DSG
- Car Model: 2016 Polo GTi DSG (6C
DSG
Hello All,
I recently got a 2016, Polo GTi with a DSG box and regularly like to "free" (taking my foot of the gas pedal for those who doesn't know ) especially on downhills (when the opportunity presents itself) with the car still in driving mode (D).
Is this good or bad for these DSG boxes?
- Wolf Mk2 16V
Re: DSG
Can't think that that would be a problem, I would imagine VW covered that ability in the design hehe
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
Re: DSG
I had to ask as I have been reading a few posts of people complaining about these DSG boxesWolf Mk2 16V wrote: ↑Wed Jan 16, 2019 11:27 am Can't think that that would be a problem, I would imagine VW covered that ability in the design hehe
- Belix
- Car Model: Passat B8
Re: DSG
The manual mentions this is the way the fuel cut-off valve works. So you'll use less fuel that way than putting it into neutral. Hense can't imagine it damaging the box
- Wolf Mk2 16V
Re: DSG
My car is at 118 000km, it is still fine, but it is as if you are more aware of little judders, and "different" behaviors (maybe just paranoia because my ass has spent so many k's in the driver's seat and knows it so well ) but I'm sure when the box is serviced at 120 she will be cool again. I think that is quite commendable considering the type of car and what it has to deal with.
2015 VW Golf Gti
1987 Golf GTS
2015 VW Move Up!
1987 Golf GTS
2015 VW Move Up!
- Belix
Re: DSG
not specifically for a polo, but there are bunches of tweak guides on the net. - https://uk-polos.net/viewtopic.php?t=62548jaunrothner wrote: ↑Wed Jan 16, 2019 11:35 am Thanks, Do you know of any VCDS coding can be applied to these Polo's?
Re: DSG
Thanks, I am feeling a little bit better nowWolf Mk2 16V wrote: ↑Wed Jan 16, 2019 11:38 am My car is at 118 000km, it is still fine, but it is as if you are more aware of little judders, and "different" behaviors (maybe just paranoia because my ass has spent so many k's in the driver's seat and knows it so well ) but I'm sure when the box is serviced at 120 she will be cool again. I think that is quite commendable considering the type of car and what it has to deal with.
Re: DSG
ThanksBelix wrote: ↑Wed Jan 16, 2019 11:41 amnot specifically for a polo, but there are bunches of tweak guides on the net. - https://uk-polos.net/viewtopic.php?t=62548jaunrothner wrote: ↑Wed Jan 16, 2019 11:35 am Thanks, Do you know of any VCDS coding can be applied to these Polo's?
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
Re: DSG
These polo boxes don't have a service in the scheduleWolf Mk2 16V wrote:My car is at 118 000km, it is still fine, but it is as if you are more aware of little judders, and "different" behaviors (maybe just paranoia because my ass has spent so many k's in the driver's seat and knows it so well ) but I'm sure when the box is serviced at 120 she will be cool again. I think that is quite commendable considering the type of car and what it has to deal with.
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
Re: DSG
you can coast against the throttle no issue. Once it's running a dsg is just like any normal gearbox.
DQ200 ie. the dry clutch boxes does not need an oil change like the dq250 wet clutch.
On the dq200 the mechatronics has it's own enclosure with oil in and does not share it with the gear section and the clutches sits outside of the box so does not contaminate the oil. So for them it's basically like any old manual gearbox.
