Hi all, im sitting with a small problem on my 2006 chico golf. I recently bought the car and noticed the rev counter is not working. I did some research and came to the conclusion that the guy i bought the car from changed the 3 pin ignition coil to the standard bottle or 2 pin coil as some call it, and added the TP100 box. The wiring from the 3 pin ignition coil is still there and intact. My question is what will be the best and easiest way to make my rev counter work again? Re-install a 3 pin ignition coil or is there a simple way with the 2 pin coil. I have tried the pin 7 on the tp100 to distributor and that didn't work. T.I.A
2006 vw chico golf rev counter
- Registered for: 4 years 9 months
Re: 2006 vw chico golf rev counter
Probably easiest to put a 3 pin coil back.
