Hi
How do I drain the gear oil...? I plan on replacing the crappy oil which was used when the gearbox was replaced....
Also which would you suggest Castrol SMX or Castrol BOT 130 (not sure if thats the name or something)..
Thanks in advance
Cti gear oil
Not to Sure of the size but like mad driver said at the bottom of your gb there is a alan key (spelling) on the diff. Loosen this to drain the oil and retighten.
I will def recommend Castrol SMX - changed mine about 3 weeks ago - smooth gears like you cant believe. You gonna need 4 pints (2L) for your gb.
