Cool...Thanks for the example and explanationICE King wrote: ↑Wed Feb 06, 2019 11:53 amSee panic's reply, it's spot on.jaunrothner wrote: ↑Wed Feb 06, 2019 8:17 amHi,
What is "brake creeping" ?
Here's a quick real life example:
Bumper to bumper traffic while rolling:
In a manual , you accelerate , take foot off accelerating pedal, put the car in Neutral and use the brake to slow down the vehicle .
In a DSG , in drive mode and you partially braking to slow the car down but in essence means partial clutch engagement = equivalent of accelerating and braking at the same time in a manual which is not good long term.
Driving a DSG
- Car Model: 2016 Polo GTi DSG (6C
Re: Driving a DSG
- Car Model: Sportline
- Membership No: 3194
Re: Driving a DSG
The Touareg does not use a DSG AFAIK, so does this principle of "babying" the box apply to them? Thank you for the explanation.panic-mechanic wrote: ↑Wed Feb 06, 2019 10:53 am The thing is though - it isn't an auto. It's a manual gearbox (with two clutches) that is operated and shifted by electro hydraulic means.
So you need to treat it a bit like a manual to make it last.
One of the first things maybe somebody taught you when driving a manual is not to ride the clutch. So if you stand at a robot - keep the clutch depressed(this has a secondary long term effect of wearing thrust bearings in the engine but let's not go there) and engage the brakes or handbrake or stick it in neutral with the brakes on. Don't 'ride' the clutch to keep the car stationary.
Well now this is the same thing for DSG. When you stand still with your foot on the brake it will disengage the clutch and basically do the equivalent of sitting in gear with you foot fully on the clutch. As soon as you release the brake the electronics will try to apply the clutch and let the car move forward. IE the equivalent of you riding the clutch. Thus at that point you are incurring clutch plate wear. Once you at the speed where the need is not there to slip the clutch it is fully engaged like a manual with your foot off the clutch. When you slow down and it has geared down to second or first and if you keep slowing it down to the point where the engine would stall it will now start slipping the clutch again to accomodate your speed and if you have come to a standstill it will disengage.
Now a genuine auto box has for the connection between the engine and the gearbox a thing called a torque converter. There is no clutches in a torque converter to make it start or stop - the clutches in there is to do lockup which only occurs in gears like 4-th onward in audi and VW products mostly.
A torque converter has two sets of 'vanes' set in very close proximity and the area around them is filled with oil. When the driven vanes(attached to the engine side) speeds up the friction effect of the oil causes the vanes on the other side to be dragged along and thus drive is created in the gearbox. There is no actual components touching and thus no wear other than some heating of the oil and with age - breakdown of the fluid itself. So allowing the vehicle to slowly creep forward with you foot lightly on the brake has no wear effect on the torque converter and you can do it all the time for no penalty. IE brake creeping is what makes auto boxes great in traffic.
Once the vehicle is moving these days the torque converter will be locked up by a set of physical clutches and will then react like a clutch car - ie power transfer is direct with no slip from the vanes.
These are the Main differences in what distinguises the 'workings' of a dsg to an auto for what we care for in terms of longevity. If you allow a dsg car to creep slowly forward with your foot partially on the brake it is wearing the clutch set for gears 1,3,5,7 and with time they will be too thin for the system to get drive and then you get all kinds of issues or get locked into 2,4,6 gears only.
So it's really at slowing down and driving in traffic that you need to consider the workings of DSG. For any other times - yes sure it's an auto for all intents and purposes. If you drive it like an auto in traffic - expect to replace a set of clutches sooner than one that doesn't or that runs long distance.
Re: Driving a DSG
No , Touareg is either a proper Aisin auto or in the very latest version an 8 speed ZF auto. Either way - you don't need to do anything special. Just drive an enjoy. Brake creep as much as you like.
Re: Driving a DSG
Perfect thank you.
- Car Model: MK7 GTI
Re: Driving a DSG
But in Joburg traffic (plus how folks drive when there's congestion), I can't think of how one can avoid brake creeping
Might regret buying a DSG
Sent from my SM-N960F using Tapatalk
MK7 GTI
Revo Tuned
Revo Intake
Roque Performance DP
Revo Tuned
Revo Intake
- Belix
- Car Model: Passat B8
Re: Driving a DSG
my DSG seems to also engages quite a bit of partial clutch at low speeds even without the brake after taking off, with low accelerator inputs.
Car seems too eager to slip in second rather than sticking in first and revving a bit without slip. Sadly I cannot avoid traffic on my daily commutes. When it's bad stop start, i try and let the traffic get a bit ahead, although whether the slip on starting is better or worse than the slip on slow speeds remains to be seen - people also get agitated when you start leaving a three car gap in heavy traffic
Maybe I should try it in "sport" in traffic, although I suspect the increased throttle sensitivity would make it a jerky affair.
- Le Clue
- Membership No: 1458
Re: Driving a DSG
You leave a big enough gap to the person in front of you where you can let the car roll in drive without touching the brake or accelerator. This also causes traffic to move smoothly...
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
Re: Driving a DSG
The way it should be but dare leave a gap and some **** will try and squeese in thereLe Clue wrote:You leave a big enough gap to the person in front of you where you can let the car roll in drive without touching the brake or accelerator. This also causes traffic to move smoothly...
- Le Clue
Re: Driving a DSG
True...Gbvl wrote: ↑Thu Feb 07, 2019 7:16 pmThe way it should be but dare leave a gap and some **** will try and squeese in thereLe Clue wrote:You leave a big enough gap to the person in front of you where you can let the car roll in drive without touching the brake or accelerator. This also causes traffic to move smoothly...
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
Re: Driving a DSG
Let's be honest, if the gap is big enough another mother f0cker will squeeze in there
Re: Driving a DSG
So if you have a DSG then you can't really do heavy traffic without screwing up your box after a certain amount of KM? That is an issue in JHB and CPT.
- Uncle Nunda
- Post Whore
- Car Model: S3
- Membership No: 1489
Re: Driving a DSG
wow some interesting facts here
- Belix
Re: Driving a DSG
Well it would wear out the clutches faster, not mess up the box I would think. Not sure how long the clutches should "normally" last. I would think some traffic use should have been designed into its expected use.billionairebum wrote: ↑Tue Feb 12, 2019 1:36 pm So if you have a DSG then you can't really do heavy traffic without screwing up your box after a certain amount of KM? That is an issue in JHB and CPT.
Re: Driving a DSG
I'm having a noticeable whinning noise, can't pin down where is coming from. It's rpm related, when the pedal is released it goes aways but always there when there pedal is depressed
Is that a known issue on a DSG. How to get it resolved
MK7 GTI
Revo Tuned
Revo Intake
Revo Tuned
Revo Intake
- Membership No: 2033
Re: Driving a DSG
Turbo
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Neuk
- Treasurer
- Membership No: 806
Re: Driving a DSG
Which pedal? At first I thought release bearing but I am not sure if DSG gearboxes even have release bearings?sbu.mah wrote: ↑Mon Mar 04, 2019 1:55 pm I'm having a noticeable whinning noise, can't pin down where is coming from. It's rpm related, when the pedal is released it goes aways but always there when there pedal is depressed
Re: Driving a DSG
That's what I'm actually suspecting
MK7 GTI
Revo Tuned
Revo Intake
Revo Tuned
Revo Intake
Re: Driving a DSG
AcceleratorNeuk wrote:Which pedal? At first I thought release bearing but I am not sure if DSG gearboxes even have release bearings?sbu.mah wrote: ↑Mon Mar 04, 2019 1:55 pm I'm having a noticeable whinning noise, can't pin down where is coming from. It's rpm related, when the pedal is released it goes aways but always there when there pedal is depressed
MK7 GTI
Revo Tuned
Revo Intake
Revo Tuned
Revo Intake
- Neuk
- Treasurer
Re: Driving a DSG
Howie may be on the money but it could also be something in the drive train that is whining when under load.sbu.mah wrote: ↑Tue Mar 05, 2019 11:32 amAcceleratorNeuk wrote:Which pedal? At first I thought release bearing but I am not sure if DSG gearboxes even have release bearings?sbu.mah wrote: ↑Mon Mar 04, 2019 1:55 pm I'm having a noticeable whinning noise, can't pin down where is coming from. It's rpm related, when the pedal is released it goes aways but always there when there pedal is depressed
- neil_fladderak
- Car Model: Polo 6C 1.8 GTI DSG
Re: Driving a DSG
I wonder what caused my clutches to start slipping now the day i got my gti back after i got my dsg gearbox repaired, because the clutches did not slip before the gearbox repair ?
'17 Polo 6C GTI DSG
- Stock ECU/TCU Software
- 152kw 282nm on flywheel at Dynotech (runs were without below mention hardware)
- RoguePerformance 76mm Dp
- Stealth Atom 2 CAI
'17 Polo 6C 1.2TSI Highline Manual WRC Inspired (Stage 1 Tuned, TWEEK CAI, Powerflow cat-back exhaust) viewtopic.php?f=11&t=212395&p=2569296#p2569296
'06 Polo 1.6 Comfortline (Stock)
'05 Corsa 1.6 Sport (Stock)
'17 Polo 6C GTI DSG
Re: Driving a DSG
What happened to your gearboxneil_fladderak wrote:I wonder what caused my clutches to start slipping now the day i got my gti back after i got my dsg gearbox repaired, because the clutches did not slip before the gearbox repair ?
MK7 GTI
Revo Tuned
Revo Intake
Revo Tuned
Revo Intake
- neil_fladderak
Re: Driving a DSG
3rd and 4th gear synchros had to be replaced as their teeth were grinded off and causing gear changes to make scratching/grinding noises.
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
Re: Driving a DSG
Oh boy I hope I'm not going that route. Just had gear selector replaced
MK7 GTI
Revo Tuned
Revo Intake
Revo Tuned
Revo Intake
Re: Driving a DSG
IS38 turbo is it just a bolt on or some internals need to be replaced
MK7 GTI
Revo Tuned
Revo Intake
Revo Tuned
Revo Intake
- Sebz
- Car Make: BMW
- Car Model: 135i E82 N54 ST 6MT
- Membership No: 3020
Re: Driving a DSG
I would suggest using the search function to find a relevant thread, or else start a new one in Technical Discussions.sbu.mah wrote:IS38 turbo is it just a bolt on or some internals need to be replaced
I assume that you’re talking about putting an IS38 on a 7 GTI. It is pretty straightforward (relatively speaking) but that depends on numerous factors. Rather start a new thread and get all the info you need bud
Single turbo BMW 135i N54 6MT
Ex's:
Brilliant BMW 135i E82 N55 6MT
Stupidly static THANAS Tuned '05 Audi A4 B7 2.0T FSi
Definitely down-to-earth '03 Audi A3 8L 1.8T
Ludicrously lowered K04 '03 Audi A4 Avant B6 1.8T
Sorta slammed '15 VW Polo Vivo GT 1.6
Stock standard '05 Opel Corsa D Ute 1.4
Ridiculously reliable '81 VW Passat CSL Estate 2.2 5-pot
It's not how you stand by your car; it's how you scrape your car. You better learn that.
Ex's:
