Vw citi rox 1.4i to 2.0 8v
Just want some advice based on the conversion to 2.0 8v
Is the gearbox of the 1.4i the same as the 2.0 8v ady or weaker?
Will everything just fit as many people say or is there mods to be done?
Re: Vw citi rox 1.4i to 2.0 8v
DAT gearbox is going to run out if steam at 200km/hDirka wrote:Hi guys
Sent from my REBEL using Tapatalk
- mike65
- Car Model: mk1
You will need to change ecu and starter and the gearbox will work yes however you will need to get a 9bolt 210mm flywheel and clutch kit
Watch this space
Starter ? Why?
- chucker02
- Car Model: Citi ADY
1971 VW beetle
1971 VW beetle
- Dub rox
- Car Model: Citi sport 1.4i
Shot on that one.Masendaco wrote:DAT gearbox is going to run out if steam at 200km/hDirka wrote:Hi guys
Depends on what you want the conversion for. Had a mate a while back that did the" 2.6 kombi piston" conversion on his 1.6 i and that thing farked of my man. Like you said, the gearbox ran out of steam at arround 200km/h and got there fast.
IMO the ratios are abit short. Could have it modified at your local gearbox expert??
my 1.4 runs out of steam at 100km/hMasendaco wrote:DAT gearbox is going to run out if steam at 200km/hDirka wrote:Hi guys
- Dub rox
Then you have big problems my man.....175SBU wrote:my 1.4 runs out of steam at 100km/hMasendaco wrote:DAT gearbox is going to run out if steam at 200km/hDirka wrote:Hi guys
My Velo is standard 1.4 with no mods done on it but that thing is a donkey, robot to robot is ok but nada speed on the freeway.
- Dub rox
Should be able to do at least 180km/h175SBU wrote:My Velo is standard 1.4 with no mods done on it but that thing is a donkey, robot to robot is ok but nada speed on the freeway.
- chucker02
Why would you want to go over 200km/h with a citi anyway? Its more than enough. A citi is not built for top speed
1971 VW beetle
1971 VW beetle
- Dub rox
If properly built, why not. Speed gets your adrenaline going, wich in turn makes you feel great.....chucker02 wrote:Why would you want to go over 200km/h with a citi anyway? Its more than enough. A citi is not built for top speed
I go 200km/h in my dreams, in reality Its a struggle to even reach 120km/h
- Dub rox
Time for a propper service and tune-up for your velo then.........175SBU wrote:I go 200km/h in my dreams, in reality Its a struggle to even reach 120km/h
That car gets a lekker service all the time every time but hey! I found myself a ROX 1.6 with a performance exhaust, I’m busy fixing this and that on it, will probably take it for a spin this weekend.
Fun times ahead, i’m replacing timing belt, rear wheel bearings, handbrake cables, going bigger brake discs, temperature switch, clean throttle body, put performance filter, front wheel bearings, clean airflow sensor, replace clutch kit, service CV’s and and and.
- chucker02
Dub rox wrote: ↑Tue Dec 04, 2018 1:23 pmIf properly built, why not. Speed gets your adrenaline going, wich in turn makes you feel great.....chucker02 wrote:Why would you want to go over 200km/h with a citi anyway? Its more than enough. A citi is not built for top speed
1971 VW beetle
1971 VW beetle
- mike65
- Car Model: mk1
I did the same conversion and starter was to weak to turn the 2lt engine so i had to get a reduction starter
Watch this space
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
My thoughts too.
- chucker02
Thats bs, I had 2 ADY golfs and used the stock starter. Your timing was probably too far advanced causing the engine to turn harder when hot.
OP, just search on the forum for the 2litre conversion. It has been discussed to death and back.
1971 VW beetle
1971 VW beetle
the joy in driving a citigolf is when u hammer opposition robot to robot and then your point is proven
top end is for laaties that cant accept defeat.
- chucker02
+1
1971 VW beetle
1971 VW beetle
- Dub rox
Different thing all together if you reach you top speed from robot to robot though........Lnrathan wrote:the joy in driving a citigolf is when u hammer opposition robot to robot and then your point is proven
- Dub rox
Your motor has an air presure sensor. Just be carefull what and how you clean it..175SBU wrote:That car gets a lekker service all the time every time but hey! I found myself a ROX 1.6 with a performance exhaust, I’m busy fixing this and that on it, will probably take it for a spin this weekend.
What zorst is fitted, size, back to front, branch mani, etc?
Remember to get the tensioner/idler for the cambelt aswell.
On the filter- just get a decent filtering one, crapp make = crapp filtration= dust in motor= gringing paste on working bits........
- Dub rox
https://www.google.co.za/url?sa=t&sourc ... kbyvebq2xsDub rox wrote:Your motor has an air presure sensor. Just be carefull what and how you clean it..175SBU wrote:That car gets a lekker service all the time every time but hey! I found myself a ROX 1.6 with a performance exhaust, I’m busy fixing this and that on it, will probably take it for a spin this weekend.
Ish. Then you need a monsterDub rox wrote:Different thing all together if you reach you top speed from robot to robot though........Lnrathan wrote:the joy in driving a citigolf is when u hammer opposition robot to robot and then your point is proven
