How cann I diy an intercooler spray?
mika1803
Car Model: 07 PGTI
Membership No: 3089
Re: How cann I diy an intercooler spray?
Post by mika1803 »
Volkspares has intercoolers with incorporated CO2 bars, how would that work? Shouldn't the nozzles be fitted as far foward as possible so that they have the most time to cool before hitting the cooler?
The yaris has an electric aircon pump, how bout using something similar to charge the intake charge
Some people are wise, then some are just other-wise
08 Audi A4 2.0 tfsi S-line
Ex:07 Merc E63 AMG
Ex:11 6R PGTI
Ex:10 Silver Leaf Jetta 2.0 TSI-K04
Ex:12 Brilliant silver Jetta TSI comfortline, 9j 18 inch BBS wheels,custom intake, eibach
Ex: 07 Flash Red Polo Gti, stage 1 revo software, 63 mm downpipe, custom intake,G4 GTi.:R wheels,boost gauge
Ex: Alfa Romeo 156 2.5 v6 24v, intake, de-cat exhaust, GTA wheels
Ex: Tazz 130, Rsi wheels, some sound,
Florida, Woes Rand
ShaneTdi
Car Model: Golf Mk6 GTI
Membership No: 1735
Post by ShaneTdi »
G-Spot wrote:The power you use to run the fan will cancel out the gain you get, i would think
I was thinking something small like a 9" fan on the standard IC.....
Shane Skipper
Current: Scarface
The Ex: Golof
The Ex: Taz
Abnormal
Registered for: 20 years
Membership No: 848
Post by Abnormal »
shaneskip wrote:
Nerville wrote:
shaneskip wrote: What about putting a fan on the standard IC?
for cooling while standing still?
Well a fan can spin constantly so I was wondering if it would have a better effect than just standard vents.....
Doubt the fan will be able to move more air than the airflow when driving, they may even be causing a restriction.
\Oo) \ _w_ / (oO/
GTiDon
Membership No: 1161
Post by GTiDon »
Maybe use boost pressure into the water tank instead of a pump.. With a valve, or even no valve the vacuum would not suck water back if the tank/air inlet is on top.
Ive seen this idea for water injection..
You will have to find a way for the sprayers not to leak when there is no pressure, unless you have the water tank lower than the sprayers
GTiDon
Membership No: 1161
Post by GTiDon »
Anybody think this idea is feasible?
Any experience with sprayers? irrigation sprayers, will they spray/mist nicely with 0.5 bar pressure?
PoLonY
Registered for: 14 years 9 months
Car Model: A8
Membership No: 1997
Post by PoLonY »
gtidon wrote:Maybe use boost pressure into the water tank instead of a pump.. With a valve, or even no valve the vacuum would not suck water back if the tank/air inlet is on top.
one way valve solves that issue completely
Fransua
Car Model: A6 V6 TDI
Post by Fransua »
I have done this on a stage 3 OPC. Extra water bottle, water pump, valve, piping, switch and 2 sprayers.
It makes a huge difference on hot days. Standing still or driving. Kills the heat soak instantly with 1 second of spraying. Aircon also cools down instantly. 2L bottle lasts about a day with some hard driving. It frustrates me to drive without it.
CO2 will obviously work better but very costly to keep the bottle full. I've also done allot of reading about it and after so much debate I decided to try it for myself and I recommend it for any turbo car. cheap and effective
XTREME RIDEZ
Automotive Customizing, Spray painting & Suspension mods
www.xtremeridez.co.za
Tidy
Registered for: 14 years 5 months
Car Make: Suzuki
Car Model: Jimny
Post by Tidy »
heres some results of D.I.Y intercooler spray pimped off the Pug club.
some of you may remeber I made an intercooler spraying system about 18 months or so ago, but I removed it when I had the bigger intercooler installed. I know Franky now has made 1 for himself too.
Well, tonight I decided to make mine again. The results are astounding..intake temps drop up to 6C BELOW ambient temp. Keep in mind that I'm using the stock intercooler again, so with a bigger intercooler I would imagine that the results would be even better
Suzuki Grand Vitara (Pearl White) 1.5'' Lift, 17" Magnums, Pirelli Scorpion ATR's
Kawasaki Ninja ZX6R 636 (Custom Saturn Black)
Suzuki Jimny (Pearl Black)
Peugeot 207 GTI (Diablo Red)
VW Polo 9n3 Sportline (Black Magic)
VW Polo 9n Classic 1.4 TDi (Silver Bird)
Mazda Astina 180SE 16v (Gunmetal)
Sinbad
Registered for: 16 years 5 months
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Post by Sinbad »
And by one-way valve you mean check valve ;)
PoLonY
Car Model: A8
Membership No: 1997
Post by PoLonY »
yes yes
:grin:
