1600 & 1800 Heads?
1600 & 1800 Heads?
Hi guys, just a Q'
Are the 1600 & 1800 Cyl. Heads 100% the same?
(Combustion Chamber sizes, Valves sizes, etc?)
La-Shay Qhuan
- Car Make: SEAT
- Membership No: 478
Re: 1600 & 1800 Heads?
Combustion chamber sizes on the 1600 and 1800 carb heads are the same, as well as the MP9 heads.La-Shay Qhuan wrote:Hi guys, just a Q'
The valve sizes on the 1600 and 1800 carb heads are different.
The valve sizes on the 1600 and 1800 MP9 heads are the same.
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
- MeTsU
- Car Model: 2005 Polo 1.9 TDi Sportline
- Membership No: 1644
Sorry for the n00b question, but how does one tell the difference between the different heads (1300/1400/1600/1800) (carb and MP9)?
What markings or codes can one look for to tell which head is which?
Thanks.
Thanks.
2005 Polo 1.9TDi Sportline - Sooty
Correct, except that 1600 and 1800 carb heads have the same valves, ie 34mm ex and 38mm intake. The kjet head has bigger intake (40mm) valves.MacMan wrote:Combustion chamber sizes on the 1600 and 1800 carb heads are the same, as well as the MP9 heads.La-Shay Qhuan wrote:Hi guys, just a Q'
- General
- Car Model: Golf 7R
Interesting thread. Yeah please if anyone has the code for the heads will help a whole lot to identify them.MeTsU wrote:Sorry for the n00b question, but how does one tell the difference between the different heads (1300/1400/1600/1800) (carb and MP9)?
Thanks.
- Car Model: MK5 GTI DSG BWA
- Membership No: 1156
The intake ports on the Mp9 head are oval with a machined edge on the top of the port for the injectors to fit in.MeTsU wrote:Sorry for the n00b question, but how does one tell the difference between the different heads (1300/1400/1600/1800) (carb and Mp9)
The carb head is just oval in shape.
The Kjet head have holes same as where the spark plug holes for the injectors to fit in as the injectors fit into the head.
The Kjet the injectors are in the head and mp9 its on the intake
2012 Dec Mk6 GTI CW DSG - REVO Stage 1
Ex 2008 White Golf 5 Gti DSG REVO3 K04 - Weekend Toy
Regards
Hoosen
072 135 7861
Regards
Hoosen
072 135 7861
Thanks a lot for your input guys, So when converting 1600 carb to 1800 one does not have to change the head. This is good news.
Another Q: My bro' Maestro found out from this BB that we're both running shim & bucket type tappets.(Silver Bucket & a Disc on top) Are these what's aka Solid Lifters?
2-and how do I identify Hydraulic Lifters, what do they look like?
3- Cams: How do I tell the difference between the Hyd. Cam & a Solid Lifter cam? Can I use a Hyd. Cam on shim & bucket type tappets & vise versa?
Do I need to fit a vernier together with a 276 the same time? Or can I do the cam then later the vernier?.
Your valuable input will be appreciated.
Shay
Shay
La-Shay Qhuan
\La-Shay Qhuan wrote:Thanks a lot for your input guys, So when converting 1600 carb to 1800 one does not have to change the head. This is good news.
Shay
1. Yes
2. Like solid lifters without the shim.
3. Solid heads have one cam journal less, so one journale on the cam won't have marks. You can't change the cams.
4. You can do the vernier later.
- Registered for: 10 years
- Car Model: Polo Playa 6n
