TDI INJECTOR UPGRADE
Neuk
Treasurer
Treasurer
Membership No: 806
Re: TDI INJECTOR UPGRADE
Post by Neuk »
MeanTdi wrote:@ Nerville: Bigger injectors could provide a better spary pattern but then you would need to up the next link in the chain - the injector pump and so it goes on.
Don't forget that when replacing a PD injector, you are in effect replacing a pump as each PD injector is a pump itself :wink: You may need to upgrade the main fuel pump from the tank or the pump in the bay as well though...
MeanTdi wrote:I think that the turbo would be the next logical upgrade after a chip, intercooler and exhaust. Injectors only if you skip a stage and fit a turbo two stages up ...and on it goes
I would rather have too much air than fuel to be honest, as it is easier to cut back on boost to meet the fueling requirements, than to ru na turbo ragged the whole day, as they seem to blow more often than injectors do...
Cheers
Nic
Moolla420
Registered for: 5 years 11 months
Car Model: Polo 9n 1.9 tdi
Post by Moolla420 »
I just would like to know if the cupra 1.9 tdi injectors will fit on a 2006 polo 9n 1.9 tdi?
I do understand that the standard polo injectors are pd130 and the cupra is pd160?
I have followed all the posts here and I do get what you guys are saying about the flow rate through the injectors, would you be able to control these things from the software?
Ashveer03
Post by Ashveer03 »
It will fit. And fueling can be controlled by the original ecu - speak to a tuner regarding that
MarshallGTi
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Post by MarshallGTi »
PD130 and PD160 use the same injectors dont they?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ashveer03
Post by Ashveer03 »
Well the part numbers are different, im sure the "cc" is also different
