Hi All,
Hope someone can help...
I’m swopping out a std mk5 headunit with a mk6 headunit and am told that in a couple of days it’ll come up with a component protection message which only VW can remove. Can some direct me otherwise please? Will vagsoftware thing be able to remove (forgive my nontechnical terminology please) the message?
Thanx all
Radio component protection removal
- Car Model: MK5 GTI
- Belix
- Car Model: Passat B8
The golf mk6 radios don't have component protection - rcd310, rcd510, rns510 and even the newer Rcd330 versions. The mk7 spec radios have component protection.
Battery drain may be an issue depending on can us version but there is a work around.
Re: Radio component protection removal
Hi Belix,
Thank you so much for the reply. Very much appreciated.
May I ask, is there any way to know beforehand of the possible battery drainage issue and what is the work around?
Thank you again.
Regards
Thank you again.
Regards
- Belix
If you get a vcds scan, you can see the part number of the can us module. There was a topic, I think it was call "rns510" where the part number was discussed. --> Unit RNS510
https://r.tapatalk.com/shareLink?share_ ... are_type=t
For the battery drain work around, if I recall, it was a simple bridge between two terminals in the fuse box. https://youtu.be/Uma0jJjqqu4
Work around viewtopic.php?t=146567
Hi All,
Eish... and now the “Component protection” has come up. Any suggestions on removing please?
component protection can ONLY be removed by a dealer.
- Belix
what head unit did you end up getting?
I got the part number - 1K8035150H
Think VAG software can undo the component protection. So says YouTube
Now just to find someone that can
Hi. Did you manage to find someone to remove the component protection?
- Belix
Have you checked in with @Chris_FZ at retrofitters?
