Mk1 clattering noise from front right
- Registered for: 2 years 9 months
Howsit guys. In a total noob when it comes to cars and im learning day by day. Busy with project golf at the moment. When I break the front right has a chattering sound sort of like someone sticking something into a fan, this is only when the car is moving and I apply breaks. Im not rolling in it so if i can isolate the problem and fix it that is first prize. Any ideas what the sound could be?
- Neuk
- Treasurer
- Membership No: 806
Re: Mk1 clattering noise from front right
Have you checked your pads and disks? I would start there and then check things like lower control arm bushes, tie rod ends, top shock mounts, etc.
Problem solved. they for some reason sold me a car with no bolts holding the engine up at the gearbox side and the cam pullies side. there were two bolts that were broken and stuck in the block on the cam pully side, so the tensioner wheel ended up rubbing on a bracket.
- Neuk
- Treasurer
WTFTimmeh87 wrote: ↑Tue Aug 03, 2021 11:56 pm Problem solved. they for some reason sold me a car with no bolts holding the engine up at the gearbox side and the cam pullies side. there were two bolts that were broken and stuck in the block on the cam pully side, so the tensioner wheel ended up rubbing on a bracket.
- marzbars
- Car Model: 1988 Corrado 16V
- Membership No: 1316
How did that car pass roadworthy when you bought it?
Current : 1988 VW Corrado
Ex : 1990 VW Golf CSL 1.6
Ex : 1995 VW Caddy 2.0 8v
Ex : 1996 VW Golf 3 GTS 1.8i
Ex : 1995 VW Golf 3 GTI
Ex : 1993 VW Chico 1.3
- amstel18
- Car Model: Tiguan Allspace
Would be interesting to hear who "they" are that sold you the car. I'd be very worried if it is a dealer...
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
