Page 1 of 3
How cann I diy an intercooler spray?
Posted: Mon Jan 26, 2009 8:08 am
by ruan9n
I have an idea of sort of running waterpiping from the window washer bottle to nozzles at the front of my FMIC, to spray on as to lessen heatsoak or cool the charge even more!
How would I do this though?
Re: How cann I diy an intercooler spray?
Posted: Mon Jan 26, 2009 9:00 am
by Polo05
Speak to G5 GP aka Mo, AFAIK, he has this setup on his V GTI.
Posted: Mon Jan 26, 2009 10:49 am
by ruan9n
What I want to do is SIMILAR to WMI but just not in the outlet boostpipe! Just sort of a system that sprays water onto the cooler itself! Something with 3 jets should suffice! Had a few hard runs last night and I mean shifting at 4k rpm in a tdi
Bought a bottle of valpre still for my cooler and just chucked it over it! Steam on the inlet side coz it gets lekker hot!!!
Posted: Mon Jan 26, 2009 12:06 pm
by JVR
I believe you can fit 6 irregation type sprayers, 3 at the top and three at the bottom. Then either fit a second water tank and pump or use the current setup with a valve. If you like i should be able to design you a module that will automatically spray when the charge temp exceds xx'C.
Posted: Mon Jan 26, 2009 7:42 pm
by Titus
JVRDesign wrote:I believe you can fit 6 irregation type sprayers, 3 at the top and three at the bottom. Then either fit a second water tank and pump or use the current setup with a valve. If you like i should be able to design you a module that will automatically spray when the charge temp exceds xx'C.
Oi!, well then what you still doing here.. get cracking and make one
certainly does a help a bit, particularly on these hot days when my boost goes for a ball of crud
i would certainly be interested in one
Posted: Tue Jan 27, 2009 8:03 am
by JVR
Give me the temp specs and such where you would like it to operate and i can do it no problem...
Posted: Tue Jan 27, 2009 11:03 am
by yosh
Turbo Toys in boksburg has an IC sprayer for approx R300 and you simply connect your pump or washer piping to it and you are sorted...011-894-8080 or Bruce 082-659-7848
Posted: Tue Jan 27, 2009 11:15 am
by ruan9n
yosh wrote:Turbo Toys in boksburg has an IC sprayer for approx R300 and you simply connect your pump or washer piping to it and you are sorted...011-894-8080 or Bruce 082-659-7848
Thanks a lot for this!!!!!!
Posted: Tue Jan 27, 2009 11:24 am
by Stry
Why not simply mount 2 X bike fans on the inside (if there is any space).
They are very slim and dirt cheap. Simple switch or temp sensor should be able to switch them on and off even before you reach temp where you require water.
Foxter's dad has a similar setup on his Musso running a Merc Kompressor motor. Seems to work well....
PS. Bike Hospital sell those fan at +- R200 each. Look at the Suzuki TL fans. They are nice and thin.
Stry
Posted: Tue Jan 27, 2009 11:27 am
by ruan9n
Thanx man but I think water spray on the cooler is the best option. Spraying the water onto the front of the cooler whilst driving, pushing the water through the cooler thus cooling the cooler itself and the charge even more!
Posted: Tue Jan 27, 2009 11:39 am
by vitchie
I agree water will have a better effect, especially when the mist is fine enought so that it evaporates as soon as it hits the cooler, that will cool it down significantly becuase of heat transfer that goes along with the phase transition
Posted: Tue Jan 27, 2009 11:46 am
by ruan9n
Vitchie- will a mist have an overall better effect than lets say just spraying it wet?
Posted: Tue Jan 27, 2009 11:58 am
by vitchie
I'm no expert, but yes I think so. I read it somewhere but can't remember where now. It has something to do with the cooling effect a liquid has when it changes to gas. Thermophysics...
Posted: Tue Jan 27, 2009 12:05 pm
by ruan9n
aaahhhh I see! Liquid could/would warm up on the already hot fmic BUT a mist is a gas and wont
Posted: Tue Jan 27, 2009 12:24 pm
by 1.6carbster
Stry wrote:Why not simply mount 2 X bike fans on the inside (if there is any space).
Stry
Can i please have Bike Hospital's number, Renier!
Posted: Tue Jan 27, 2009 12:36 pm
by vitchie
ruan9n wrote: aaahhhh I see! Liquid could/would warm up on the already hot fmic BUT a mist is a gas and wont
No i don't think that is it. Mist is still liquid, but smaller drops will evaporate faster than bigger drops, and the largest heat exchange effect occurs upon evaporation
Posted: Tue Jan 27, 2009 1:05 pm
by ruan9n
Thanks mate
Gotta love your signature
Posted: Tue Jan 27, 2009 1:44 pm
by 1.6carbster
ruan9n wrote:Thanks mate
Yup, that bird, and Eedubz's photographic skills at the Jamboree! Pure bliss
Posted: Tue Jan 27, 2009 3:33 pm
by Jueshen
hi Guys,
ive searched on this before and lots of the guys on the overseas forum says it doesn't make a noticible difference if at all, search it before u outlay the cash, also depends when u spray it, most of them say spray the ic befor a run not while you on a run... most of the guys with polo's just remove the rear wiper spray nozel and bring it to the front if u want to bring cost to 0
also to cool the ic down enough you probably need a big water tank...
i think it was in the AU forum the guys had proper measured readings of intake temps of this, without the spray and with it.
go check it out on the vwwatercooled site
Posted: Tue Jan 27, 2009 3:44 pm
by 1.6carbster
Jueshen wrote:hi Guys,
Thanks bro. makes sense though, as you'd have to spray liters to really cool it down
this might work:
and then THIS: notice how cold the vapour is...its cooled down in some way
Posted: Tue Jan 27, 2009 3:55 pm
by joggiep
1.6carbster wrote:Stry wrote:Why not simply mount 2 X bike fans on the inside (if there is any space).
Stry
Not sure of the number but I got a TL 1000 fan for the Jetta there a while back for R200
It's in Schoeman street just after Potgieter Street crossing sits on the left, a little hidden away as you have to walk down a type of ale to get to the shop.
Posted: Tue Jan 27, 2009 4:39 pm
by Esham
1.6carbster wrote:Jueshen wrote:hi Guys,
this might work:
Are you sure thats not nitrous being used to cool the IC?
Posted: Tue Jan 27, 2009 5:30 pm
by ruan9n
Aaaah damn now i'm being confused, I mean it must cool it down! The cooler must be better off with some sort of water mist spray than without it
Posted: Wed Jan 28, 2009 9:31 am
by gambit
Posted: Wed Jan 28, 2009 10:19 am
by BatteryWorldPtaEast
I have built a unit for this with a 2 litre water bottle with a switch that spray when at WOT and it makes a differance ,the 2 l just dont last so im busy surching for a big water bottle from any car that can take 8+ litres ,the 2 lasts about a trip from pta to jhb.
Another thing is ,you can only use 2 misters ,more and the pump just leaks the water no mist.
Another thing is that you can mix the water with some cind of alcohol that makes it vaporate quicker and cool better.
