Missing parts for Mark 1 towbar
- xXx
- Car Model: MK1 20V T
I bought a bossal tow bar off gum-tree only to find it wasn't complete , its missing the bumper brackets . Anyone does have any hang about I can buy or copy?
Current : 2018 Mark 6 Polo GTI
Ex: : 1994 Citi 1.8T 20 v
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Polo GTI 1.4 TSI ( Biggest kak ever )
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex 2008 Rox 16V ABF ( Miss that car )
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
- Car Make: SEAT
Re: Missing parts for Mark 1 towbar
Huh? A genuine Bosal towbar has the brackets integrated into the towbar - IOW, you remove the standard bumper brackets so that you could fit the towbar.
Methinks someone lost/threw the original brackets away and proceeded to grind them off the towbar, rendering it useless.
- xXx
From what I can gather they screw in from the side
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
There are also 2 versions of mk1 bumper.
Original steel jobs
Plastic cover jobs
For the first one I think they were indeed welded to the towbar and you just bolted the steel bumper on straight to that
For the plastic jobs you had to bolt the stiffener to the towbar and then clip the plastic bumper on and I think those were bolt onto the towbar. But it's easy enought to work it out by just looking at what is needed.
Otherwise just contact bosal and ask if they can help you. They do still exist.
Original steel jobs
Plastic cover jobs
- Car Make: SEAT
AFAIK, only one Bosal towbar that fits all A1 Golfs - and it requires that you remove the existing OEM brackets for fitment, like so:panic-mechanic wrote: ↑Wed Nov 14, 2018 6:48 am There are also 2 versions of mk1 bumper.
Original steel jobs
Plastic cover jobs
ETA: DO NOT (ever) use the existing OEM bumper brackets to fit any towbar to - you WILL thank me later!
I think we are talking about different brackets. You are talking about the thing that has 2 bolts each side that sticks into the channel. I am talking about the bracket that the bumper stiffener then mounts to the towbar to.
I think the OP needs to post a picture or clarify which part he is talking about.
- Car Make: SEAT
panic-mechanic wrote: ↑Thu Nov 15, 2018 8:16 am I think the OP needs to post a picture or clarify which part he is talking about.
- xXx
Hi Guys
I will post pics of what a have , this week end .
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
- xXx
That hole is threaded and an bracket attaches there.
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
- Car Make: SEAT
So you do not need bumper brackets, as I have previously stated.
1. Remove existing bumper by removing the 4 bolts on the inside, under the carpet - keep these bolts for refitting towbar;
2. Remove the bumper brackets from the rest of the bumper, again retaining all bolts;
3. You are now left with what is called a bumper stiffener which bolts into those holes - if memory serves ...
4. Refit in reverse order!
So as I stated originally, you might need to make up the brackets to bolt the stiffener to the towbar.
- xXx
Yip Bosal described it as a L Bracket.panic-mechanic wrote: ↑Mon Nov 19, 2018 11:08 am So as I stated originally, you might need to make up the brackets to bolt the stiffener to the towbar.
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
- Car Make: SEAT
The L-brackets should already be fitted to your existing bumper stiffener, if memory serves. I know that I did not have to buy any extras when I fitted the towbar to my wife's CitiGolf.xXx wrote: ↑Tue Nov 20, 2018 10:50 pmYip Bosal described it as a L Bracket.panic-mechanic wrote: ↑Mon Nov 19, 2018 11:08 am So as I stated originally, you might need to make up the brackets to bolt the stiffener to the towbar.
- xXx
My L brackets are not correct. Are they different on new citis?Supervan II wrote: ↑Wed Nov 21, 2018 10:49 amThe L-brackets should already be fitted to your existing bumper stiffener, if memory serves. I know that I did not have to buy any extras when I fitted the towbar to my wife's CitiGolf.xXx wrote: ↑Tue Nov 20, 2018 10:50 pmYip Bosal described it as a L Bracket.panic-mechanic wrote: ↑Mon Nov 19, 2018 11:08 am So as I stated originally, you might need to make up the brackets to bolt the stiffener to the towbar.
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
- Car Make: SEAT
Post pics so that we can see.xXx wrote: ↑Wed Nov 21, 2018 5:33 pmMy L brackets are not correct. Are they different on new citis?Supervan II wrote: ↑Wed Nov 21, 2018 10:49 amThe L-brackets should already be fitted to your existing bumper stiffener, if memory serves. I know that I did not have to buy any extras when I fitted the towbar to my wife's CitiGolf.xXx wrote: ↑Tue Nov 20, 2018 10:50 pmYip Bosal described it as a L Bracket.panic-mechanic wrote: ↑Mon Nov 19, 2018 11:08 am So as I stated originally, you might need to make up the brackets to bolt the stiffener to the towbar.
