How do I replace my brake Discs ?
I need to replace them. The old one's got a deep scratch in it. So Goldwagen quoted me R405 for the pads and discs.
I just need to know how to replace it (time for the upgrade at last.). Dont want to just to do it and mess it up.
I know this might be a stupid question to some people.
Thx
Thx
*** How would life be without a VW? ***
2006 Tossablau Velociti 1.4i (150K km and still going strong)
2011 Mahindra Thar 2.5 CRDe 4X4 (The monster!)
EX's :
1978 Golf 1 Diesel 1.5 White (Original)
2005 Citi Golf Chico 1.4 Gold (oil abuser)
EX's :
- Membership No: 2033
Re: How do I replace my brake Discs ?
Do a search this was covered not so long ago..... Simple job....VW-Uziel wrote:I know this might be a stupid question to some people. Thx
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- SHAUN
- Post Whore
- Registered for: 19 years 9 months
- Car Make: BMW
- Car Model: 2006 335i
- Membership No: 1148
Search, there is a whole DIY topic i made about it with pics!
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
Thx Shaun.
One more Question, whats the difference between yours and my velociti? Installation wise, I think they are the same.
EX's :
EX's :
- Car Make: SEAT
- Membership No: 478
They are very similar, but not exactly the same.VW-Uziel wrote:Thx Shaun.
It is really simple.
1) Jack the car up and remove wheel
2) Use a 6mm Allen key to remove the 2 Allen head bolts holding the caliper on. Take note of where they came from because they are different lengths
3) Pull the caliper off
4) Remove the brake pads and spring clips
5) Remove the single screw holding the disk onto the hub
6) Remove the disk from the hub / carrier
7) Fit the new disk and screw the little screw back in
8 ) Fit the new pads and spring clips
9) Push the caliper piston back using your hands or pump pliers
10) Locate caliper into the carrier
11) Refit and tighten the 2 Allen head bolts
12) Refit wheel
13) Jack down car
14) Repeat steps 1 - 13 for the other side
15) Pump the brakes until they are hard
16) Bed the brakes in properly
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Registered for: 21 years 2 months
- Car Model: 2017 Cross Polo 1.2 TSI
6a) Smear some copper grease (anti-seize) on the hub face that contacts the disk.
You never know when rust and corrosion begin to glue things together. First set of discs that came off my Chico needed a klap to remove.
2017 VW Cross Polo 1.2TSI
2006 VW Citi 1.4 carb
1995 VW Chico 1.3 4-speed
1989 Audi 500 turbo (the end. finally.)
- SHAUN
- Post Whore
- Car Make: BMW
- Car Make: SEAT
Ideally you want the hub face and the inside of the disk to be as clean as possible as anything in between these two surfaces could cause the disk to not sit flush with the hub face which could cause vibrations.2226cc wrote:6a) Smear some copper grease (anti-seize) on the hub face that contacts the disk.
In the 7 years I have had my car I have never put any copper slip on those surfaces and I have never had the problem you mentioned.
Rather just clean both surfaces with some petrol and it will be fine.
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Car Make: SEAT
The only tools you will need are:VW-Uziel wrote:So I need a 6mm Ellen key, any spanners?
1) A wheel spanner
2) A strong 6mm Allen key
3) A medium Philips head screwdriver
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- Car Make: Ford
- Car Model: Ranger
- Membership No: 458
- Car Make: SEAT
Usually I just spray some Q20 / WD40 in there and let it soak for a while.Fastandfurious wrote:And a drill if that little screw holding the disc on has rusted badly......MacMan wrote:The only tools you will need are:VW-Uziel wrote:So I need a 6mm Ellen key, any spanners?
1) A wheel spanner
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- General
- Car Model: Golf 7R
- Car Make: Ford
- Car Model: Ranger
I don't think mine will be stuck. Haven seen any rust there. Got a nice drill if it comes to that. Car only got 35K km's on.
EX's :
EX's :
- Car Make: SEAT
Don't even waste your time or money. ATE discs or nothing I say.Hotdubz wrote:sorry to hijack, are the Spirex vented discs any good?
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- General
Hi all. It has been almost a moth now and some 3500 odd k's later and my brakes a superb. I will recommend this to any one thinking of it.
Vented Disc's are the best for a MK1.
EX's :
EX's :
- Car Model: MK5 GTi DSG
- Membership No: 1232
- Registered for: 1 year 9 months
