Rev counter (dicktator content)
- Velofox
- Registered for: 16 years
- Membership No: 1314
any body running dicktator with the new type dash..... my rev counter is not working
Current Rides
1994 2.0 16v FoxT - Lexy
1998 2.0 8v Mk3 GTI - Liesy
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
- Colonel
- Membership No: 1041
Re: Rev counter (dicktator content)
where you taking the signal from
- Velofox
dicktator has an output wire.UDC wrote:where you taking the signal from
but im not sure which wire is the 1 for the rev counter on the std harness (Velociti 1 installed)
Current Rides
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
- Colonel
ok, I'm not clued up on the velo harness, maybe pm Ted or Macman on the forum.
- Velofox
just thought about it and i think it should be running into the Boardnetz box and then out to the clusterUDC wrote:ok, I'm not clued up on the velo harness, maybe pm Ted or Macman on the forum.
Current Rides
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
- Car Model: Amarok V6
- Membership No: 664
Not 100% sure of the velo but my reasoning tells me that the rev counter will pickup it's signal from the (-) on the coil the Dictator also connects to the coil at the same spot .. at least thats how my Jetta is wired and then from there to the cluster.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Velofox
the normal cluster i can wire up from scratch, i just need to confirm if i should trace the - wire... (ok i think i just answered my own question here) to the boardnetz box and see if it goes to the cluster, if so i think i know why my rev counter does not work.joggiep wrote:Not 100% sure of the velo but my reasoning tells me that the rev counter will pickup it's signal from the (-) on the coil the Dictator also connects to the coil at the same spot .. at least thats how my Jetta is wired and then from there to the cluster.
just need to double check if i should wire directly to the cluster or let the current flow through the control unit as there might be some chip that controls the voltage or something... (like the BMW sound system's)
Current Rides
My Inspiration
16vT Engine Pics
My Inspiration
16vT Engine Pics
- Old School Quintin
- Car Model: MK1 16v
any update on this did you get the rev-counter to work
im struggling with this thing
2008 VW CitiRox
Abf 45mm ITB
Under construction
Seeking ponies
Abf 45mm ITB
Under construction
Seeking ponies
Chat to PapaJo on forum - he has a new velo dash in his caddy.
Running 16v with throttles on dictator.
AC
AC
- Registered for: 14 years
Pin 4 blue/grey wire on Dicktator connects to centre wire on distributor plug feeding into cluster.Old School Quintin wrote: ↑Thu Oct 18, 2018 11:25 am any update on this did you get the rev-counter to work
Are you running Dicktator std? The signal wire(centre wire) on dissy plug is wired from dissy centre wire to pin 1 green wire on Dicktator. The other part of the signal wire going to the inside on harnass is then connected to blue/grey wire pin 4 on Dicktator.
And so Mr Dictator speaks ..
So last night I got it sorted
I was struggling with the rev counter in the car, on the dictator everything was good.
Its a 2008 citirox with a ABF motor runnig on STD dictator, on the dictator side nothing is wrong and I ended up runnig an aftermarket rev counter from the tacho wire that comes from the dictator and worked perfectly, just irritated the living crap out of me
So last night what I did after reading the forum the hole day
From the plug that is currently in the dizzy (Dictator loom) I took the middle wire (signal) opened the isolation and place a "separate" wire on it , I then took the original dizzy plug that was left behind from the original loom (as its still in the car) and connected the "separate" wire to the middle wire (signal) of the original dizzy plug. Now all is working and for the time in 4 years i have a proper rev-counter
2008 VW CitiRox
Abf 45mm ITB
Under construction
Seeking ponies
Abf 45mm ITB
Under construction
Seeking ponies
Perfect!!Old School Quintin wrote: ↑Fri Oct 19, 2018 10:38 am So last night I got it sorted
