Total noob VW owner questions
Hi guys! So, ya, new VW owner here. I have a few questions I hope you guys can answer about the car I bought today.
It's a 2000 Polo Playa 1.6 hatchback manual. Bought it with 140000km something on the clock, it runs well, no oil leaks, no smoke, no dodgy sounds or anything and the engine sounds NICE. but the one thing that worries me is I have no idea when last the cam belt was checked. I know what happens to an engine when the cam belt snaps. A few friends told me that the car's engine is non-interference, so I wouldn't have to worry about bending valves and damaging pistons. Yeah, the skeptical side of me kicked in. I basically have three questions I hope you guys can answer.
1) Is this engine non-interference?
2) What would it cost to have the cam belt checked?
3) What would it cost to replace the cam belt if it needs to be replaced?
Any solid info would be greatly appreciated.
EDIT: Changed title to closer resemble thread
Re: How do you know if your engine is interference or non-interference?
Gee man the parts will cost you like r300 maybe and say two hours labour at most.
So under R2k. Why risk it?
It should be non interference but some people just have no luck. Of you are one of those just get it changed.
You serious? That cheap? Sho, ok well that's awesome! Thanks, buddy!
Is there a way you can tell if it's interference by looking at it?
- ICE King
Nope , Non interference means the valve and pistons does not meet when the valve is open , How would you see this by looking at the engine from the outside?SnowHonkey wrote: ↑Thu Nov 15, 2018 10:13 am Is there a way you can tell if it's interference by looking at it?
Agree with panic , this should not be an issue or discussion , just change the cam-belt and carry on driving like a boss
For sure, bru. Going to change it anyway. Just being a curious noob.ICE King wrote:Nope , Non interference means the valve and pistons does not meet when the valve is open , How would you see this by looking at the engine from the outside?SnowHonkey wrote: ↑Thu Nov 15, 2018 10:13 am Is there a way you can tell if it's interference by looking at it?
There are published lists by manufacturers of what is interference and what is not. BUT let me tell you about lists. Sometimes they aren't too good in real life. Post and engine code. If it is HM in theory it is non interference but I have seen some meet up anyways.
So again. safest if the history is unknown is to simply change it as a precuation - rather be safe than test theory.
- Dub rox
- Car Model: Citi sport 1.4i
If the valve and piston meet when the valve is open your timing is all wrong budICE King wrote:Nope , Non interference means the valve and pistons does not meet when the valve is open , How would you see this by looking at the engine from the outside?SnowHonkey wrote: ↑Thu Nov 15, 2018 10:13 am Is there a way you can tell if it's interference by looking at it?
- Dub rox
Like panic sayd. Its cheap enough to do and have piece of mind than to wonder when last or if it has been changed. Save your self the headache and just get it done.SnowHonkey wrote:Hi guys! So, ya, new VW owner here. I have a few questions I hope you guys can answer about the car I bought today.
Do a cambelt and tensioner/idle bearing and have no worry motoring. Your car has low millage so i take it it has been cared for and loved but one can never be sure unless it was logged in the service books.
- ICE King
Exactly why I don't believe in the non-interference notion,Since the intro of Overhead Camshafts , it's a thing of the pastDub rox wrote: ↑Thu Nov 15, 2018 2:53 pmIf the valve and piston meet when the valve is open your timing is all wrong budICE King wrote:Nope , Non interference means the valve and pistons does not meet when the valve is open , How would you see this by looking at the engine from the outside?SnowHonkey wrote: ↑Thu Nov 15, 2018 10:13 am Is there a way you can tell if it's interference by looking at it?
It's really luck , as I seen some claim non interference motors bend valve and see case where an claimed interference design not bend valves.
Well, I've successfully identified my engine. It's a 1600 8v MP9. Hooray! Taking it in on Monday to get the cam belt changed. While the mechanic is at it, I'm going to get him to change the plugs, filters and oil same time.
Yesterday it started whining from the engine compartment. It whines when idling and pitch changes with revs. Randomly the engine just cuts out too, happens when sitting in traffic and this morning when I put the car into reverse. Clutch is all the way down when it happens. Starts again immediately, though. On top of that, the speedo just bounces at 0 and the rev counter doesn't move at all, but that's random. Next time I start it up, the needles work normally again and then later when I start it up again, the needles don't work. I'm going to take an uneducated guess and say all the above is the alternator.
- Dub rox
Those normally give a whing noise from the alternator. Have that tested as well, could just be a bearing on the altinator or the idle bearing/tensioner on the cam belt.SnowHonkey wrote:Well, I've successfully identified my engine. It's a 1600 8v MP9. Hooray! Taking it in on Monday to get the cam belt changed. While the mechanic is at it, I'm going to get him to change the plugs, filters and oil same time.
Let them do a test on the alterator it self aswell to see if it is charging correctly.
If you dont trust the VW experts, maybe the tech experts will give you the answer you seek..
https://mybroadband.co.za/forum/threads ... ne.989406/
[Audi A3 2.0T http://vwclub.co.za/forum/viewtopic.php?f=11&t=177350]
Polo Playa 1.6 Oo oO
Ex: Polo Playa 1.8 - Sold
That's my wifeRubbin&dubbin wrote:If you dont trust the VW experts, maybe the tech experts will give you the answer you seek..
Re: Total noob VW owner questions
Thanks for all the info, guys.
Car went for a proper service and now has new filters, new plugs, new oil, a new cam belt and a new tensioner. Runs like a beast. Didn't cost that much either, just over R3k. Very happy I bought this car. Only thing remaining is the bearing on the alternator is a bit noisy, but since the alternator still works fine, I'll sort that out some other time.
Thanks again!
Thanks again!
- Car Make: SEAT
LOL, just as well you have joined here ... perhaps you'll learn something!SnowHonkey wrote: ↑Fri Nov 16, 2018 3:38 pmThat's my wifeRubbin&dubbin wrote:If you dont trust the VW experts, maybe the tech experts will give you the answer you seek..
The answer is: the Ibiza and the Polo are two different vehicles that may, or may not, share some parts - depending on model.I think because this model was only released for South Africa and was then renamed to the SEAT Ibiza. Still cannot get a clear answer.
