Page 1 of 2
VR6 Airflow-Meter Problem
Posted: Mon Dec 11, 2006 8:28 am
by just4fozi@yahoo.com
Sup dudes?
Allgood on my side (not really
). I’ve been having some performance issues with my VR6 over the past 2-3months. The car’s been to VW in PE about 3times already and they keep telling me that theres nothing wrong with it (stupid idiots). I finally decided to consult my buddy who does all the VR6 / V5 cars at the Uitenhage VW dealership. I explained my cars symptoms to him (Poor power delivery / Hard starting
sometimes / Terrible consumption). He almost immediately knew what the cause was. He told me that theres a 75% chance that my Air-Mass-Meter is stuffed.
Friday I ran a test on my car. I had a couple of runs with the MAF dissconnected & re-connected. The car felt exactly the same both ways. My car doesn’t wanna rev like it use to. I 1st suspected the lambda & Crank sensor. According to the VW VAS both are giving proper readings.
Did any1 ever experience this before?
BTW:
New NGK plugs
New HT Leads
Crack-free Coilpack
Posted: Mon Dec 11, 2006 1:16 pm
by satinsilver110
sommmmmmebody must have had the same problem
Posted: Mon Dec 11, 2006 1:21 pm
I suppose there aint 2many VR6 drivers out there.
Posted: Mon Dec 11, 2006 1:31 pm
by Smoke187
Eish i dont drive a VR6 but I have a GTi and i had the same problem twice and its still giving me crap. Now you know i want to eliminate the Air-flow.
Posted: Mon Dec 11, 2006 2:14 pm
by Gandalf
I agree with your logic that it is the MAF. If the VR6 has the same ECU (Motronic 5) as my 1995 Audi S2 has, airflow is the one important thing that you can't log with VAGCOM. But if the car pulls the same with the MAF connected or not, it is most probably the MAF.
Why not try to clean the MAF before replacing? Clean the plug with contact cleaner and the MAF element with Carb Cleaner. Spray the carb cleaner from a distance as the element is quite delicate (I repeat it 3 times). I see you use an oiled filter - they are not good for MAFs!
Posted: Mon Dec 11, 2006 2:24 pm
Gandalf wrote:I agree with your logic that it is the MAF. If the VR6 has the same ECU (Motronic 5) as my 1995 Audi S2 has, airflow is the one important thing that you can't log with VAGCOM. But if the car pulls the same with the MAF connected or not, it is most probably the MAF.
I have cleaned it with proper 3M intake cleaner. I think its just dead
Posted: Mon Dec 11, 2006 2:31 pm
by panic-mechanic
hehe - now here is 1 good reason to use a good old paper air cleaner
Posted: Mon Dec 11, 2006 2:34 pm
panic-mechanic wrote:hehe - now here is 1 good reason to use a good old paper air cleaner
Í've always used a paper filter on this car. Only fitted Simopta flatpad about 1.5 months ago. You should know from my previous posts that i've been having perfomance issues for a loooongtime now already. (pre-simota)
So tha MAF has been the culprit all along..................
Posted: Mon Dec 11, 2006 2:51 pm
by saxo
I've got a spare VR6 air flow meter, but I think that it is for n corrodo VR6 but it was on my golf VR and it worked....
Posted: Mon Dec 11, 2006 2:56 pm
saxo wrote:I've got a spare VR6 air flow meter, but I think that it is for n corrodo VR6 but it was on my golf VR and it worked....
So it works 100%
Howmuch
What model was your golf?
Posted: Mon Dec 11, 2006 8:04 pm
by panic-mechanic
remember there are 2 types depending on year model.
Posted: Tue Dec 12, 2006 8:39 am
Apparently you can buy a 2.0l MAF and just use your old housing. Its suppose to be much cheaper.
Very common in Europe and USA. But Our 2.0l Golf3's have no MAF's
Posted: Tue Dec 12, 2006 9:17 am
by MoCTi
just4fozi@yahoo.com wrote:Apparently you can buy a 2.0l MAF and just use your old housing. Its suppose to be much cheaper.
As sensitive as these air flow meters are do u really want to mess around with em ....
if u do go that route let me know on the outcome would be very interestin..
Posted: Tue Dec 12, 2006 10:31 am
I'm just trying to check what all the options are. My car has been booked for the 18th at VW anyways. They allready told me that theres a 75% chance that my MAF is busted. My warranty (SA Warranties) should cover most of the cost anyways. I saw that
www.mrturbo.co.za sells the BOSCH MAF for R750. It looks exactly the same as mine. If i do have2 pay in 2much at VW i'll buy the BOSCH 1 from mrturbo
Posted: Tue Dec 12, 2006 10:35 am
by kobus.nel
You get three different types, 94-96 had one type, 96-98 had two types it wich has the same part no except the one has a "A" added to the part no if I remember correctly. They don't work if it's not the correct one believe me.
Posted: Tue Dec 12, 2006 10:56 am
DNT wrote:Off topic...but do the 2005 Velociti 1.4 and 1.6 have MAFs?
Nope
Posted: Tue Dec 12, 2006 11:50 am
by VR6-BOY
I had a problem starting my VR6 (98 model), I had to start the car and hold the accelarator on about 1500rpm for 30 seconds and then the car would idle by it self, otherwise it would just hunt and switch off... My mechanic changed the AIR MASS METER and walla all has been fine ever since..... I bought a original one from the agents R3500.00
Posted: Tue Dec 12, 2006 11:59 am
VR6-BOY wrote:I had a problem starting my VR6 (98 model), I had to start the car and hold the accelarator on about 1500rpm for 30 seconds and then the car would idle by it self, otherwise it would just hunt and switch off... My mechanic changed the AIR MASS METER and walla all has been fine ever since..... I bought a original one from the agents R3500.00
R3500
Son of a @#$%
Was it gold-plated or something?
Posted: Tue Dec 12, 2006 1:00 pm
by saxo
You just gonna have to pay me for the sending it from me 2 you via post.... It look just like the one mrTurbo sells!!
Posted: Tue Dec 12, 2006 1:27 pm
saxo wrote:You just gonna have to pay me for the sending it from me 2 you via post.... It look just like the one mrTurbo sells!!
So howmuch do you want for it?
I'm gonna go check the part no. on mine in a few mins then you can give me the no. on your. That way we can determine if it'll work. My car is a 1996 model.
Posted: Tue Dec 12, 2006 2:17 pm
by panic-mechanic
not gold plated no but it is made from platinum which incidentally is way more expensive than gold
Posted: Tue Dec 12, 2006 3:04 pm
by saxo
Mine is also a 1996...
Posted: Tue Dec 12, 2006 3:46 pm
These are the No’s on my cars Mass-Airflow-Meter. I have it right here infront of me now.
0 280 217 504
021 906 462
Posted: Tue Dec 12, 2006 4:24 pm
by HASSEN
Sure its not the 'A' after 462 hey????
If so R3859-13+vat
Posted: Tue Dec 12, 2006 4:28 pm
HASSEN wrote:Sure its not the 'A' after 462 hey????
If so R3859-13+vat
0 280 217 504 This is the part number (no A)
Ignore the number below that. Its not the model with the A at the back. Thats for the later model VR6
