Done a new installtion. Properly done is an understatement. (evrythn new)
Car is mapped and running perfectly fine.
then all of a sudden the car dies. when it doesnt wana start the dicktator is powered (red light on), but the other two lights are off (green and yellow), and fuel pump primes still.
After one or two minutes pause, the other two lights come back on (yellow and green)the car fires up again, n behaves normal.
then wheter hot or cold it just dies intermittantly. above symptoms. then starts again. changed and fitted new bosch relay (from dicktator to f pump) thinkn mayb the new relay frm dicktator b faulty.
did a test whilst idling, it does the same thing.
nevr missd a beat whilst on the dyno??
Is ther something im missing? like a faulty sensor (temp, map sens in box) a failsafe mechanism in the software?
Im suspecting the mangement box is faulty, altho it is a week old?? so gona load a map on another box and try tommorw.
Just thought id share my experiences, just to see if anyone else had similar issues..
Btw, is a dicktator std, dizzy pickup, map sensor, and car is golf 16vturbo.
Dicktator issues
- Registered for: 20 years 7 months
- Car Model: MKV Gti
Re: Dicktator issues
Whats the condition of the tp100 module ? or could be the coil. The yellow and green light should only flash when you crank the motor.
- Registered for: 19 years 10 months
Sorry, thats what i meant, the green and yellow light dont come on when i crank it. (when it doesnt wana start)
newish tp100.. hmm, will check it aswell tomorrow.
coil is original gti16v, maybe its the coil??
- sjs
- Car Model: Citi & Megane RS 275 Final
- Membership No: 1315
Maranou once wrote that Dicktator ECUs like to fry tp100s. Hope you come right.
I suspect its the module. Check the earth as well, from tp100 module pin 2 to earth on the body.GtiTuned wrote:Sorry, thats what i meant, the green and yellow light dont come on when i crank it. (when it doesnt wana start)
Hi did u ever find the problem? I have the same problem. Pls email me. Don't know what to do anymore. When I plug my laptop in, It doesn't read anything, it reads that management is on but nothing else
Jacobsd123@gmail.com
I suggest you contact dicktator themselves and see if they can test the unit for you.
https://www.dicktator.co.za/contacts.html
