Hi, I just bought 3m of racecraft exhaust wrap.
Has anyone used it or know if its any good?
I only want to wrap my downpipe as it passes very close to the steering rack rubber and want to prevent the heat from damaging the rubber.
Will this work or do I need to take more precautions? There ia about 15mm between the rubber and downpipe
Sent from my PRA-LA1 using Tapatalk
Racecraft exhaust wrap
- Zoltan2222
- Car Model: A3 8L 2.0L 20VT
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
A3 8L 2.0L 20VT (project)
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
Re: Racecraft exhaust wrap
Wrap the rubber side instead of the exhaust
- Zoltan2222
Will somer wrap both
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
I agree with panic on this one.
Some info to consider and maybe someone can shed some light.
I have heard someone say that wrapping your down pipe or exhaust is bad as the material keeps the moisture around the exhaust for longer and it tends to rust quicker. Now I am not sure if this is true as I have never tried it and maybe this guy put the wrap on an already very rusty down pipe or exhaust...
VW Jetta mk2 16V
1978 Beetle 1600 8V
VW Jetta mk3 CSX
1978 Beetle 1600 8V
VW Jetta mk3 CSX
- Zoltan2222
I have read the same thing, but luckily for me my dp is 316 s/steel so rust will not be an issue.
What I ended up doing (as 3m wrap does not go very far) I wrapped the downpipe and then used the heat reflecting material that was on the turbo delivery pipe to cover the steering rubber, so double isolated.
The wrap works good as I could touch the dp after a 10min drive.
Current rides:
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
530D E60 LCI
Polo 1.9TDi 9N3
Previous rides:
Caddy MK1 1.8L 20VT
