So I had some issues with power to the driver door dying and then also needed to have starter refurbed.
Took it away to an auto electrician to refurb starter and sort out the door. he sorted both out and ever since then the airbag fault light is on the dash now. He did say I can take it back to him if it didn't work. Was just wondering if anyone knows what the cause could be and if it is a quick fix that I could maybe sort out myself. He wasn't anywhere close to the airbags or anything like that and battery was disconnected when he did all the work.
Worst case scenario if I can't fix it myself, then I will need to just make time to go around to him to sort it out.
Airbag light on
- DJ7
- Car Model: MK5 2.0 TDI DSG
- Membership No: 3238
Airbag light on
Ex: '97 Astra Estate 200i
'00 Corsa 200 GSI 16v
'96 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
'95 Astra 200i E 16v
'02 Corsa 160 GSI
'93 Ballade 160e
- Stefan0909
- Car Model: Tiguan 2.0TDI
Re: Airbag light on
Get a scan done on the car. Check the threads for VCDS/VAG register and contact the person closest to you, seeing that you are in CPT.
Let them scan and clear error codes.
That would be the first point
Sent from my ELE-L09 using Tapatalk
1.4i Velocity Stock
1.4i Kia Rio Stock
1.8i VTEC Honda FRV Stock
Citroen DS3 Techno Pack Stock
1.4i Velocity Stock
1.4i Kia Rio Stock
- Stefan0909
Re: Airbag light on
1.4i Velocity Stock
1.4i Kia Rio Stock
1.4i Velocity Stock
1.4i Kia Rio Stock
- DJ7
Re: Airbag light on
That is exactly what the auto was going to do. Shot bud.Stefan0909 wrote: ↑Fri Apr 26, 2019 12:49 pm Get a scan done on the car. Check the threads for VCDS/VAG register and contact the person closest to you, seeing that you are in CPT.
'02 Corsa 160 GSI
'93 Ballade 160e
'02 Corsa 160 GSI
'93 Ballade 160e
- Stefan0909
Re: Airbag light on
Cool stuff, hope he gets it sorted out for you
1.4i Velocity Stock
1.4i Kia Rio Stock
1.4i Velocity Stock
1.4i Kia Rio Stock
- DJ7
Re: Airbag light on
Stefan0909 wrote: ↑Fri Apr 26, 2019 12:51 pm Cool stuff, hope he gets it sorted out for you
'02 Corsa 160 GSI
'93 Ballade 160e
'02 Corsa 160 GSI
'93 Ballade 160e
Airbag light on
good day all
can anyone help with manual reset on polo vivo 1.4 airbag light
Re: Airbag light on
Read previous posts.gcinashange wrote:good day all
Re: Airbag light on
There is no such a thing as a manual reset. You need to plug in a scan tool, se what the fault is, fix th fault and then clear it.
If it was a battery dead or battery swop then just clear the fault. But scantool is the only way.
