CAM DURATION ON STD VW CAMS <OEM>???
-CC-
Post by -CC- »
Guys
I need to find the cam duration for the
"G" -253 deg (?)
"B"-?
"A"-?
"L"-?
"D"-?
cams.
Can anyone assist? GOOGLE hates me. :(
rsarlie
Registered for: 18 years
Post by rsarlie »
A cam is same as g 25* degrees
L and K cams are the same i think,motly found on carb golfs,degrees 23* im not sure,dont know about the others
Golf GT
2.0l
288 cam + gassflow
viper 4-2-1 branch
57 mm powerflow pipe,dicktator efi
power : 110hp 161nm atw@KAR
In the wings : slow ass polo 1,4 tdi !
1.6carbster
Car Model: 330i (E90)
Post by 1.6carbster »
A cam is NOT the same as G, A=238 deg,with 10 odd mm of lift, G=252 deg, with 11.? Odd mm of lift
2005 BMW 330i (E90) The Beef
1999 Audi A4 1.8T (AEB) the tank
1992 VW Citi 1.8i MP9 R.I.P.
1973 Mini Cooper S sold
Mk1-8valve
Post by Mk1-8valve »
@1.6carbster, what diff. did the G-cam you had before make to your power and drivability, Where was the power band?. I'm interested to know. Thanks
Mk1 1.8i 8v MP9 :-)
De-trumpet Airbox (std. filter)
50mm TNT F/Flow
40mm N-Force Drop
Life Tail Lights
Future mods:
272/6 Estas Cam
2E 2L 8v motor
1.6carbster
Before the G cam: car ran out of steam @ 4800rpm.
With G cam: power started @ 3000rpm,and peaked @ 5300rpm. Consumption was 10km/l even while gunning the car.
With the 268/272 split cam. Power REALLY kicks in @ 3600rpm and still HAULS @ 6200rpm...
GolfPlayer
Cam specs...
Post by GolfPlayer »
G cam has same specs as A cam, with only difference being the A is advanced about 4 degrees compared to G. A works well on all stock 1.6 8V motors. G is OK for carb 1800, std on K-Jet 1800 motors. There, upgrade to 286/276 for better results. B is the same as A, but with the bearing journal on
cam cap nr 4, in stead of oil sprayer. L is actually some diesel cam that VW chose for the early 1.6 and 1.8 carb motors. Almost OK on 1.6, but runs outta steam at about 4500 rpm on 1.8. Useful for one thing only, and that's as a paperweight or doorstop. Rubbish. Useless. K, I can't comment on, except that a solid lifter K can be cut up to 276h. I had one of those in my old GTI 3.
D is stock 1.6i cam. Not tooooo bad, but A still works better. And oh yeah! Best of luck fitting a G into an 1.4i MP9 engine. Makes OK-ish power, not spectacular. But idles quite kuk. Even Unichip can't sort it, maybe an ECU reflash could.....
rsarlie
Post by rsarlie »
read
http://www.vwclub.co.za/vwforum/viewtop ... t=cam++cam
according to them a and g are the sam,for interest sake i put a standatd 2.0l mp9 cam in today and it had 250 written on it
Golf GT
2.0l
288 cam + gassflow
viper 4-2-1 branch
Mk1-8valve
G-cam
Thanks 1.6carbster, so a G-cam should work nicely in my 1800 carb motor, power coming in early at 3000rpm until 5300rpm. I hoping it will give me more low-down torque and better drivability.
Mk1 1.8i 8v MP9 :-)
50mm TNT F/Flow
40mm N-Force Drop
Life Tail Lights
Future mods:
272/6 Estas Cam
2E 2L 8v motor
1.6carbster
Yeah it'll work leker in your car,but a 268,for driveability's sake,wil work PERFECT. Yov should consider it.
Mk1-8valve
Cam
Thanks Chris,
You maybe have a pic of the G-cam for me? If so, plz email to michaelg@lekana.co.za
I am able to swop for a g-cam, dont know if someone is willing to swop me for a 268 cam, how much do 268 cams go for 2nd hand??
Mk1 1.8i 8v MP9 :-)
50mm TNT F/Flow
40mm N-Force Drop
Life Tail Lights
Future mods:
272/6 Estas Cam
2E 2L 8v motor
1.6carbster
Damn,wish i still had my g cam,i'd have swopped you...lol.
268's go for r700 odd bucks.
BTW,sory, i got no pics...
Mk1-8valve
Gti King is willing to swop me the g-cam, but I have not seen what a hydr. G-cam looks like, & I don't wanna get the wrong G-Cam. I know its got a 049G stamp on it though.
Mk1 1.8i 8v MP9 :-)
50mm TNT F/Flow
40mm N-Force Drop
Life Tail Lights
Future mods:
272/6 Estas Cam
2E 2L 8v motor
ssshannah
Registered for: 6 years 1 month
Re: Cam specs...
Post by ssshannah »
GolfPlayer wrote: Thu Jul 19, 2007 5:25 pm G cam has same specs as A cam, with only difference being the A is advanced about 4 degrees compared to G. A works well on all stock 1.6 8V motors. G is OK for carb 1800, std on K-Jet 1800 motors. There, upgrade to 286/276 for better results. B is the same as A, but with the bearing journal on
a solid lifter K can be cut up to 276h? that's interesting. Anyone to elaborate on that? I'm aware the thread is old but hoping to get more info on this.
gt'79
Registered for: 10 years 5 months
Car Make: VW's
Car Model: MK3 Cli, MK3 CSX, MK1 GT
Re: Cam specs...
Post by gt'79 »
ssshannah wrote: Wed May 25, 2022 10:29 am
Somewhere i heard the same, called Mastercams and they could not confirm this. This the times i miss Nellis. im sitting with 4 of those K-cams
'78 Mk1 2door - RIP
'79 Mk1 2door - New Project - Making a trailer from it - WIP
'96 Jetta CLi 2.0L 8v MP9 99.1 KW - 187 Nm with Zorst and Branch RIP
'94 Jetta CLi 2.0L 8V Stock standard (SOLD)
'97 Jetta CSX 1800 8v (WIP)
'89 MK1 4door Citi Golf - New Spec to Old Spec WIP
Howie-WP
Membership No: 2033
Re: Cam specs...
Post by Howie-WP »
gt'79 wrote: Tue Nov 01, 2022 1:57 pm This the times i miss Nellis. im sitting with 4 of those K-cams
RIP Nellis, you are still fondly thought of and missed :cry:
