V S3 Sedan S tronic
Ex: '15 Mk7 Golf 2.0 TSI Performance Pack DSG®
Ex: '13 Mk7 Golf 2.0 TDI Comfortline
Ex: '10 6R Polo 1.6 TDI Comfortline
Ex: '06 9N3 Polo 1.9 TDI Highline
Ex: '98 6N Polo 1.8i Lux
Ex: '96 Chico 1.3... it was green
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Possibly true - A TDi generally cannot warm itself up by just idling, but I am not sure at what point it will start generating excess heat that can be used to warm up :wink: Also remember that at colder temperatures teh EGR will be open more, feeding exhaust gas back into the engine to help with warmup...
kripstoe
Membership No: 1379
Post by kripstoe »
True. Would be interesting then to hear from veedubbed what the consumption (l/h) indicates when the high idle issue manifests itself.
SoDub
Chairman
Chairman
Car Model: Seat Ibiza Cupra 20VT
Membership No: 1998
Post by SoDub »
hey guys.... at 800 revs which is where the idle sits now after it was changed to by the dealer I took it to : 0.6/0.7l
when the idle decides to sit at 1000 its exactly the same 0.6/0.7l
With the aircon on its at 0.9/1.0l at 1000 revs...
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
veedubbed wrote:hey guys.... at 800 revs which is where the idle sits now after it was changed to by the dealer I took it to : 0.6/0.7l
Mine is pretty much identical...
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
So took the car in to Frans this morning at Hatfield. Got a call now saying he has checked the car and the problem is electrical. Seems to be the wiring from the control unit to the alternator. They changed the control unit and car still did the same - So it must be the wiring causing the alternator to think the battery is low on charge- They have to rebook the car in with the auto elec at the dealer as he is fully booked for a while. They said its ok to drive the car like this until it goes back in. Shew! Im okay now that the car is in hands of peeps who know!
El Toro
Blossom
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
veedubbed wrote:So took the car in to Frans this morning at Hatfield. Got a call now saying he has checked the car and the problem is electrical. Seems to be the wiring from the control unit to the alternator. They changed the control unit and car still did the same - So it must be the wiring causing the alternator to think the battery is low on charge- They have to rebook the car in with the auto elec at the dealer as he is fully booked for a while. They said its ok to drive the car like this until it goes back in. Shew! Im okay now that the car is in hands of peeps who know!
Good to hear...
MK2 G60
Membership No: 388
Post by MK2 G60 »
The on booard electronics only see's 12.3v while all other ecu's see 13.7v.
So on board will jack up idle atuo to try chrge battery and supply current to other ecu's.
Why the other place did not see that.We took a look and saw the falt in onboard and then check rmvb.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
heheh G60 Golf - The other dealer had the car for 6 days. You guys had it for less than 2 hours and you found the problem easily!!!
After the other dealer insisted my car had a throttle body and they were going to change it I should have run to get my car out of there hehehe
El Toro
Blossom
kripstoe
Membership No: 1379
Post by kripstoe »
g60 golf wrote:Why the other place did not see that.We took a look and saw the falt in onboard and then check rmvb.
*sigh* No wonder so many people complain about VW service.
ree1
Registered for: 14 years 9 months
Car Model: 2018 320D
Post by ree1 »
Thanks 4 the update, now i can sort out my car
devZo
Car Model: Polo TSI
Membership No: 1395
Post by devZo »
ree1 wrote:Thanks 4 the update, now i can sort out my car
+1 :cool:
Polo TSI Highline DSG
ex:Polo TSI Comfortline
ex:MKVII GTI DSG
ex:MKVI GTI DSG CPi Tuned
ex:MKV GTI CPi Tuned
ex:Polo TDI Sportline
ex:VeloCiti 1.4i
Ex-Rides Thread
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
Hey guys. Got my car back today! Missed it for a few days :) All is back to normal. Big thanks to Morne and Frans at Hatfield VW for the great service. From what I understand(I need a course in engine jargon) it was the earth straps on the harness that were acting up so that's what caused the car to read less voltage back from the alternator. All is sorted and the car is happy!
El Toro
Blossom
MK2 G60
Membership No: 388
Post by MK2 G60 »
The onboard electronics has 6 power supplys and a number of earths.
The power supplys was there but not the one earth so the ecu only read 12.3v.
The ecu then would tell the engine ecu to pick up idel on the car so the alt can charge more.
The new systems drive me up the wall sumtimes.
G60 16V GOLF
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
veedubbed wrote:Hey guys. Got my car back today! Missed it for a few days :) All is back to normal. Big thanks to Morne and Frans at Hatfield VW for the great service. From what I understand(I need a course in engine jargon) it was the earth straps on the harness that were acting up so that's what caused the car to read less voltage back from the alternator. All is sorted and the car is happy!
BAM - That just happened :crazy: Morne and the team at Hatfield VW Bryanston are legends :wink:
ree1
Post by ree1 »
Good news, howmuch will it cost
sanelenanti
Registered for: 6 years 1 month
Post by sanelenanti »
Guys, I have a similar problem with my Polo Classic 1.9 tdi. When I start the car in the mornings the rpms sit at 890-900 for few seconds then go up to 1000. I have been to 2 different places for diagnostics where the 1st one couldn't find anything and the second one said calibration needed to be done, did the calibration and the rpms are now at 980 but it is still doing the same thing of starting slow and then rev up after few seconds. Please assist me guys I'm still new to the family and this is now frustrating. I'm in Pretoria.
SoDub
Chairman
Chairman
Membership No: 1998
Post by SoDub »
Hi sanelenanti! Please see what G60 Golf diagnosed mine as. It seems to be an earth issue that causes the higher idle.
El Toro
Blossom
