Polo subframe
- Car Model: jetta vr6
Polo subframe
Good day....i would like to know if 2012 polo9n3 subframe will fit onto 2013 polo vivo....
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Re: Polo subframe
Production of the 9N3 ended somewhere in 2009 when the 6R started.
But the 9N3 front subframe is different to the Vivo as far as I know, the LCA bushes was turned 90 degrees similar to the 6R, so even if it may fit you will have to source new lower control arms.
Why do you want to do that, I am sure you can find a Vivo subframe somewhere... these things are everywhere, there should be one at some scrappy.
Re: Polo subframe
Ive got the complete subframe with lower control arms...
Re: Polo subframe
But why would you want to do it?
Was the car in an accident?
Re: Polo subframe
I want to put it on the polo vivo......
The vivo was in an accident
- BIGMIG
- Porra Love
- Membership No: 1574
Re: Polo subframe
If I’m not mistaken you can but you would need the entire subframe assembly this includes the LCA arms and sway bar. The sway bar mounts directly off the upper aluminum tower section. Then you might have an issue with drop link length.
Not worth it. What is your reasoning for wanting to convert?
Re: Polo subframe
@BIGMIG.....the vivo was in an accident so the subframe and lca got hurt......so im stripping my 9n3 subframe with control arms and swaybar to fit onto vivo....
Re: Polo subframe
well try and then let us know.
- BIGMIG
- Porra Love
Re: Polo subframe
Im looking for a 2009 polo 1.8 gti front subframe. Mine got torn on the left side when i accidentally drove over a pavement. The vehicle still drives its just that im a bit worried that the control arm bolt might snap in the long run. Any idea where i can find one still?
