PD130 Injectors
PD130 Injectors
Hi everyone,
Im looking for a set of PD130 injectors. Does anyone knows where i can find one for a good price?
Thanks.
William
Thanks.
William
Current ride: 2008 Polo GTD. Dimsport remap, FMIC, K&N Performance air filter, De-Cat Exhaust. 105Kw, 360Nm
My ride's thread:http://vwclub.co.za/phpbb3/viewtopic.php?f=11&t=98829
- Wheel Whore
Re: PD130 Injectors
What are PD 130 injectors? what are they off? If they are std Polo ones I have a set for R400 for all 4.
082 8766837
082 8766837
Re: PD130 Injectors
PD 130 injectors are the ones that are fitted 1.9 TDI sportline engines... Which one do you have?
- Wheel Whore
Re: PD130 Injectors
Sorry....got the petrol 1800 polo injectors. Hope you come right.
- Post Whore
- Membership No: 1343
Re: PD130 Injectors
iirc they're R13k each
Re: PD130 Injectors
What the hell??? So that would work out to R52000 for the set of 4. That's f@rkin expensive... At least now i know im not getting new ones... Its impossible to get R52000 out of a student budget!
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
Re: PD130 Injectors
W - T - F !!ruan9n wrote:iirc they're R13k each
(makes mental note to go buy injector cleaner 1st thing in the morning)
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- Neuk
- Treasurer
- Membership No: 806
Re: PD130 Injectors
PD130 injectors are around R7k - R9k a piece from what I remember, so not cheap at all Most guys looking for extra fueling on PD's go for LPG injection, while the older VE engines you could get larger nozzles and an uprated fuel pump, but not sure if this would work on the PD's...
Cheers
Nic
P.S. A clutch and flywheel replacement on a PD130 Polo is R18k - R19k
Cheers
Nic
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: PD130 Injectors
Neuk wrote:...P.S. A clutch and flywheel replacement on a PD130 Polo is R18k - R19k
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
Re: PD130 Injectors
What's LPG injection? and out of interest what does iirc means?
Sorry if the questions are a bit stupid guys. im new to this.
- Neuk
- Treasurer
Re: PD130 Injectors
LPG - Liquid Petroleum Gasserwill wrote:What's LPG injection? and out of interest what does iirc means?
IIRC - If I remember correctly
You could also use NOS or Water/Meth...
Re: PD130 Injectors
Thanks Nic .LPG - Liquid Petroleum Gas
Im interested by the Water/Meth kit but i think i'll do it as a last mod. Right now i'll try and find out whether i can source the injectors from overseas because it seems like they are a lot cheaper there. I REALLY want to hit the 140kw mark, even if i have to spend the next ten years at it
- Neuk
- Treasurer
Re: PD130 Injectors
Cool - What engine do you have? PD 100?serwill wrote:Thanks Nic .
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
Re: PD130 Injectors
Everything about the TDIs is ridiculously expensive.
Turbo replacement at agents: R23000
Catalytic convertor at agents: R15000 odd...
- Neuk
- Treasurer
Re: PD130 Injectors
Yep, ridiculous, but luckily most parts are interchangeable between the models As far as I know, the PD injectors are fairly similar if not exactly the same between the smaller PD engines...Sinbad wrote:Everything about the TDIs is ridiculously expensive.
- Sinbad
- Post Whore
Re: PD130 Injectors
sssh, we need to start a similar legend for PD160 injectors to what exists for VR6 injectors.Neuk wrote:Yep, ridiculous, but luckily most parts are interchangeable between the models As far as I know, the PD injectors are fairly similar if not exactly the same between the smaller PD engines...Sinbad wrote:Everything about the TDIs is ridiculously expensive.
Then I can part my car out for more than it's worth in one piece
- Neuk
- Treasurer
Re: PD130 Injectors
Oops Will be a tough act to follow though, I heard they used the VR6 injectors for the Bugatti Veyron, but they kept breaking sideshafts, so went with .:R36 injectors instead...Sinbad wrote:sssh, we need to start a similar legend for PD160 injectors to what exists for VR6 injectors.
- Sinbad
- Post Whore
Re: PD130 Injectors
I hear it's running detuned caravelle pistons as wellNeuk wrote:Oops Will de a tough act to follow though, I heard they used the VR6 injectors for the Bugatti Veyron, but they kept breaking sideshafts, so went with .:R36 injectors instead...Sinbad wrote:sssh, we need to start a similar legend for PD160 injectors to what exists for VR6 injectors.
- Neuk
- Treasurer
Re: PD130 Injectors
Yes, they added a bit on the top of them as using the 2.6l ones would mean a displacement of 23.87l...Sinbad wrote:I hear it's running detuned caravelle pistons as wellNeuk wrote:Oops Will de a tough act to follow though, I heard they used the VR6 injectors for the Bugatti Veyron, but they kept breaking sideshafts, so went with .:R36 injectors instead...Sinbad wrote:sssh, we need to start a similar legend for PD160 injectors to what exists for VR6 injectors.
- Post Whore
Re: PD130 Injectors
Funny MOFOS! Would morne know the max BHP a pd100 injector can handle? 200-220 is what I heard 130 injectors can handle before they're maxed!
Sinbad mentioned something about my dutycycle when reviewing my logs and thinks that refers to injectors.
Re: PD130 Injectors
I have the PD100 engine and i want to do the turbo upgrade. But since the PD 100 can only handle about 150-165 hp (or so i heard), i need to change my injectors.Neuk wrote:Cool - What engine do you have? PD 100?serwill wrote:Thanks Nic .
- Post Whore
Re: PD130 Injectors
Hence there is no need to upgrade the turbo because the injectors wont be able to fuel the requested volume with upped boost and fueling.serwill wrote:I have the PD100 engine and i want to do the turbo upgrade. But since the PD 100 can only handle about 150-165 hp (or so i heard), i need to change my injectors.Neuk wrote:Cool - What engine do you have? PD 100?serwill wrote:Thanks Nic .
Re: PD130 Injectors
Yeah but that's the whole point of getting PD 130 injectors . Providing for the upped boost level and fueling.ruan9n wrote:Hence there is no need to upgrade the turbo because the injectors wont be able to fuel the requested volume with upped boost and fueling.
Oh by the way, could you get ahold of those guys ruan?
- Neuk
- Treasurer
Re: PD130 Injectors
He could probably take a guess at it...ruan9n wrote:Funny MOFOS! Would morne know the max BHP a pd100 injector can handle? 200-220 is what I heard 130 injectors can handle before they're maxed!
If I understand correctly, the duty cycle refers to the length of the injection cycle of the injectorruan9n wrote:Sinbad mentioned something about my dutycycle when reviewing my logs and thinks that refers to injectors.
- Neuk
- Treasurer
Re: PD130 Injectors
I am still not entirely convinced there is that much difference between the PD injectors on the smaller 4 pot engines, but I'll do some research...ruan9n wrote:Hence there is no need to upgrade the turbo because the injectors wont be able to fuel the requested volume with upped boost and fueling.serwill wrote:I have the PD100 engine and i want to do the turbo upgrade. But since the PD 100 can only handle about 150-165 hp (or so i heard), i need to change my injectors.Neuk wrote:Cool - What engine do you have? PD 100?
