Reset Faulty Airbag G4 Gti
- Wheel Whore
Hi guys,
I accidentally removed the fuse for the airbag while the igniton was on. Now the dashboard says 'faulty airbag'. How do I go about resolving this issue?
- Neuk
- Treasurer
- Membership No: 806
Re: Reset Faulty Airbag G4 Gti
You will probably need to do it via VAGCom, I used to reset airbag lights in my B6 A4 using a fong kong cable and freeware VAGCom software.
- Car Make: Nike
Where are you based?KEVIN PAKKIRI wrote: ↑Mon Jan 14, 2019 12:25 pm Hi guys,
Alot of guys that will help you free of charge. Just give your location
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
- DieterMK5
- Car Model: Jetta MK5 1.9 TDi
- Membership No: 3015
You could try disconnecting the battery for a couple hours or overnight, but chances are you'll need VAGCOM
- Wheel Whore
Hi guys,Rudi46 wrote: ↑Tue Jan 15, 2019 7:36 amWhere are you based?KEVIN PAKKIRI wrote: ↑Mon Jan 14, 2019 12:25 pm Hi guys,
I'm on the east rand, Benoni / Boksburg
Battery disconnect will not clear an airbog issue, as a matter of fact it will create others rather than solve the one you have. In theneast rand I can assist you after hours or on a weekend. Send me a PM.
Stephan,
If it's not too much trouble, I'd be interested to hear more about the additional issues that a battery disconnect can cause (seeing that I drive a Mk4 as well).
It records faults with all the units that report to the can bus.
- Wheel Whore
Thanks Stephan,panic-mechanic wrote: ↑Thu Jan 17, 2019 7:21 am Battery disconnect will not clear an airbog issue, as a matter of fact it will create others rather than solve the one you have. In theneast rand I can assist you after hours or on a weekend. Send me a PM.
I really appreciate your assistance yesterday.
Hi Guys
I have and airbag light that comes on
I want to know what does the flash mean before it turns to a solid light... When I start then the light will flags once the remain solid...
Need to be plugged into diagnostics. No way to guess. The flash is just when it checks the system, then finds the fault and leaves the light on. Helps nothing towardsnfinding what the fault is.
