good day
My mk5's aircon does not want to come on, thr fan.
When i connect the fan to a batt. The fan turns. I tested the Fan speed resistor.
Can it be then the switch to set the speed or is there something else that i can look at. Thanks
Wait to hear from you.
Mk5 aircon
- Registered for: 5 years
- Car Model: MK5 1.9 tdi
- Irfaan
- fuckitimtiredletsgetdonewiththis
- Car Model: 07' Velociti, 06' MK5 GTi
- Membership No: 1757
Re: Mk5 aircon
G65 Sensor
Buy from GW for around R800
You will need to empty out the aircon gas before replacing and once you replace it you will have to refill
Yip I still got my 1.4 Citi
- Registered for: 11 years
- Membership No: 1893
Re: Mk5 aircon
What Irfaan said. Had the same issue on my MK5 Jetta, the pressure sensor connected to the a/c lines goes bad.
Apart from the draining and refilling the system (Rememeber, they have CFC gas, so it's dangerous to inhale), it's a quick jobbie.
Ex's:
'07 VW Golf MK5 GT - SOLD
Ex's:
Re: Mk5 aircon
Thanks will check it out.
Re: Mk5 aircon
Is there a way for me to test the G65 sensor ?
