Hi guys,
I’m at my wits end! My girls golf 5 key is stuck in the ignition. This has happened before but it got stuck in the on position.
I was able to remove the insides following a few YouTube videos. Some small pieces of metal broke off and jammed the key. Cleaned it out and it was all good.
Problem is this time it’s stuck in the off position. I cannot turn the key enough to stick in the pin to remove it...
Who can I contact to come out and remove the whole barrel mechanism and replace it? I’m totally lost...
Thanks guys... hope someone can point me in which direction.
I’m located in Ruimsig, west of jhb.
Vw golf 5 key stuck - Please help!!
- Car Model: A3 1.8t
- Membership No: 1990
- Registered for: 16 years 11 months
Re: Vw golf 5 key stuck - Please help!!
Chief, I had the same issue, only way is to replace the ignition barrel.
I bought a second hand one from ABC Spares for R350. Speak to Jan or Alfred.
Checkout Key Boutique in Rivonia, they will come out to you and replace it, they can also supply the barrel, but way too expensive.
Thanks so much bud! Gave them a call now and they coming out to do the job for R1200 bucks.Farhad1 wrote: ↑Thu Feb 07, 2019 10:24 am Chief, I had the same issue, only way is to replace the ignition barrel.
