2E unable to give enough oil pressure
- Car Make: BMW
- Car Model: 520D
What's up guys.
So my project of a few years is standing still and I'm frustrated to the end.
Details;
2E Block bored bigger
BMW Pistons
X-Flow Head (Flowed, Ported, Bigger Valves, Imported Parts, etc)
Toyota RXI Throttles
C/R planned under 12
Crank, Flywheel lightened
My mechanics can't find the issue and the engineers could not find a issue on the head or block.
Fixes tried;
Check squirters in block - No squirters in block
Replace Oil Pump - The 4th one currently
Check clearances - 2 Engineers checked and all looks good
Check for cracks on block - Unable to find any to the eye issues
Anybody have any suggestions?
It's easy to probably buy a other block but don't want to spend money on block and engineers to bore bigger then the issue is again there.
Is there a company in Cape Town who can scan/x-ray a block to see if there is cracks or blocked oil feeders?
Details;
BMW Pistons
Fixes tried;
Last edited by rodriguesbeast on Wed May 15, 2019 9:31 am, edited 1 time in total.
Re: 2E unable to give enough oil pressure
Are you getting oil pressure and what is the the pressure reading then
- Car Make: BMW
- Car Model: 520D
Getting oil pressure yes.
Idle under 1Bar
Reving under 3Bar
Tested at the oil filter
Can hear the tappets making a noise
Idle under 1Bar
Reving under 3Bar
Are you running solid lifters or hydraulic lifters
- Car Make: BMW
- Car Model: 520D
Confirming with my builder quickly.
If memory serves me right yes, cause we running a 302 cam.
Put a restriction in the feed hole to the cylinder head. Like down to a 1 mm hole.
- Car Make: BMW
- Car Model: 520D
And then test again?
What should the outcome be
Higher oil pressure in the bottom end. We basically hit a jet or a copper bar into the block feed hole to thenhead and drill it to size.
- Car Make: BMW
- Car Model: 520D
And what will happen to the head pressure?
And also what is the negative effects of doing this
Elementary my dear watson. Pressure in the head drops, which you don't need that much off seeing you are running solid lifters anyway. Pressure in the block will climb as that is something you seem to be worried about.
No long term issue. Have run many many many many vw challenge race cars like that.
- Car Make: BMW
- Car Model: 520D
My last hope mechanic found the issue we hope.
In the distributor hole, there is a washer/restrictor/bush, that thing is missing.
Anybody have a spare one for me perhaps?
Anybody know the part number maybe
Are you talking about the bush that sits in the block surrounding the oil pump shaft?
GW should be able to supply this.
- Car Make: BMW
- Car Model: 520D
Thanks guys for the info.
The issue was that bush which was not in the distributor hole. That bush is R100 but it's costing me already loads of money to find the issue.
Hope someone sees this post in future when they don't get oil pressure and just check this.
- Car Model: Polo 1 Classic
I HAVE A SIMILAR ISSUE WITH MY 2002 POLO 1.6 AFX Motor.. can u please advise if the same set up applies on my motor as on the 2.0 l
Dave 0606226922
Dave 0606226922
Re: AFX Motor rebuild
Hi Guys n Girls.. I am looking for a reliable and reasonable mechanic in JHB/PTA area to recon my 2002 AFX 1.6 Polo motor and do some other work.. or... failing that a good replacement motor (2E, AGG or similar)
Dave 0606226922
Dave 0606226922
