Keihin Carb as used in the Citigolf
- jetta786
- Car Model: MK5 JETTA COMFORTLINE 2LTR
- Membership No: 1715
Re: Keihin Carb as used in the Citigolf
what has happened to this topic?
HI Guys
Im looking at this for some guidance, I have a 1600 auto and the car has been struggling for the past week when going uphill, it would loose power and then die,it can start immidiatly afterwards but then all the way to the top it feels as if the car is not getting enough fuel.
I replaced the petrol pump, but the problem seems to still be there, I was told ontop of the carb is a screw ( which I don't see on the mentioned pics ) this is supposedly to adjust the needle and see to either increase the fuel into the float chamber or decrease.
No I would like to know what might the problem be on the car, and also how many turns do I need to turn either clockwise or anti to adjust the amount of fuel going into the chamber
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
Subscribed
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
- jetta786
if your car start immediately, then there is certainly fuel. if you insist on adjusting the float, turn anti-clockwise. not too much. i would check the timing first.
- MikesDub1984
- Registered for: 11 years
- Car Model: 2.0l 8valve Citi
Hi All,
I know this thread is old but I as I struggled with this model carb for years and eventually found out what M and O is for I am going to share. As I understand it, it is vacuum enrichment. Meaning throttle position doesn't change but as you go up an uphill the vacuum increased as there is more load on the engine. These two the together help enrich the mixture. M is the valve and O is the jet. This is what I've deducted after reading hundreds of articles over the years, I might be wrong, but if I am, please post the correct answer.
What happened to the PDF file that was going to be posted?
- jetta786
I am so stubborn and stupid when it comes to my car, that Ive fiddled so much with the carb. (I dont recommend that any non mechanic do this unless your aim is to get grey hair or lose the hair you have)
In the beginning, I really relied on this thread when I was rejetting and I got the car running based on what I found
But this fills in the blanks: https://workshop-manuals.com/volkswagen ... ttor07.78/
Worth a look if you were wondering about this carb
Any one know how to tune these carbs
Read this threadMohammedkr wrote:Any one know how to tune these carbs
- Car Model: VW MK5 GTi
Sorry guys I know it's an old thread. Any Ody know how to check if my second stage is actually working? Recently bought a MK2 Jetta CSX with a 1800 carb motor. It drives really nice but feels like after 4000RPM it's hesitating. If you really driving Ng it hard from 1st gear it's got power up untill 4000RPM and then nothing.
Second stage has nothing to do with RPM, and everything to do with pedal position.Melvin Shale wrote:Sorry guys I know it's an old thread. Any Ody know how to check if my second stage is actually working? Recently bought a MK2 Jetta CSX with a 1800 carb motor. It drives really nice but feels like after 4000RPM it's hesitating. If you really driving Ng it hard from 1st gear it's got power up untill 4000RPM and then nothing.
Remove the air filter assembly from the carb, lean over the carb and look down the barrel, turn the throttle linkage to the full open position and observe if both butterflies open.
Remember they are not synchronous, the first stage opens to 3/4 before the second stage starts opening. Both butterflies should be fully open at full throttle.
I don't think your problem is carb related as the car performs fine at lower revs.
Look for vacuum leaks and also inspect the carb base gasket for cracks.
- ICE King
Have you checked ignition timing?
Stock Carb 8 valve peak power is 5000 - 5500rpm's ,there's not much left after 4000rpm's.
to add to the list of things to check:
1. Get someone to step on the accelerator pedal in the car to make sure throttle opens fully on the carb.
2.Could also be a leaking carb base plate.
3. Spark plug gap
3. Spark plug gap
- ICE King
Some carb cleaner might just do the trick if you haven't tried it already.
- JohnnyD
- Car Model: Citigolf Shuttle
I found out on another site what P is for, does anyone know where it connects to? Mine broke and I have no idea where it connects and now with the colder weather I can't pull the choke too far as engine wants to die then. Tried plugging it but made no difference.
P = Vacuum unit fortifier for choke. When applying a vacuum to the outlet o (eg, through the mouth slightly lifts the valve if choke fortifier is pulled (located in the cabin). If the vacuum drops at this point valve closes immediately. This system is needed in order to slightly lift the flap fortifier immediately after a cold start.
- Car Make: mk1
- Car Model: GTX
On my car it is attached to one of the nipples found on the non return valve situated between the inlet manifold and brake boosterJohnnyD wrote: ↑Mon May 17, 2021 9:20 am I found out on another site what P is for, does anyone know where it connects to? Mine broke and I have no idea where it connects and now with the colder weather I can't pull the choke too far as engine wants to die then. Tried plugging it but made no difference.
- dazza
- Car Make: VW and VW
- Membership No: 1327
These carbs can drive you dilly when they not working as you would like but once sorted they just work a treat.
I recently replaced pretty much my entire fuel system and after completion I had some issues with my carb. After plenty fiddling and getting it to run and idle half decently it is now running great again but it needed CO2's set to get it running perfectly again.
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
